ME6208
150 mA, high input voltage LDO Linear Regulators ME6208 Series
General Description
Features
High output accuracy:± 2%
Input voltage:up to 18 V
Output voltage:3.0 V ~ 5.0V
Ultra-low quiescent current (Typ. = 3 µ A)
Output Current:Iout = 200mA
(When Vin = 7V and Vout =5V)
Importation good stability:Typ. 0.05% / V
Low temperature coefficient
Ceramic capacitor can be used
Package:SOT89-3、SOT23-3、TO92
ME6208 series are low-dropout linear
voltage regulators with a built-in voltage
reference module, error correction module
and phase compensation module. ME6208
series are based on the CMOS process and
allow high voltage input with low quiescent
current. This series has the function of
internal feedback resistor setting from 3.0V
to 5.0V. The output accuracy is ± 2%.
Typical Application
Selection Guide
Electronic weighbridge
SCM
Phones, cordless phones
Security Products
Water meters, power meters
Typical Application Circuit
V04
www.microne.com.cn
Page 1 of 8
ME6208
Pin Configuration
Pin Assignment
ME6208AXX
Pin Number
Pin Name
Functions
1
VSS
Ground
2
3
VIN
Power Input
3
2
VOUT
Output
SOT89-3 / TO92
SOT23-3
1
Absolute Maximum Ratings
Parameter
Symbol
Ratings
Units
Input Voltage
VIN
18
V
Output Current
IOUT
250
mA
Output Voltage
VOUT
Vss-0.3~VIN +0.3
V
500
mW
500
mW
300
mW
SOT89-3
Power Dissipation
TO92
PD
SOT23-3
Operating Temperature Range
TOPR
-25~+85
Storage Temperature Range
TSTG
-40~+125
Lead Temperature
260℃,10sec
Block Diagram
V04
www.microne.com.cn
Page 2 of 8
ME6208
Electrical Characteristics
ME6208A
(VIN= VOUT+2.0V,CIN=CL=10uF,Ta=25OC, unless otherwise noted)
Parameter
Output Voltage
Input Voltage
Maximum Output
Current
Load Regulation
Dropout Voltage
(Note 3)
Supply Current
Line Regulations
Symbol
Conditions
VOUT(E)
IOUT=40mA,
(Note 2)
VIN=Vout+2V
Min.
X 0.98
Typ.
VOUT (T)
(Note 1)
VIN
IOUT _max
∆VOUT
VIN=Vout+2V
VIN=Vout+2V,
1mA≤IOUT≤100mA
150
Max.
Units
X 1.02
V
18
V
mA
10
mV
Vdif1
IOUT =50mA
250
mV
Vdif2
IOUT =100mA
500
mV
Vdif3
IOUT =200mA
1000
mV
ISS
VIN=Vout+2V
3
μ A
∆VOUT
IOUT =40mA
∆VIN ×VOUT
Vout+2V ≤VIN≤18V
0.05
%/V
Note :
1. VOUT (T) :Specified Output Voltage
2.VOUT (E) :Effective Output Voltage ( ie. The output voltage when “VOUT (T)+2.0V”is provided at the Vin pin while
maintaining a certain Iout value.)
3.VDIF:VIN1 –VOUT (E)’
VIN1 :The input voltage when VOUT(E)’ appears as input voltage is gradually decreased.
VOUT (E)’=A voltage equal to 98% of the output voltage whenever an amply stabilized Iout and {VOUT (T)
+2.0V} is input.
Precautions
V04
During the test, if AC/DC power supply and the ceramic chip capacitors collocation is used,
there may be serious voltage spike phenomenon instantaneously. When the power supply
access to 16V, the voltage is rushed to about 30V instantaneously. Because of exceeding the
limit voltage of chip, the chip is damaged. If you string a small resistance of 1 ohm in the input
end during the test, the peak phenomenon can be avoided.
In the test, there is serious burr phenomenon only when the AC/DC power is used with
ceramic chip capacitors. But electrolytic capacitors and tantalum capacitance won't appear
above phenomenon. Please be sure to pay attention to this point when you use AC/DC power.
In normal use, when any type of capacitor is used with battery or the supply of fire power, the
above phenomenon doesn’t occur.
www.microne.com.cn
Page 3 of 8
ME6208
Type Characteristics
(1)Output CurrentVS.Output Voltage( Ta = 25 °C)
ME6208A50
Output Voltage VS. Output Current
Output Voltage (V)
5.30
5.20
5.10
5.00
4.90
4.80
4.70
60
80
100
120
140
160
180
200
Output Current(mA)
(2)Input VoltageVS.Output Voltage(Ta = 25 °C)
ME6208A50
Output Voltage(V)
Output Voltage VS. Input Voltage
5.50
5.00
4.50
4.00
3.50
3.00
2.50
2.00
1.50
1.00
0.50
0.00
Io=0mA
Io=40mA
1
2
3
4
5
6
7
8
9 10 11 12 13 14 15 16 17 18
Input Voltage(V)
V04
www.microne.com.cn
Page 4 of 8
ME6208
(3)Output Current VS.Droput Voltage( Ta = 25 °C)
ME6208A50
Dropout Voltage VS.Output Current
Dropout Voltage(mV)
1200
1000
800
600
400
200
100
150
200
Output Current (mA)
(4)Input Voltage VS. Supply Current(Ta = 25 °C)
ME6208A50
Quiescent Current VS. Input Voltage
Quiescent Current (uA)
5
4
3
2
1
4
6
8
10
12
14
16
18
Input Voltage(V)
V04
www.microne.com.cn
Page 5 of 8
ME6208
Packaging Information
● SOT89-3
● SOT23-3
V04
www.microne.com.cn
Page 6 of 8
ME6208
● TO-92
V04
www.microne.com.cn
Page 7 of 8
ME6208
V04
The information described herein is subject to change without notice.
Nanjing Micro One Electronics Inc is not responsible for any problems caused by circuits or diagrams
described herein whose related industrial properties, patents, or other rights belong to third parties.
The application circuit examples explain typical applications of the products, and do not guarantee the
success of any specific mass-production design.
Use of the information described herein for other purposes and/or reproduction or copying without the
express permission of Nanjing Micro One Electronics Inc is strictly prohibited.
The products described herein cannot be used as part of any device or equipment affecting the human
body, such as exercise equipment, medical equipment, security systems, gas equipment, or any
apparatus installed in airplanes and other vehicles, without prior written permission of Nanjing Micro
One Electronics Inc.
Although Nanjing Micro One Electronics Inc exerts the greatest possible effort to ensure high quality
and reliability, the failure or malfunction of semiconductor products may occur. The user of these
products should therefore give thorough consideration to safety design, including redundancy,
fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community
damage that may ensue.
www.microne.com.cn
Page 8 of 8
很抱歉,暂时无法提供与“ME6208A36TG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34621
- 100+0.28141
- 300+0.24901
