VBL1203M
www.VBsemi.com
Power MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
• Halogen-free According to IEC 61249-2-21
Definition
• Surface Mount
• Available in Tape and Reel
• Dynamic dV/dt Rating
• Repetitive Avalanche Rated
• Fast Switching
• Ease of Paralleling
• Simple Drive Requirements
• Compliant to RoHS Directive 2002/95/EC
200
RDS(on) ()
VGS = 10 V
0.30
Qg (Max.) (nC)
43
Qgs (nC)
7.0
Qgd (nC)
23
Single
Configuration
D
D2PAK (TO-263)
K
G
D
S
G
S
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted)
SYMBOL
LIMIT
Drain-Source Voltage
PARAMETER
VDS
200
Gate-Source Voltage
VGS
± 20
Continuous Drain Current
VGS at 10 V
TC = 25 °C
TC = 100 °C
Pulsed Drain Currenta
ID
IDM
UNIT
V
10
6.7
A
36
Linear Derating Factor
0.59
Linear Derating Factor (PCB Mount)e
0.025
W/°C
Single Pulse Avalanche Energyb
EAS
250
mJ
Repetitive Avalanche Currenta
IAR
9.0
A
EAR
7.4
mJ
Energya
Maximum Power Dissipation
TC = 25 °C
Maximum Power Dissipation (PCB Mount)e
TA = 25 °C
PD
74
3.0
W
* Pb containing terminations are not RoHS compliant, exemptions may apply
Peak Diode Recovery dV/dtc
服务热线:400-655-8788
dV/dt
5.0
V/ns
1
VBL1203M
www.VBsemi.com
PARAMETER
SYMBOL
LIMIT
TJ, Tstg
- 55 to + 150
Operating Junction and Storage Temperature Range
Soldering Recommendations (Peak Temperature)
UNIT
°C
300d
for 10 s
Notes
a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11).
b. VDD = 50 V, starting TJ = 25 °C, L = 4.6 mH, Rg = 25 , IAS = 9.0 A (see fig. 12).
c. ISD 9.0 A, dI/dt 120 A/μs, VDD VDS, TJ 150 °C.
d. 1.6 mm from case.
e. When mounted on 1" square PCB (FR-4 or G-10 material).
THERMAL RESISTANCE RATINGS
PARAMETER
SYMBOL
MIN.
TYP.
MAX.
Maximum Junction-to-Ambient
(PCB Mount)c
RthJA
40
RthJA
62
Maximum Junction-to-Case (Drain)
RthJC
1.7
UNIT
°C/W
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
PARAMETER
SYMBOL
TEST CONDITIONS
MIN.
VDS
TYP.
MAX.
UNIT
Static
Drain-Source Breakdown Voltage
VGS = 0, ID = 250 μA
200
V
VDS/TJ
Reference to 25 °C, ID = 1 mA
0.24
V/°C
VGS(th)
VDS = VGS, ID = 250 μA
2.0
4.0
V
Gate-Source Leakage
IGSS
VGS = ± 20 V
± 100
nA
Zero Gate Voltage Drain Current
IDSS
VDS = 200 V, VGS = 0 V
25
VDS = 160V, VGS = 0 V, TJ = 125 °C
250
0.30
3.8
S
800
240
76
43
VDS Temperature Coefficient
Gate-Source Threshold Voltage
Drain-Source On-State Resistance
Forward Transconductance
RDS(on)
gfs
ID = 5.4 Ab
VGS = 10 V
VDS = 50 V, ID = 5.4
Ab
μA
Dynamic
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-On Delay Time
td(on)
Rise Time
Turn-Off Delay Time
Fall Time
tr
td(off)
VGS = 0 V,
VDS = 25 V,
f = 1.0 MHz, see fig. 5
VGS = 10 V
ID = 5.9 A, VDS = 160 V
see fig. 6 and 13b
VDD = 100 V, ID = 5.9 A
Rg = 12 , RD= 16
see fig. 10b
tf
Internal Drain Inductance
LD
Internal Source Inductance
LS
Between lead,
6 mm (0.25") from
package and center of
die contact
D
7.0
23
9.4
28
39
7.5
pF
nC
ns
nH
G
S
服务热线:400-655-8788
2
VBL1203M
www.VBsemi.com
PARAMETER
SYMBOL
TEST CONDITIONS
MIN.
TYP.
MAX.
9.0
UNIT
Drain-Source Body Diode Characteristics
Continuous Source-Drain Diode Current
Pulsed Diode Forward
IS
Currenta
ISM
MOSFET symbol
showing the
integral reverse
p - n junction diode
D
A
G
S
36
VSD
TJ = 25 °C, IS = 9.0 A, VGS = 0 Vb
2.0
V
Body Diode Reverse Recovery Time
trr
170
340
ns
Body Diode Reverse Recovery Charge
Qrr
TJ = 25 °C, IF = 5.9 A,
dI/dt = 100 A/μsb
1.1
2.2
μC
Forward Turn-On Time
ton
Body Diode Voltage
Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD)
Notes
b. Pulse width 300 μs; duty cycle 2 %.
c. When mounted on 1" square PCB (FR-4 or G-10 material).
