MS60N03
MS60N03
    MSKSEMI(美森科)
    TO252
    类型:N沟道;漏源电压(Vdss):30V;连续漏极电流(Id):60A;功率(Pd):17W;
MS60N03 数据手册
www.msksemi.com MS60N03 Semiconductor Product Summary ● VDS ● ID ● RDS(ON)( at VGS=10V) ● RDS(ON)( at VGS=4.5V) ● 100% UIS Tested ● 100% ▽VDS Tested 30V 60A <9.0mohm <11.0mohm Compiance Schematic diagram General Description ● Trench Power LV MOSFET technology ● Excellent package for heat dissipation ● High density cell design for low RDS(ON) Applications ● High current load applications ● Load switching ● Hard switched and high frequency circuits ● Uninterruptible power supply TO-252 ■ Absolute Maximum Ratings (TA=25℃unless otherwise noted) Parameter Symbol Limit Drain-source Voltage VDS 30 V Gate-source Voltage VGS ±20 V 60 TC=25℃ ID Drain Current IDM TC=25℃ Total Power Dissipation A 35 TC=100℃ Pulsed Drain Current A Unit 150 A 34 W 17 W PD TC=100℃ Single Pulse Avalanche Energy B EAS 80 mJ Thermal Resistance Junction-to-Case C RθJC 4.4 ℃/ W TJ ,TSTG -55~+175 ℃ Junction and Storage Temperature Range www.msksemi.com MS60N03 Semiconductor Compiance ■ Electrical Characteristics (TJ=25℃ unless otherwise noted) Parameter Symbol Conditions Min Drain-Source Breakdown Voltage BVDSS VGS= 0V, ID=250μA 30 Zero Gate Voltage Drain Current IDSS Typ Max Units Static Parameter V 1 TJ=25℃ VDS=30V,VGS=0V μA 5 TJ=55℃ IGSS VGS= ±20V, VDS=0V Gate Threshold Voltage VGS(th) VDS= VGS, ID=250μA Static Drain-Source On-Resistance RDS(ON) Gate-Body Leakage Current Diode Forward Voltage Maximum Body-Diode Continuous Current VSD ±100 nA 1.5 2.5 V VGS= 10V, ID=15A 6.5 9.0 VGS= 4.5V, ID=15A 8.6 11.0 IS=15A,VGS=0V 0.85 1.2 V 50 A 1.0 mΩ IS Dynamic Parameters Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss 114 Total Gate Charge Qg 28 Gate-Source Charge Qgs Gate-Drain Charge Qgd Reverse Recovery Charge Qrr 920 VDS=15V,VGS=0V,f=1MHZ 198 pF Switching Parameters VGS=10V,VDS=15V,ID=50A 7 nC 5 25 IF=20A, di/dt=100A/us Reverse Recovery Time trr 26 Turn-on Delay Time tD(on) 8 Turn-on Rise Time tr Turn-off Delay Time tD(off) Turn-off fall Time tf VGS=10V,VDD=20V, ID=2A,RL=1Ω RGEN=3Ω 15 ns 27 7 A. Pulse Test: Pulse Width≤300us,Duty cycle ≤2%. B. Tj=25℃, VDD=20V, VG=10V, L=0.5mH, Rg=25Ω C. RθJA is the sum of the junction-to-case and case-to-ambient thermal resistance, where the case thermal reference is defined as the solder mounting surface of the drain pins. RθJC is guaranteed by design, while RθJA is determined by the board design. The maximum rating presented here is based on mounting on a 1 in 2 pad of 2oz copper. www.msksemi.com MS60N03 Semiconductor Compiance ■ Typical Performance Characteristics Figure1. Output Characteristics Figure3. Capacitance Characteristics Figure5. Drain-Source on Resistance Figure2. Transfer Characteristics Figure4. Gate Charge Figure6. Drain-Source on Resistance www.msksemi.com MS60N03 Semiconductor Figure7. Safe Operation Area Compiance Figure8. Switching wave www.msksemi.com MS60N03 Semiconductor Compiance PACKAGE MECHANICAL DATA D A D1 c V L3 h A1 L4 L E φ L2 L1 D2 b e Symbol A A1 b c D D1 D2 E e L L1 L2 L3 L4 Φ θ h V Dimensions In Millimeters Min. Max. 2.200 2.400 0.000 0.127 0.635 0.770 0.460 0.580 6.500 6.700 5.100 5.460 4.830 REF. 6.000 6.200 2.186 2.386 9.712 10.312 2.900 REF. 1.400 1.700 1.600 REF. 0.600 1.000 1.100 1.300 0° 8° 0.000 0.300 5.250 REF. Dimensions In Inches Min. Max. 0.087 0.094 0.000 0.005 0.025 0.030 0.018 0.023 0.256 0.264 0.201 0.215 0.190 REF. 0.236 0.244 0.086 0.094 0.382 0.406 0.114 REF. 0.055 0.067 0.063 REF. 0.024 0.039 0.043 0.051 0° 8° 0.000 0.012 0.207 REF. REEL SPECIFICATION P/N MS60N03 PKG QTY TO-252 2500 www.msksemi.com MS60N03 Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
MS60N03 价格&库存
很抱歉,暂时无法提供与“MS60N03”相匹配的价格&库存,您可以联系我们找货
