LC6020
1A Standalone Linear Li-Ion Battery Charge
DESCRIPTION
FEATURES
The LC6020 is a single cell, fully integrated
constant current (CC)/constant voltage (CV) Li-ion
battery charger. Its compact package with
minimum external components requirement
makes the LC6020 ideal for portable applications.
No external sense resistor or blocking diode is
necessary for the LC6020. Build-in thermal
feedback mechanism regulates the charge
current to control the die temperature during
high power operation or at elevated ambient
temperature.
The LC6020 has a pre-charge function for trickle
charging deeply discharged batteries. The fast
charge current can be programmed by an
external resistor. CV regulation mode is
automatically enabled once the battery’s
charging curve reaches the constant voltage
portion. The output current then decays and is
finally terminated once the charge current drops
to 1/10 of the programmed value. The LC6020
keeps monitoring the battery voltage and enables
a new charge cycle once the voltage drops by
150mV below the CV value.
Standalone Capability with no Requirement
of External MOSFET, Sense Resistor or
Blocking Diode.
Complete Linear Charger in Compact Package
for Single Cell Lithium-Ion Batteries
Programmable Pre-charge, Fast Charge and
Termination Current.
Constant-Current/Constant-Voltage Operation
with Thermal Regulation to Maximize Charge
Rate Without Risk of Overheating
Charges Single Cell Li-Ion Batteries Directly
from USB Port
Preset 4.2V Charge Voltage with 1% Accuracy
Automatic Recharge
Charge Status Output Pin
C/10 Charge Termination
25A Supply Current in Shutdown
2.9V Trickle Charge Threshold
Soft-Start Limits Inrush Current
Available in ESOP8 Package
APPLICATIONS
Power supply state is constantly monitored and
the battery drain current is reduced to minimum
value automatically when the LC6020 senses a
lack of input power. In its shutdown mode, the
LC6020 can reduce the supply current to less than
25μA. A status pin outputs a logic HIGH/LOW to
indicate the charging status and the presence of
power supply.
Cellular Telephones, PDAs, MP3 Players
Charging Docks and Cradles
Bluetooth Applications
Other features include charge current monitor,
under-voltage lockout.
TYPICAL APPLICATION
www.leadchip.com.cn
1
Your final power solution
LC6020
ORDERING INFORMATION
LC6020 □
1□
2□
3
Code
1
3
Product Classification
Description
LC6020CS8TR
ESOP-8
B3:Product code
Temperature&Rohs:
C:-40~85C ,Pb Free Rohs Std.
Package type:
S8:ESOP8
Packing type:
TR:Tape&Reel (Standard)
NC
LL: Lot No.
B3
LLXYW
X: Fab code
YW: Date code
PROG
GND
VCC
NC
B3
LLXYW
2
PIN CONFIGURATION
CHRG
STDBY
BAT
Note:Y: The Year of manufacturing,”1” stands for year
2011,”2” stands for year 2012,and “8” stands for year 2018.
W: The week of manufacturing. ”A” stands for week 1,”Z”
stands for week 26,” A ” stands for week 27,” Z ” stands
for week 52.
BLOCK DIGRAM
www.leadchip.com.cn
2
LC6020
PIN DESCRIPTION
PROG (Pin2): Program, Monitor the charge
current and Shutdown. This pin set to 1V in
constant-current mode. The charge current is
programmed by connecting a 1% resistor, RPROG,
to GND pin. The charge current can be calculated
using the following formula:
VCC (Pin4): Positive Input Supply. Needs to be
bypassed with at least a 1μF capacitor. When
input voltage drops to within 80mV of the BAT
pin voltage, the LC6020 switches to shutdown
mode.
BAT (Pin5): Charge Current Output. This pin
provides charge current to the battery and
regulates the final float voltage to 4.2V which is
set by an internal precision resistor divider.
I BAT (VPROG / RPROG ) 1000
The PROG pin can also be used to switch the
charger to shutdown mode by disconnecting the
program resistor from ground. This result in a
3μA current to pull the PROG pin to a high level
shutdown threshold voltage, thus stop the
charging and reduce the supply current to 25μA.
This pin is also clamped to approximately 2.4V. A
higher voltage beyond this value will draw
currents as high as 1.5mA. Device normal
operation can be resumed by reconnecting the
RPROG resistor to ground.
STDBY (Pin6): Open-Drain Charge Status Output.
The STDBY pin outputs low when the battery is
full.
̅̅̅̅̅̅̅̅ (Pin7): Open-Drain Charge Status Output.
The ̅̅̅̅̅̅̅̅ pin outputs low when the battery is
charging. When the LC6020 detects an under
voltage lockout condition, ̅̅̅̅̅̅̅̅ is forced high
impedance.
GND (Pin3): Ground.
ABSOLUTE MAXIMUM RATING
Parameter
Value
VCC
PROG
BAT
–0.3V to 6V
– 0.3V to VCC + 0.3V
–0.3V to 5V
–0.3V to 6V
Continuous
5mA
125°C
–40°C to 85°C
–40°C to 125°C
260°C
BAT short-circuit duration
PROG pin current
Maximum junction temperature
Operating ambient temperature range
Storage temperature range
Lead temperature (soldering, 10 sec)
Note:
Exceed these limits to damage to the device.
Exposure to absolute maximum rating conditions may affect device reliability.
www.leadchip.com.cn
3
LC6020
ELECTRICAL CHARACTERISTICS
VCC=5V, TA=25°C, RPROG=10K, unless otherwise noted.
SYMBOL
VCC
ICC
PARAMETER
CONDITIONS
MIN TYP MAX UNITS
Input supply voltage
Input supply current
VFLOAT
Regulated output (float) voltage
IBAT
BAT pin current
ITRIKL
VTRIKL
VTRHYS
VUV
VUVHYS
Trickle charge current
Trickle charge threshold voltage
Trickle charge hysteresis voltage
VCC under voltage lockout threshold
VCC under voltage lockout hysteresis
VMSD
Manual shutdown threshold voltage
VASD
VCC–VBAT lockout threshold voltage
ITERM
4.25
Charge mode (note 1)
Standby mode (charge terminated)
Shutdown mode (RPROG not connected,
VCC
很抱歉,暂时无法提供与“LC6020CS8TR”相匹配的价格&库存,您可以联系我们找货
