LC3030
High Efficiency Low Noise PFM Step-up DC/DC Converter
DESCRIPTION
FEATURES
LC3030 series are CMOS-based PFM step-up DCDC Converter. The converter can start up by
supply voltage as low as 0.8V, and capable of
delivering maximum 200mA output current at
3.3V output with 1.8V input Voltage. Quiescent
current drawn from power source is as low as
5.5uA. All of these features make LC3030 series
be suitable for the portable devices, which are
supplied by a single battery to four-cell batteries.
To reduce the noise caused by the switch
regulator, LC3030 is well considerate in circuit
design and manufacture, so that the interferer to
other circuits by the device is reduced greatly.
LC3030 integrates stable reference circuits and
trimming technology, so it can afford high
precision and low temperature-drift coefficient of
the output voltage.
Deliver 200mA at 3.3V output voltage with
1.8V input voltage
Low start-up voltage (when the output
current is 1mA)-----------------------------0.8V
Output voltage can be adjusted from 2.5V~
6.0V (In 0.1V step)
Output voltage accuracy ---------------2%
Low temperature-drift coefficient of the
output voltage--------------------100ppm/℃
Only three external components are
necessary: an inductor, a Schottky diode and
an output filter capacitor
High power conversion efficiency-----85%
Low quiescent current drawn from power
source-------------------------------------
很抱歉,暂时无法提供与“LC3030CB5TR36”相匹配的价格&库存,您可以联系我们找货
