BVDSS = 75V
RDS(on) = 16 mΩ
HD60N75 / HU60N75
ID = 60 A
75V N-Channel MOSFET
TO-252
TO-251
FEATURES
Originative New Design
HD60N75
Superior Avalanche Rugged Technology
Robust Gate Oxide Technology
HU60N75
1.Gate 2. Drain 3. Source
Very Low Intrinsic Capacitances
Excellent Switching Characteristics
Unrivalled Gate Charge : 40 nC (Typ.)
Extended Safe Operating Area
Lower RDS(ON) : 0.016 Ω (Typ.) @V GS=10V
100% Avalanche Tested
Absolute Maximum Ratings
Symbol
TC=25℃ unless otherwise specified
Parameter
Value
Units
75
V
VDSS
Drain-Source Voltage
ID
Drain Current
– Continuous (TC = 25℃)
60
A
Drain Current
– Continuous (TC = 100℃)
35.4
A
IDM
Drain Current
– Pulsed
200
A
VGS
Gate-Source Voltage
±20
V
EAS
Single Pulsed Avalanche Energy
(Note 2)
490
mJ
IAR
Avalanche Current
(Note 1)
60
A
EAR
Repetitive Avalanche Energy
(Note 1)
12
mJ
dv/dt
Peak Diode Recovery dv/dt
(Note 3)
7.0
V/ns
PD
Power Dissipation (TA = 25℃)*
3.75
W
Power Dissipation (TC = 25℃)
- Derate above 25℃
120
W
0.8
W/℃
-55 to +150
300
(Note 1)
TJ, TSTG
Operating and Storage Temperature Range
TL
Maximum lead temperature for soldering purposes,
1/8” from case for 5 seconds
Thermal Resistance Characteristics
Typ.
Max.
RθJC
Symbol
Junction-to-Case
Parameter
1.0
RθJA
Junction-to-Ambient*
40
RθJA
Junction-to-Ambient
62.5
* When mounted on the minimum pad size recommended (PCB Mount)
Units
℃/W
HD60N75_HU60N75
Nov 2009
Symbol
Parameter
Test Conditions
Min
Typ
Max
Units
On Characteristics
VGS
RDS(ON)
Gate Threshold Voltage
VDS = VGS, ID = 250 ㎂
2.0
4.0
V
Static Drain-Source
On-Resistance
VGS = 10 V, ID = 30 A
0.013
0.016
Ω
VGS = 0 V, ID = 250 ㎂
60
V
ID = 250 ㎂, Referenced to25℃
0.06
V/℃
VDS = 75 V, VGS = 0 V
1
VDS = 48 V, TC = 150℃
10
Off Characteristics
BVDSS
Drain-Source Breakdown Voltage
ΔBVDSS Breakdown Voltage Temperature
/ΔTJ
Coefficient
IDSS
Zero Gate Voltage Drain Current
IGSSF
Gate-Body Leakage Current,
Forward
VGS = 20 V, VDS = 0 V
100
IGSSR
Reverse
VGS = -20 V, VDS = 0 V
-100
1600
2270
600
780
90
120
15
40
105
220
60
130
65
140
40
52
nC
10
nC
17
nC
Dynamic Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VDS = 20 V, VGS = 0 V,
f = 1.0 MHz
td(on)
Turn-On Time
tr
Turn-On Rise Time
td(off)
Turn-Off Delay Time
tf
Turn-Off Fall Time
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
VDS = 30 V, ID = 60 A,
RG = 25 Ω
(Note 4,5)
VDS = 48 V, ID = 60 A,
VGS = 10 V
(Note 4,5)
Gate-Drain Charge
Source-Drain Diode Maximum Ratings and Characteristics
IS
Continuous Source-Drain Diode Forward Current
60
ISM
Pulsed Source-Drain Diode Forward Current
200
VSD
Source-Drain Diode Forward Voltage
IS = 60 A, VGS = 0 V
1.6
V
trr
Reverse Recovery Time
52
Qrr
Reverse Recovery Charge
diF/dt = 100 A/μs (Note 4)
75
μC
Notes ;
1. Repetitive Rating : Pulse width limited by maximum junction temperature
2. L=230μH, IAS=50A, VDD=25V, RG=25, Starting TJ =25C
3. ISD≤50A, di/dt≤300A/μs, VDD≤BVDSS , Starting TJ =25 C
4. Pulse Test : Pulse Width ≤ 300μs, Duty Cycle ≤ 2%
5. Essentially Independent of Operating Temperature
A
HD60N75_HU60N75
