HY1904D/U/V
N-Channel Enhancement Mode MOSFET
Feature Description
Pin Description
40V/72A
RDS(ON)= 4.8mΩ(typ.)@VGS = 10V
RDS(ON)= 5.8mΩ(typ.)@VGS = 4.5V
100% Avalanche Tested
Reliable and Rugged
Lead Free and Green Devices Available
(RoHS Compliant)
TO-252-2L
TO-251-3L
TO-251-3S
Applications
Power Management for Inverter Systems
N-Channel MOSFET
Ordering and Marking Information
Package Code
D
HY1904
YYXXXJWW G
U
V
HY1904
HY1904
YYXXXJWW G
YYXXXJWW G
D: TO-252-2L
Date Code
YYXXX WW
U: TO-251-3L
V:TO-251-3S
Assembly Material
G:Halogen Free
Note: HOOYI lead-free products contain molding compounds/die attach materials and 100% matte tin plateTermiNation finish; which are fully compliant with RoHS. HOOYI lead-free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HOOYI defines “Green”
to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous
material and total of Br and Cl does not exceed 1500ppm by weight).
HOOYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr
-oduct and/or to this document at any time without notice.
www.hooyi.cc
V1.0
1
HY1904D/U/V
Absolute Maximum Ratings
Symbol
Parameter
Rating
Unit
Common Ratings (Tc=25°C Unless Otherwise Noted)
VDSS
Drain-Source Voltage
40
V
VGSS
Gate-Source Voltage
±20
V
Maximum Junction Temperature
175
°C
-55 to 175
°C
Tc=25°C
72
A
Tc=25°C
288
A
Tc=25°C
72
A
Tc=100°C
51
A
Tc=25°C
62.5
W
Tc=100°C
31
W
TJ
TSTG
Storage Temperature Range
IS
Source Current-Continuous(Body Diode)
Mounted on Large Heat Sink
Note:
IDM
Pulsed Drain Current *
ID
Continuous Drain Current
PD
Maximum Power Dissipation
RJC
Thermal Resistance, Junction-to-Case
2.4
°C/W
RJA
Thermal Resistance, Junction-to-Ambient **
110
°C/W
EAS
Single Pulsed-Avalanche Energy ***
134
mJ
L=0.3mH
Repetitive rating;pulse width limited by max. junction temperature.
Surface mounted on FR-4 board.
Limited by TJmax , starting TJ=25°C, L = 0.3mH, RG= 25Ω, VGS =10V.
Electrical Characteristics(Tc =25°C Unless Otherwise Noted)
Symbol
Parameter
Test Conditions
HY1904
Unit
Min
Typ.
Max
40
V
1
μA
5
μA
3
V
Static Characteristics
BVDSS
Drain-Source Breakdown Voltage
IDSS
Drain-to-Source Leakage Current
VGS(th)
IGSS
RDS(ON)*
VGS=0V,IDS=250μA
VDS=40V,VGS=0V
TJ=55°C
Gate Threshold Voltage
VDS=VGS, IDS=250μA
1
1.7
Gate-Source Leakage Current
VGS=±20V,VDS=0V
VGS=10V,IDS=36A
4.8
6.0
VGS=4.5V,IDS=36A
5.8
7.0
ISD=36A,VGS=0V
0.83
1.1
V
53
ns
78
nC
Drain-Source On-State Resistance
±100
nA
mΩ
Diode Characteristics
VSD*
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
ISD=36A,dISD/dt=100A/μs
www.hooyi.cc
V1.0
2
HY1904D/U/V
Electrical Characteristics (Cont.) (Tc =25°C Unless Otherwise Noted)
Symbol
Parameter
Test Conditions
HY1904
Min
Typ.
