HE9116 Synchronous Step-Up
DC-DC Converter with PFM Control
Features
External parts: Coil, capacitor
Output voltage: Settable to between
Accuracy of ±2%
2.1V to 5.5V in 0.1V steps
High efficiency :95%
Maximum Oscillation
Package: SOT23 and TO92
Digital cameras
Cameras , video equipment
Electronic notebooks and PDAS
Communications equipment
Portable CD/MD players
Power supply for microcomputers
frequency :300KHz
Applications
General Description
The
HE9116
Series is a Synchronous
an external coil, capacitor. The built-in
step-up DC/DC Converter with PFM Control.
MOSFET is turned off by a protection circuit
With the HE Series, a step-up switching DC/
when the voltage at the LX pin exceeds the
DC converter can be configured by using
limit to prevent it from being damaged.
Block Diagram
Order Information
HE9116①②③④⑤
Designator
1
②③
④
⑤
Ver1.4
Symbol
A
B
Integer
N
T
R
G
Description
Standard
Another pin definition
Output Voltage
(2.1~5.5) e.g:3.0V=②:3;③:0
Package:SOT23
Package:TO-92
RoHS / Pb Free
Halogen Free
Oct 22,2015
Pin Assignment
Table1 HE9116A series (SOT23 PKG)
PIN NO.
PIN NAME
FUNCTION
1
VOUT
Output voltage pin
2
GND
GND pin
3
LX
External inductor connection pin
Table2 HE9116A series (TO92 PKG)
PIN NO.
PIN NAME
FUNCTION
1
GND
GND pin
2
VOUT
Output voltage pin
3
LX
Table3 HE9116B series (TO92PKG)
Ver1.4
PIN NO.
PIN NAME
FUNCTION
1
VOUT
Output voltage pin
2
GND
GND pin
3
LX
Oct 22,2015
Absolute Maximum Ratings
(Unless otherwise specified, Ta=25℃)
PARAMETER
SYMBOL
RATINGS
UNITS
VOUT Pin Voltage
VOUT
VSS-0.3~VSS+8
V
EN Pin Voltage
EN
VSS-0.3~VSS+8
V
LX Pin Voltage
VLX
VSS-0.3~VSS+8
V
LX Pin Current
ILX
500
mA
250
mW
250
mW
500
mW
500
mW
SOT23
Power
SOT23-3/SOT23-5
Dissipation
SOT-89-3
PD
TO-92
Operating Temperature
TOPR
-40~+85
Storage Temperature
TSTG
-40~+125
Soldering Temperature & Time
TSOLDER
260℃,10s
Note: These are stress ratings only. Stresses exceeding the range specified under “Absolute Maximum
Ratings” may cause substantial damage to the device. Functional operation of this device at other
conditions beyond those listed in the specification is not implied and prolonged exposure to extreme
conditions may affect device reliability.
Electrical Characteristics
(Unless otherwise specified,Ta = 25℃)
PARAMETER
SYMBOL
Output Voltage
VOUT
Input Voltage
VIN
Operation Start Voltage
VST1
Input Current At No Load
ISS1
Current Consumption 2
Current Consumption
During Shutdown
Maximum Oscillation
Frequency
MIN
UNITS
CONDITION
V
7.5
V
0.9
V
IOUT=1mA
15
uA
VIN=1.8V, VOUT=3.0V
ISS2
6
10
uA
VOUT=VOUT(s)+0.5V
ISSS
1.0
uA
VEN=0V
VOUT(S)
X0.98
fosc
Duty Ratio1
Duty1
Efficiency
EFF1
TYP
VOUT
MAX
VOUT(S)
X1.02
300
70
78
KHz
85
90
VOUT=0.95xVOUT(s), measure
Waveform at LX pin
VOUT=0.95xVOUT(s)
VOUT=0.95xVOUT(s), judge
VSH
0.75
V
VSL
0.3
V
Shutdown Pin input
ISH
-0.1
0.1
uA
VEN=6V
Current
ISL
-0.1
0.1
uA
VEN=0V
Shutdown Pin Input
Voltage
Oscillation at LX pin
stop at LX pin
Remark: VOUT(S) specified above is the set output voltage value,and VOUT is the typical value of the
actual output voltage
Ver1.4
Oct 22,2015
Application Circuits
Note:External Component Recommendation:
1)
L=47uH(Sumida)
2)
C=100uF/16V(Tantalum)
Ver1.4
Oct 22,2015
TYPICAL PERFORMANCE CHARACTERISTICS
(Cin=Cout=100uF,L=47uH)
Ver1.4
Oct 22,2015
Package Information
3-pin SOT23 Outline Dimensions
Ver1.4
Oct 22,2015
3-pin TO92 Outline Dimensions
Ver1.4
Oct 22,2015
很抱歉,暂时无法提供与“HE9116A33NR”相匹配的价格&库存,您可以联系我们找货
