B772
SOT-89-3L Plastic-Encapsulate Transistors
TRANSISTOR(PNP)
SOT-89-3L
FEATURE
Low speed switching
1. BASE
MARKING:B772
2. COLLETOR
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
-40
V
VCEO
Collector-Emitter Voltage
-30
V
VEBO
Emitter-Base Voltage
-6
V
IC
Collector Current -Continuous
-3
A
PC
Collector Power Dissipation
0.5
W
RӨJA
Thermal Resistance, Junction to Ambient
250
℃/W
TJ,Tstg
Operation Junction and
Storage Temperature Range
-55~150
3. EMITTER
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC=-100μA ,IE=0
-40
V
Collector-emitter breakdown voltage
V(BR)CEO
IC= -10mA , IB=0
-30
V
Emitter-base breakdown voltage
V(BR)EBO
IE= -100μA,IC=0
-6
V
Collector cut-off current
ICBO
VCB= -40V, IE=0
-1
μA
ICEO
VCE=-30V, IB=0
-10
μA
Emitter cut-off current
IEBO
VEB=-6V, IC=0
-1
μA
DC current gain
hFE
VCE= -2V, IC= -1A
Collector-emitter saturation voltage
VCE(sat)
IC=-2A, IB= -0.2A
-0.5
V
Base-emitter saturation voltage
VBE(sat)
IC=-2A, IB= -0.2A
-1.5
V
VCE= -5V, IC=-0.1A
fT
Transition frequency
60
400
50
f =10MHz
MHz
CLASSIFICATION OF hFE
Rank
R
O
Y
GR
Range
60-120
100-200
160-320
200-400
V1.0_Aug,2018
-1-
www.wpmtek.com
B772
Typical Characteristics
Static Characteristic
-1.8
COMMON EMITTER
Ta=25℃
-1.6
IC
COMMON EMITTER
VCE= -2V
-6.75mA
-1.2
-4.5mA
-1.0
-3.75mA
-5.25mA
-2.25mA
-0.6
-1.5mA
-0.4
-0.2
DC CURRENT GAIN
1000
-3.0mA
-0.8
hFE
(A)
IC
-6.0mA
-1.4
COLLECTOR CURRENT
hFE
10000
-7.5mA
Ta=100℃
Ta=25℃
100
IB=-0.75mA
-0.0
-0.0
10
-0.5
-1.0
-1.5
-2.0
-2.5
COLLECTOR-EMITTER VOLTAGE
VCEsat ——
-1000
-3.0
-3.5
-1
-10
-100
COLLECTOR CURRENT
VCE (V)
VBEsat ——
IC
IC
-1000
-3000
-1000
-3000
(mA)
IC
-1500
β=10
β=10
BASE-EMITTER SATURATION
VOLTAGE VBEsat (mV)
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
-1200
-100
Ta=100 ℃
Ta=25℃
-10
-1
-1
-10
-100
COLLECTOR CURRENT
IC
-3000
-1000
IC
Ta=25℃
Ta=100 ℃
-300
-3000
-1
(mA)
-10
-100
COLLECTOR CURREMT
VBE
fT
200
IC
(mA)
IC
(MHz)
TRANSITION FREQUENCY
-10
T=
a 25
T
a
=1
00
-100
100
fT
(mA)
IC
-600
COMMON EMITTER
VCE= -2V
-1000
COLLECTOR CURRENT
-900
-1
COMMON EMITTER
VCE=-5V
Ta=25℃
-0.1
-300
-400
-500
-600
-700
-800
10
-4.23
-900 -1000 -1100-1200
BASE-EMMITER VOLTAGE VBE (mV)
PC
COLLECTOR POWER DISSIPATION
PC (W)
0.6
-10
COLLECTOR CURRENT
-100
IC
(mA)
Ta
0.5
0.4
0.3
0.2
0.1
0.0
50
75
AMBIENT TEMPERATURE
V1.0_Aug,2018
100
Ta
125
150
-2-
www.wpmtek.com
B772
SOT-89-3L Package Outline Dimensions
Dimensions In Millimeters
Max
Min
1.400
1.600
0.320
0.520
0.400
0.580
0.350
0.440
4.400
4.600
1.550 REF.
2.300
2.600
3.940
4.250
1.500 TYP.
3.000 TYP.
0.900
1.200
Symbol
A
b
b1
c
D
D1
E
E1
e
e1
L
Dimensions In Inches
Min
Max
0.055
0.063
0.013
0.020
0.016
0.023
0.014
0.017
0.173
0.181
0.061 REF.
0.091
0.102
0.155
0.167
0.060 TYP.
0.118 TYP.
0.035
0.047
SOT-89-3L Suggested Pad Layout
1.400
0.950
45°
1.600
2.200
1.300
0.700
0.900
0.800
1.500
V1.0_Aug,2018
-3-
www.wpmtek.com
很抱歉,暂时无法提供与“B772”相匹配的价格&库存,您可以联系我们找货