Max
1.6
2164
Unit
Dynamic Characteristics
RG
Gate Resistance
Ciss
Input Capacitance
VGS=0V,VDS=0V,F=1
MHz
VGS=0V,
Coss
Output Capacitance
VDS=25V,
202
Crss
Reverse Transfer Capacitance
Frequency=1.0MHz
75
td(ON)
Turn-on Delay Time
23
Tr
Turn-on Rise Time
VDD=20V,RG=4Ω,
28
td(OFF)
Turn-off Delay Time
IDS=36A,VGS=10V
29
34
51.5
5.5
11
Tf
Turn-off Fall Time
Gate Charge
Ω
pF
ns
Characteristics
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS =32V, VGS=10V,
ID=36A
nC
Note: *Pulse test,pulse width ≤ 300us,duty cycle ≤ 2%
www.hooyi.cc
V1.0
3
HY1904D/U/V
Typical Operating Characteristics
ID-Drain Current(A)
Voltage
Figure 2: Drain Current
Power Dissipation (w)
Figure 1: Power Dissipation
Tc-Case Temperature(℃)
Impedance (℃/W)
Thermal
Normalized Transient
Figure 4: Thermal Transient Impedance
Zjc
Voltage
ID-Drain Current(A)
Figure 3: Safe Operation Area
Maximum Effective Transient Thermal
Impedance, Junction-to-Case
VDS-Drain-Source Voltage(V)
VDS-Drain-Source Voltage (V)
Voltage
RDS(ON)-ON-Resistance(Ω)
Figure 6: Drain-Source On Resistance
Voltage
ID-Drain Current(A)
Figure 5: Output Characteristics
ID-Drain Current(A)
www.hooyi.cc
V1.0
4
HY1904D/U/V
Typical Operating Characteristics(Cont.)
VGS-Gate-Source Voltage (V)
Tj-Junction Temperature(℃)
Voltage
IS-Source Current (A)
Figure 10: Source-Drain Diode Forward
Voltage
Normalized On-Resistance
Figure 9: On-Resistance vs. Temperature
Tj-Junction Temperature (℃)
VSD-Source-Drain Voltage(V)
Voltage
Voltage
Figure 12: Gate Charge Characteristics
Figure 11: Capacitance Characteristics
C-Capacitance(pF)
Voltage
(mΩ)
Normalized Threshold Voltage (V)
Figure 8: Source-Drain Diode Forward
Voltage
RDS(ON)-On-Resistance(mΩ)
Figure 7: Gate-Source On Resistance
Q G-Gate Charge (nC)
www.hooyi.cc
V1.0
5
HY1904D/U/V
Avalanche Test Circuit and Waveforms
Switching Time Test Circuit and Waveforms
Gate Charge Test Circuit and Waveforms
www.hooyi.cc
V1.0
6
HY1904D/U/V
Device Per Unit
Package Type
Unit
Quantity
TO-252-2L
TO-251-3L
TO-251-3S
Tube
Tube
Tube
75
75
75
Package Information
TO-252-2L
www.hooyi.cc
V1.0
7
HY1904D/U/V
TO-251-3L
www.hooyi.cc
V1.0
8
HY1904D/U/V
TO-251-3S
www.hooyi.cc
V1.0
9
HY1904D/U/V
Classification Profile
Classification Reflow Profiles
Profile Feature
Preheat & Soak
Temperature min (Tsmin)
Temperature max (Tsmax)
Time (Tsmin to Tsmax) (ts)
Average ramp-up rate
(Tsmax to TP)
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body Temperature
(Tp)*
Time (tP)** within 5°C of the specified
classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to peak temperature
Sn-Pb Eutectic Assembly
Pb-Free Assembly
100 °C
150 °C
150 °C
200 °C
60-120 seconds
60-120 seconds
3 °C/second max.
3°C/second max.
183 °C
217 °C
60-150 seconds
60-150 seconds
See Classification Temp in table 1
See Classification Temp in table 2
20** seconds
30** seconds
6 °C/second max.
6 °C/second max.
6 minutes max.
8 minutes max.
*Tolerance for peak profile Temperature (T p) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
www.hooyi.cc
V1.0
10
HY1904D/U/V
Table 1.SnPb Eutectic Process – Classification Temperatures (Tc)
Package
Volume mm³
Volume mm³
Thickness
很抱歉,暂时无法提供与“HY1904D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.61277
- 10+1.30896
- 30+1.17882
- 100+1.01639
- 500+0.94403
- 1000+0.90062
