600V N-Channel MOSFET
General Description
Features
This Power MOSFET is produced using Truesemi‘s
advanced planar stripe DMOS technology.
This advanced technology has been especially tailored to
minimize on-state resistance, provide superior switching
performance, and withstand high energy pulse in the
avalanche and commutation mode. These devices are well
suited for high efficiency switched mode power supplies,
active power factor correction based on half bridge
topology.
Absolute Maximum Ratings
Symbol
• 10.0A,600V,Max.RDS(on)=0.8Ω @ VGS =10V
• Low gate charge(typical 48nC)
• High ruggedness
• Fast switching
• 100% avalanche tested
• Improved dv/dt capability
TC=25℃ unless otherwise specified
Parameter
VDSS
Drain-Source Voltage
VGS
Gate-Source Voltage
TSP10N60M
TSF10N60M
Units
600
V
± 30
V
TC = 25℃
10.0
10.0*
A
TC = 100℃
6.0
6.0*
A
40
40*
A
ID
Drain Current
IDM
Pulsed Drain Current
(Note 1)
EAS
Single Pulsed Avalanche Energy
(Note 2)
709
mJ
EAR
Repetitive Avalanche Energy
(Note 1)
16.2
mJ
Peak Diode Recovery dv/dt
(Note 3)
4.5
V/ns
dv/dt
PD
TJ, TSTG
TL
Power Dissipation (TC = 25℃)
-Derate above 25℃
162
52
W
1.30
0.42
W/℃
Operating and Storage Temperature Range
-55 to +150
300
Maximum lead temperature for soldering purposes,
1/8” from case for 5 seconds
* Drain current limited by maximum junction temperature.
Thermal Resistance Characteristics
Symbol
Parameter
TSP10N60M
TSF10N60M
Units
RθJC
Thermal Resistance,Junction-to-Case
0.77
2.4
℃/W
RθCS
Thermal Resistance,Case-to-Sink Typ.
0.5
℃/W
RθJA
Thermal Resistance,Junction-to-Ambient
62.5
62.5
℃/W
© 2018 Truesemi Semiconductor Corporation
Ver.C1
www.truesemi.com
TSP10N60M/TSF10N60M
TSP10N60M/TSF10N60M
Symbol
Parameter
Test Conditions
Min
Typ
Max
Units
Gate Threshold Voltage
VDS = VGS, ID = 250 uA㎂
3.0
5.0
V
Static Drain-Source
On-Resistance
VGS = 10 V, ID = 5.0A
0.62
0.8
Ω
600
V
ID = 250 uA, Referenced to 25
0.7
V/℃
VDS = 600 V, VGS = 0 V
1
uA
VDS = 480 V, TJ = 125℃
10
uA
On Characteristics
VGS
RDS(ON)
Off Characteristics
BVDSS
Drain-Source Breakdown Voltage
△BVDSS Breakdown Voltage Temperature
/ △TJ
Coefficient
VGS = 0 V, ID = 250 uA㎂
IDSS
Zero Gate Voltage Drain Current
IGSSF
Gate-Body Leakage Current,Forward
VGS = 30 V, VDS = 0 V
100
nA㎁
IGSSR
Gate-Body Leakage Current,Reverse
VGS =- 30 V, VDS = 0 V
-100
nA㎁
1650
pF㎊
165
pF㎊
18
pF
25
ns
70
ns㎱
140
ns㎱
80
ns㎱
48
nC
7.0
nC
18.0
nC
Dynamic Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VDS = 25 V, VGS = 0 V,
f = 1.0 MHz
Switching Characteristics
td(on)
Turn-On Time
tr
Turn-On Rise Time
td(off)
Turn-Off Delay Time
tf
Turn-Off Fall Time
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS = 300V, ID = 10.0A,
RG = 25 Ω
(Note 4,5)
VDS = 480 V, ID = 10.0A,
VGS = 10 V
(Note 4,5)
Source-Drain Diode Maximum Ratings and Characteristics
IS
Continuous Source-Drain Diode Forward Current
10.0
ISM
Pulsed Source-Drain Diode Forward Current
40.0
VSD
Source-Drain Diode Forward Voltage
IS = 10.0A, VGS = 0 V
1.4
trr
Reverse Recovery Time
IS =10.0A, VGS = 0 V
430
ns㎱
Qrr
Reverse Recovery Charge
diF/dt = 100 A/μs
4.3
uC
(Note 4)
A
V
NOTES:
1. Repetitive Rating: Pulse width limited by maximum junction temperature
2. L=13mH, IAS=10.0A, VDD=50V, RG=25 Ω,Starting TJ=25 ℃
3. ISD≤10.0A, di/dt ≤ 200A/us, VDD ≤ BVDSS, Starting TJ = 25 ℃
4. Pulse Test: Pulse width ≤ 300us, Duty Cycle ≤ 2%
5. Essentially Independent of Operating Temperature Typical Characteristics
Ver.C1
www.truesemi.com
TSP10N60M/TSF10N60M
Electrical Characteristics TC=25 ℃
TSP10N60M/TSF10N60M
Ver.C1
www.truesemi.com
TSP10N60M/TSF10N60M
Ver.C1
www.truesemi.com
TSP10N60M/TSF10N60M
Ver.C1
www.truesemi.com
TSP10N60M/TSF10N60M
Fig 12. Gate Charge Test Circuit & Waveform
50KΩ
12V
VGS
Same Type
as DUT
200nF
Qg
10V
300nF
VDS
VGS
Qgs
Qgd
DUT
3mA
Charge
Fig 13. Resistive Switching Test Circuit & Waveforms
RL
VDS
VDS
90%
VDD
RG
( 0.5 rated VDS )
Vin
DUT
10V
10%
td(on)
tr
td(off)
t on
t off
tf
Fig 14. Unclamped Inductive Switching Test Circuit & Waveforms
L
VDS
VDD
ID
RG
10V
1
EAS = ---- LL IAS2
2
BVDSS
IAS
ID (t)
DUT
VDS (t)
VDD
tp
Ver.C1
Time
www.truesemi.com
TSP10N60M/TSF10N60M
Fig 15. Peak Diode Recovery dv/dt Test Circuit & Waveforms
DUT
VDS
_
IS
L
Driver
RG
VGS
VGS
( Driver )
IS
( DUT )
Same Type
as DUT
VDD
• dv/dt controlled by RG
• IS controlled by pulse period
Gate Pulse Width
D = -------------------------Gate Pulse Period
10V
IFM , Body Diode Forward Current
di/dt
IRM
Body Diode Reverse Current
VDS
( DUT )
Body Diode Recovery dv/dt
VDD
Vf
Body Diode
Forward Voltage Drop
Ver.C1
www.truesemi.com
TSP10N60M/TSF10N60M
Package Dimension
Ver.C1
www.truesemi.com
TSP10N60M/TSF10N60M
Package Dimension
Ver.C1
www.truesemi.com
很抱歉,暂时无法提供与“TSP10N60M”相匹配的价格&库存,您可以联系我们找货
