Document: W0803152, Rev: C
WM02N70M
M
N-Channel MOSFET
Features
VDS= 20V, ID = 7A
RDS(on) < 25mΩ @ VGS = 4.5V
RDS(on) < 30mΩ @ VGS = 2.5V
High Power and Current Handing Capability
ESD Protected
Mechanical Characteristics
SOT-23 Package
Marking : Making Code
RoHS Compliant
Schematic & PIN Configuration
D
G
D
G
S
S
Device symbol
SOT-23(Top View)
Absolute Maximum Rating
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
V
Gate-Source Voltage
VGS
±10
V
Continuous Drain Current
ID
7
A
Pulsed Drain Current 1
IDM
24
A
Power Dissipation
PD
1.3
W
Junction Temperature
TJ
150
°C
Storage Temperature
TSTG
-55 to +150
°C
Thermal Resistance from Junction to Ambient 2
RθJA
96
°C/W
©2019 WAYON Corporation
www.way-on.com
1 / 4
N Channel MOSFET
WM02N70M
Electrical Characteristics (Tamb=25°C unless otherwise noted)
Parameter
Symbol
Test Condition
Min.
Typ.
Max.
Unit
Static Characteristics
Drain-Source Breakdown Voltage
BVDSS
VGS = 0 V, ID = 250µA
V
Drain Cut-off Current
IDSS
VDS = 20V, VGS = 0 V
1
µA
Gate Leakage Current
IGSS
VGS = ±10V, VDS = 0 V
±10
µA
Gate Threshold Voltage3
VGS(th)
VGS = VDS, ID = 250µA
0.4
0.62
1.0
V
VGS = 4.5V, ID =6A
14
25
Drain-Source on-State Resistance3
RDS(on)
VGS = 2.5V, ID = 4A
18
30
850
140
mΩ
Dynamic Characteristics
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
105
Total Gate Charge4
Qg
11
Gate-Source Charge4
Qgs
2
Gate-Drain Charge4
Qgd
3.1
Turn-on Time4
td(on)
5.2
14
23
15
1.2
VGS = 0 V, VDS = 10V,
f = 1 MHz
pF
Switching Characteristics
Rise Time4
Turn-off Time4
tr
td(off)
Fall Time4
VGS = 4.5V, ID = 6A,
VDS = 10V
VGS= 4.5V, VDD = 10V,
RL = 1.5Ω, RGEN= 3Ω,
tf
nC
nS
Source-Drain Diode Characteristics
Body Diode Voltage
VSD
VGS = 0V, IS= 1A
V
Notes:
1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. Surface mounted on FR4 board using 1 square inch pad size,1oz single-side copper.
3. Pulse Test: Pulse width≤300μs, duty cycle≤2%.
4. Guaranteed by design, not subject to product
www.way-on.com
2 / 4
N Channel MOSFET
WM02N70M
Typical Characteristics
Figure 1. Output Characteristics
Figure 3. RDS(on) vs. ID
Figure 5. IS vs. VSD
Figure 2. Transfer Characteristics
Figure 4. RDS(on) vs. VGS
Figure 6. Capacitance Characteristics
www.way-on.com
3 / 4
N Channel MOSFET
WM02N70M
Outline Drawing – SOT-23
PACKAGE OUTLINE
D
b
3
DIMENSIONS
0.25
E1 E
θ
1
SYMBOL
c
2
e
e1
A
b
A
MIN
0.035
MAX
0.045
A1
0.00
0.10
0.000
0.004
b
0.30
0.50
0.012
0.020
c
0.08
0.15
0.003
0.006
D
2.80
3.00
0.110
0.118
E
2.25
2.55
0.089
0.100
E1
1.20
1.40
0.047
0.055
DIM
INCHES
MILLIMETERS
M
0.080
2.02
C
0.032
0.80
Z
0.111
2.82
e
0.037 BSC
0.95 BSC
e1
0.075 BSC
1.90 BSC
b
0.032
0.80
M
C
0.95 BSC
0.0374 BSC
e1
1.80
2.00
0.071
0.079
L
0.45
0.65
0.018
0.026
θ
Notes
DIMENSIONS
Z
INCHES
MAX
1.15
e
A1
MILLIMETER
MIN
0.90
L
1. Dimensioning and tolerances per ANSI Y14.5M,
1985.
2. Controlling Dimension: Inches
3. Pin 3 is the cathode (Unidirectional Only).
4. Dimensions are exclusive of mold flash and metal
burrs.
e
e1
Marking Codes
Part Number
WM02N70M
Marking Code
3416E
Package Information
Qty:3k/Reel
CONTACT INFORMATION
No.1001, Shiwan (7) Road, Pudong District, Shanghai, P.R.China.201207
Tel: 86-21-68969993 Fax: 86-21-50757680 Email: market@way-on.com
WAYON website: http://www.way-on.com
For additional information, please contact your local Sales Representative.
® is registered trademark of Wayon Corporation.
Specifications are subject to change without notice.
The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time.
Users should verify actual device performance in their specific applications.
www.way-on.com
4 / 4
很抱歉,暂时无法提供与“WM02N70M”相匹配的价格&库存,您可以联系我们找货