Electrical Characteristics TC=25 C
HD60N75_HU60N75
ID, Drain Current [A]
Typical Characteristics
VGS, Gate-Source Voltage [V]
VDS, Drain-Source Voltage [V]
Figure 1. On Region Characteristics
RDS(ON)[Ω],
Drain-Source On-Resistance
IDR, Reverse Drain Current [A]
Figure 2. Transfer Characteristics
VSD, Source-Drain Voltage [V]
Figure 4. Body Diode Forward Voltage
Variation with Source Current
and Temperature
Figure 3. On Resistance Variation vs
Drain Current and Gate Voltage
3000
Ciss
2000
Coss
1500
※ Note ;
1. VGS = 0 V
2. f = 1 MHz
1000
Crss
500
2500
Capacitances [pF]
12
Ciss = Cgs + Cgd (Cds = shorted)
Coss = Cds + Cgd
Crss = Cgd
VDS = 30V
10
VDS = 48V
8
6
4
2
※ Note : ID = 50 A
10
1
10
40
QG, Total Gate Charge [nC]
Figure 5. Capacitance Characteristics
Figure 6. Gate Charge Characteristics
50
HD60N75_HU60N75
(continued)
2.5
RDS(ON), (Normalized)
1.0
* Note :
1. VGS = 0 V
0.9
1.1
2.0
1.5
1.0
Note :
0.5
1. VGS = 10 V
2. ID = 25 A
2. ID = 250 A
0.0
-100
0.8
-100
-50
100
150
-50
50
100
150
200
o
TJ, Junction Temperature [ C]
o
Figure 8. On-Resistance Variation
vs Temperature
Figure 7. Breakdown Voltage Variation
vs Temperature
60
3
10
Operation in This Area
is Limited by R DS(on)
50
100 s
2
10
1 ms
10 ms
DC
1
10
* Notes :
o
1. TC = 25 C
40
30
o
2. TJ = 175 C
3. Single Pulse
-1
1
10
2
10
10
50
75
100
125
Figure 9. Maximum Safe Operating Area
Figure 10. Maximum Drain Current
vs Case Temperature
D=0.5
* Notes :
o
1. ZJC(t) = 1.24 C/W Max.
0.2
2. Duty Factor, D=t1/t2
0.1
3. TJM - TC = PDM * ZJC(t)
-1
10
0.05
PDM
0.02
0.01
t1
single pulse
-2
10
-5
10
-4
10
150
o
TC, Case Temperature [ c]
Zθ JC(t), Thermal Response
BVDSS, (Normalized)
1.2
-3
10
-2
10
-1
10
t2
t1, Square Wave Pulse Duration [sec]
Figure 11. Transient Thermal Response Curve
1
10
175
HD60N75_HU60N75
Fig 12. Gate Charge Test Circuit & Waveform
50KΩ
12V
VGS
Same Type
as DUT
200nF
Qg
10V
300nF
VDS
VGS
Qgs
Qgd
DUT
3mA
Charge
Fig 13. Resistive Switching Test Circuit & Waveforms
RL
VDS
VDS
90%
VDD
RG
( 0.5 rated VDS )
Vin
DUT
10V
10%
td(on)
tr
td(off)
t on
t off
tf
Fig 14. Unclamped Inductive Switching Test Circuit & Waveforms
BVDSS
1
EAS = ---- LL IAS2 -------------------2
BVDSS -- VDD
L
VDS
VDD
ID
BVDSS
IAS
RG
10V
ID (t)
DUT
VDS (t)
VDD
tp
Time
HD60N75_HU60N75
Fig 15. Peak Diode Recovery dv/dt Test Circuit & Waveforms
DUT
VDS
_
IS
L
Driver
RG
VGS
VGS
( Driver )
Same Type
as DUT
VDD
• dv/dt controlled by RG
• IS controlled by pulse period
Gate Pulse Width
D = -------------------------Gate Pulse Period
10V
IFM , Body Diode Forward Current
IS
( DUT )
di/dt
IRM
Body Diode Reverse Current
VDS
( DUT )
Body Diode Recovery dv/dt
Vf
Body Diode
Forward Voltage Drop
VDD
HD60N75_HU60N75
Package Dimension
TO
TO-252
2.3±0.1
6.6±0.2
1.2±0.3
9.7+0.5
-0.3
2.7±0.3
0.5±0.05
5.6±0.2
1±0.2
5.35±0.15
1.2±0.3
0.05+0.1
-0.05
0.8±0.2
0.6±0.2
2.3typ
2 3typ
2.3typ
0.5+0.1
-0.05
HD60N75_HU60N75
Package Dimension
TO
TO-251
6.6±0.2
2.3±0.1
0.8±0.15
0.6±0.1
2.3typ
2 3typ
2.3typ
7.8±0
±0.4
0.3
7.5
0.75±0.15
7±0.2
0.5±0.05
5.6±0.2
5.35±0.15
0.5+0.1
-0.05
1.2±0.3
