ShenZhen HanKingYuan Electronic Co.,Ltd
KY3407
-30V P-Channel Mosfet
SOT-23
FEATURES
● RDS(ON) ≤ 60mΩ( 48mΩ Typ.)
@VGS=-10V
● RDS(ON) ≤ 85mΩ( 62mΩ Typ.)
@VGS=-4.5V
1. GATE
2. SOURCE
3. DRAIN
APPLICATIONS
● Load Switch
● Power Management
MARKING
P-CHANNEL MOSFET
3407
3407:Device code
MAXIMUM RATINGS (Ta=25°C unless otherwise noted)
Symbol
Parameter
Max.
Units
VDSS
Drain-Source Voltage
-30
V
VGSS
Gate-Source Voltage
±20
V
ID
Continuous Drain Current
-4.1
A
IDM
Pulsed Drain Current note1
-16.4
A
Ptot
Total Power Dissipation
W
Thermal Resistance, Junction to Ambient
1.67
75
℃/W
Junction Temperature
150
-55 to +150
RθJA
TJ
TSTG
Storage Temperature Range
www.scr-ky.com
1/5
KY3407
MOSFET ELECTRICAL CHARACTERISTICS Ta=25 °C unless otherwise specified
Parameter
Symbol
bol
Test Condition
Min.
Typ.
Max.
Units
Off Characteristic
V(BR)DSS
Drain-Source Breakdown Voltage
VGS = 0V,ID = -250μA
-30
V
IDSS
Zero Gate Voltage Drain Current
VDS = -30V,
VGS = 0V, TJ = 25℃
-1
μA
IGSS
Gate to Body Leakage Current
VGS = ±20V,VDS = 0V
±100
nA
Gate Threshold Voltage
VDS =VGS,ID = -250μA
-1.0
-1.4
-2.5
V
Static Drain-Source
VGS =-10V, ID =-4.1A
48
60
On-Resistance note2
VGS =-4.5V, ID =-3.5A
62
85
VDS =-5V, ID = -4.1A
5
S
580
pF
98
pF
74
pF
6.8
nC
1.0
nC
1.4
nC
14
ns
61
ns
19
ns
10
ns
On Characteristics
VGS(th)
RDS(on)
gFS
Forwar d Transconductance
mΩ
Dynamic Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain(“Miller”) Charge
VDS =-15V, VGS = 0V
f = 1.0MHz
VDS=-15V, ID=-4.1A,
VGS=-10V
Switching Characteristics
td(on)
Turn-On Delay Time
tr
Turn-On Rise Time
td(off)
Turn-Off Delay Time
tf
Turn-Off Fall Time
VGS = -10V, VDS=-15V
RG =2.5Ω, ID=-1A
RL =15Ω,
Drain-Source Diode Characteristics and Maximum Ratings
IS
Maximum Continuous Drain to Source Diode Forward
Current
-4.1
A
ISM
Maximum Pulsed Drain to Source Diode Forward Current
-16.4
A
VSD
Voltage
-0.89
-1.2
V
VGS = 0V, ISD=-4.1A
TJ = 25℃
Notes: 1. Repetitive Rating: Pulse width limited by maximum junction temperature
2 . Pulse Test: Pulse width ≤ 300μs, Duty Cycle ≤ 2%
www.scr-ky.com
2/5
KY3407
TYPICAL PERFORMANCE CHARACTERISTICS
Figure 2: Typical Transfer Characteristics
Figure1: Output Characteristics
-ID (A)
-ID (A)
15
-5V
-10V
-4.5V
TJ=25℃
12
15
-4V
9
10
6
-3.5V
5
-VDS(V)
2
3
4
5
-VGS(V)
RDS(ON) (mΩ)
1
3
4
5
6
Figure 4: Body Diode Characteristics
Figure 3:On-resistance vs. Drain Current
70
TJ=125℃
3
VGS=-3V
10
-IS(A)
60
VGS= -4.5V
50
TJ=150℃
VGS= -10V
40
30
TJ=-50℃
TJ=-25℃
1
-ID(A)
1
2
3
4
5
6
7
8
0.1
0.0
Figure 5: Gate Charge Characteristics
8
0.2
0.4
-VSD(V)
0.6
0.8
1.0
1.2
1.4
Figure 6: Capacitance Characteristics
-VGS(V)
103
VGS=-10V
ID=-5.1A
C(pF)
Ciss
6
4
Coss
102
Crss
2
Qg(nC)
2
4
www.scr-ky.com
6
8
10
12
101
-VDS(V)
10
40
50
60
3/5
KY3407
TYPICAL PERFORMANCE CHARACTERISTICS (cont.)
Figure 7: Normalized Breakdown Voltage vs.
VBR(DSS)(V)
1.3
Figure 8: Normalized on Resistance vs.
RDS(on)(mΩ)
2.5
1.2
2.0
1.1
1.5
1.0
1.0
0.9
Tj (℃)
-50
100
150
200
Figure 9: Maximum Safe Operating Area
-ID(A)
0.5
-100
1ms
150
200
-ID(A)
3
100ms
DC
2
TC=25℃
Single pulse
1
100
4
10ms
0.1
0.1
50
5
100μs
1
10μs
10
-50
Figure 10: Maximum Continuous Drain Current
vs. Case Temperature
7
Limited by RDS(on)
Tj (℃)
1
-VDS (V)
10
50
Tc (℃)
75
100
125
150
Figure.11: Maximum Effective
Transient Thermal Impedance, Junction-to-Ambient
(SOP-8)
102
ZthJ-C(℃/W)
101
D=0.5
t1
D=0.2
D=0.1
t2
D=0.05
D=0.02
D=0.01
Notes:
Single pulse 1.Duty factor D=t1/t2
2.Peak TJ=PDM*ZthJC+TC
TP(s)
PDM
100
10-1
10-2 -4
10
10-3
10-2
www.scr-ky.com
10-1
100
101
102
4/5
KY3407
SOT-23 PACKAGE OUTLINE DRAWING
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min
Max
Min
Max
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.000
0.004
A2
0.900
1.050
0.035
0.041
b
0.300
0.500
0.012
0.020
c
0.080
0.150
0.003
0.006
D
2.800
3.000
0.110
0.118
E
1.200
1.400
0.047
0.055
E1
2.250
2.550
0.089
0.100
e
e1
0.950 TYP
1.800
L
0.037 TYP
2.000
0.071
0.550 REF
L1
0.300
0.500
0.012
θ
0°
8°
0°
www.scr-ky.com
0.079
0.022 REF
0.020
8°
5/5
很抱歉,暂时无法提供与“KY3407”相匹配的价格&库存,您可以联系我们找货
