JSM3401
P-Channel 30-V(D-S) MOSFET
V(BR)DSS
RDS(on)MAX
ID
SOT-23
0.060Ω@-10V
-30V
0.070Ω@-4.5V
3
-4.0A
1.GATE
2.SOURCE
0.100Ω@-2.5V
1
3.DRAIN
2
Equivalent Circuit
MARKING
General FEATURE
●TrenchFET Power MOSFET
●Lead free product is acquired
●Surface mount package
A11TF w
APPLICATION
●Load Switch for Portable Devices
●DC/DC Converter
*w:week code
Maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Value
Symbol
Unit
Drain-Source Voltage
VDS
-30
Gate-Source Voltage
VGS
±12
Continuous Drain Current
ID
-4.0
Pulsed Drain Current
IDM
-25
Maximum Power Dissipation
PD
1.2
W
R θJA
104
℃/W
Junction Temperature
TJ
150
Storage Temperature
Tstg
-55 ~+150
Thermal Resistance from Junction to Ambient(t ≤5s)
V
A
MOSFET ELECTRICAL CHARACTERISTICS
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
Units
Static characteristics
Drain-source breakdown voltage
V
-30
BVDSS
VGS = 0V, ID =-250µA
Zero gate voltage drain current
IDSS
VDS =-24V,VGS = 0V
-1
µA
Gate-source leakage current
IGSS
VGS =±12V, VDS = 0V
±100
nA
Drain-source on-resistance (note a)
Forward tranconductance (note a)
Gate threshold voltage
Diode forward voltage (note a)
RDS(on)
gFS
VGS(th)
VSD
VGS =-10V, ID =-4.0A
55
60
mΩ
VGS =-4.5V, ID =-3.5A
65
70
mΩ
VGS =-2.5V, ID =-1.2A
95
100
mΩ
VDS =-5V, ID =-4.0A
7
10
VDS =VGS, ID =-250µA
-0.6
-1
IS=-1A,VGS=0V
S
-1.2
V
-1.2
V
Dynamic characteristics (note b)
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitance
950
pF
115
pF
Crss
75
pF
td(on)
7.0
ns
VDS =-15V, VGS = 0 V, f =1MHz
Switching Characteristics (note b)
Turn-on delay time
Turn-on rise time
Turn-off delay time
Turn-off fall time
tr
VGS=-10V,VDS=-15V,
3.0
ns
td(off)
ID =-4.0A ,RGEN=6Ω
30
ns
12
ns
tf
Notes:
a.Pulse Test : Pulse Width < 300µs, Duty Cycle ≤2%.
b.These parameters have no way to verify.
Typical Electrical and Thermal Characteristics
ton
tr
td(on)
toff
tf
td(off)
90%
VOUT
90%
INVERTED
10%
10%
90%
VIN
50%
50%
10%
PULSE WIDTH
Figure 2:Switching Waveforms
ID- Drain Current (A)
PD Power(W)
Figure 1:Switching Test Circuit
TJ-Junction Temperature(℃)
Figure 3 Power Dissipation
Figure 4 Drain Current
Rdson On-Resistance(mΩ)
Vds Drain-Source Voltage (V)
Figure 5 Output Characteristics
Figure 6 Drain-Source On-Resistance
Normalized On-Resistance
Figure 7 Transfer Characteristics
Figure 8 Drain-Source On-Resistance
4.0A
C Capacitance (pF)
Vgs Gate-Source Voltage (V)
4.0A
Qg Gate Charge (nC)
Figure 11 Gate Charge
Figure 10 Capacitance vs Vds
Is- Reverse Drain Current (A)
Figure 9 Rdson vs Vgs
Vsd Source-Drain Voltage (V)
Figure 12 Source- Drain Diode Forward
r(t),Normalized Effective
Transient Thermal Impedance
Figure 13 Safe Operation Area
Square Wave Pluse Duration(sec)
Figure 14 Normalized Maximum Transient Thermal Impedance
SOT-23 Package Outline Dimensions
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
Dimensions In Millimeters
Min
Max
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP
1.800
2.000
0.550 REF
0.300
0.500
0°
8°
SOT-23 Suggested Pad Layout
Dimensions In Inches
Min
Max
0.035
0.045
0.004
0.000
0.041
0.035
0.020
0.012
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP
0.071
0.079
0.022 REF
0.012
0.020
0°
8°
很抱歉,暂时无法提供与“JSM3401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.11572
- 200+0.10070
- 600+0.09237
- 3000+0.08337
- 9000+0.07903
- 21000+0.07669
