B
N02B
20V /6A Single N Power MOSFET
SM2312SRL
N
V
General Description
DS
RDS(on),TYP@VGS=10V
RDS(on),TYP@VGS=4.5
ID
Very low on-resistance RDS(on) @ VGS=4.5 V
Pb-free lead plating; RoHS compliant
Part ID
Package Type
Marking
Tape and reel
infomation
SM2312SRL
SOT23-3
2312
3000
Parameter
6N02B
V
18.9
mΩ
42.0
mΩ
6
A
100% UIS Tested
100% Rg Tested
Symbol
Maximum
Units
Drain-Source Voltage
VDS
V
Gate-Source Voltage
VGS
12
±V
Continuous Drain Current A
Pulsed Drain Current
Avalanche Current
TA=25°C
TA=70°C
B
Power Dissipation
G
9.6
IAR
1.9
EAR
4.4
TA=25°C
A
A
mJ
1.4
PD
TA=70°C
Junction and Storage Temperature Range
5.0
IDM
G
Repetitive avalanche energy L=0.1mH
6.0
ID
W
0.9
-55 to 150
TJ, TSTG
°C
Thermal Characteristics
Parameter
Symbol
Maximum Junction-to-Ambient
A
t ≤ 10s
A
Steady State
Maximum Junction-to-Lead
V01
C
Steady State
1
www.sourcechips.com
RθJA
RθJL
Typ
Max
Units
67
101
°C/W
135
162
°C/W
40
64
°C/W
STATIC PARAMETERS
Symbol
BVDSS
Parameter
Drain-Source Breakdown
Voltage
Conditions
ID = -250uA, VGS = 0V
IDSS
Zero Gate Voltage Drain Current
VDS=20V, VGS=0V
IGSS
Gate-Body leakage current
VDS = 0V, VGS = ±20V
VGS(th)
Gate Threshold Voltage
VDS = VGS ID = 250µA
RDS(ON)
Static Drain-Source OnResistance
gFS
VSD
IS
SM2312SRL
Min
Typ
Max
Units
V
1
5
uA
±100
nA
0.8
1.1
V
VGS=-10V, ID=6A
18.9
27.0
VGS=4.5V, ID=6A
42.0
55.0
Forward Transconductance
VDS=5V, ID=6A
82
Diode Forward Voltage
IS=1A,VGS=17V
0.72
0.6
mΩ
S
1
V
6
A
Typ
Max
Units
525
640
pF
95
116
pF
75
89
pF
1
Ω
Max
Units
Maximum Body-Diode Continuous Current
DYNAMIC PARAMETERS
Symbol
Parameter
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
Conditions
Min
VGS=0V, VDS=15V, f=1MHz
VGS=0V, VDS=0V, f=1MHz
SWITCHING PARAMETERS
Symbol
Parameter
Qg (10V)
Total Gate Charge
Qg 4.5V)
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
2
tD(on)
Turn-On DelayTime
7
tr
Turn-On Rise Time
tD(off)
Turn-Off DelayTime
tf
Turn-Off Fall Time
Body Diode Reverse Recovery
Time
trr
Qrr
V01
Charge
Conditions
Min
Typ
6
VGS=10V, VDS=15V, ID=6A
VGS=10V, VDS=15V,RL=0.75Ω,
RGEN=3Ω
3
1.4
5.6
19.6
nC
ns
6.3
IF=-8A, dI/dt=500A/µs
14
ns
IF=18A, dI/dt=500A/µs
6
nC
2
www.sourcechips.com
V01
3
www.sourcechips.com
SM2312SRL
V01
4
www.sourcechips.com
SM2312SRL
很抱歉,暂时无法提供与“SM2312SRL”相匹配的价格&库存,您可以联系我们找货