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
VGS
15 V
10 V
8.0 V
7.0 V
6.0 V
5.5 V
5.0 V
Bottom 4.5 V
101
100
4.5 V
91032_01
101
100
Fig. 1 - Typical Output Characteristics, TC = 25 °C
服务热线:400-655-8788
10-1
10-1
101
VDS, Drain-to-Source Voltage (V)
4.5 V
100
20 µs Pulse Width
TC = 25 °C
10-1
10-1
VGS
15 V
10 V
8.0 V
7.0 V
6.0 V
5.5 V
5.0 V
Bottom 4.5 V
Top
ID, Drain Current (A)
Top
91032_02
20 µs Pulse Width
TC = 150 °C
100
101
Fig. 2 - Typical Output Characteristics, TC = 150 °C
3
VBL1203M
www.VBsemi.com
1600
Capacitance (pF)
101
150 °C
25 °C
100
1200
Ciss
800
Coss
400
4
5
6
7
8
9
10
VGS, Gate-to-Source Voltage (V)
91032_03
Crss
20 µs Pulse Width
VDS = 50 V
10-1
2.5
ID = 5.9 A
VGS = 10 V
2.0
1.5
1.0
0.5
0.0
- 60 - 40 - 20 0
91032_04
Fig. 5 - Typical Capacitance vs. Drain-to-Source Voltage
RDS(on), Drain-to-Source On Resistance
(Normalized)
3.0
101
91032_05
Fig. 3 - Typical Transfer Characteristics
ID = 5.9 A
VDS = 160 V
16
VDS = 100 V
VDS = 40 V
12
8
4
For test circuit
see figure 13
20 40 60 80 100 120 140 160
TJ, Junction Temperature (°C)
Fig. 4 - Normalized On-Resistance vs. Temperature
4
VGS = 0 V, f = 1 MHz
Ciss = Cgs + Cgd, Cds Shorted
Crss = Cgd
Coss = Cds + Cgd
91032_06
10
40
50
QG, Total Gate Charge (nC)
Fig. 6 - Typical Gate Charge vs. Gate-to-Source Voltage
服务热线:400-655-8788
VBL1203M
www.VBsemi.com
ISD, Reverse Drain Current (A)
10
101
150 °C
25 °C
100
8
6
4
2
VGS = 0 V
0.5
0.7
0.9
VSD, Source-to-Drain Voltage (V)
91032_07
1.3
1.1
25
50
VGS
5
150
RD
D.U.T.
Rg
Operation in this area limited
by RDS(on)
125
Fig. 9 - Maximum Drain Current vs. Case Temperature
VDS
103
100
TC, Case Temperature (°C)
91032_09
Fig. 7 - Typical Source-Drain Diode Forward Voltage
75
- VDD
2
10 V
102
5
10 µs
2
10
100 µs
Fig. 10a - Switching Time Test Circuit
5
1 ms
2
10 ms
1
5
VDS
TC = 25 °C
TJ = 150 °C
Single Pulse
2
0.1
0.1
91032_08
Pulse width ≤ 1 µs
Duty factor ≤ 0.1 %
2
5
1
2
5
10
2
90 %
5
102
2
5
103
2
5
104
10 %
VGS
td(on)
Fig. 8 - Maximum Safe Operating Area
tr
td(off) tf
Fig. 10b - Switching Time Waveforms
服务热线:400-655-8788
5
VBL1203M
www.VBsemi.com
Thermal Response (ZthJC)
10
1
0 − 0.5
0.2
PDM
0.1
0.05
0.1
t1
0.02
0.01
t2
Single Pulse
(Thermal Response)
Notes:
1. Duty Factor, D = t1/t2
2. Peak Tj = PDM x ZthJC + TC
10-2
10-5
10-4
10-3
10-2
0.1
1
10
t1, Rectangular Pulse Duration (s)
91032_11
Fig. 11 - Maximum Effective Transient Thermal Impedance, Junction-to-Case
L
Vary tp to obtain
required IAS
VDS
VDS
tp
VDD
Rg
D.U.T.
IAS
V DD
VDS
10 V
tp
0.01 Ω
IAS
Fig. 12a - Unclamped Inductive Test Circuit
Fig. 12b - Unclamped Inductive Waveforms
EAS, Single Pulse Energy (mJ)
600
ID
4.0 A
5.7 A
Bottom 9.0 A
Top
500
400
300
200
100
VDD = 50 V
25
91032_12c
50
75
100
125
150
Starting TJ, Junction Temperature (°C)
Fig. 12c - Maximum Avalanche Energy vs. Drain Current
服务热线:400-655-8788
6
VBL1203M
www.VBsemi.com
Current regulator
Same type as D.U.T.
50 kΩ
QG
10 V
0.2 µF
12 V
0.3 µF
QGS
QGD
D.U.T.
VG
VDS
VGS
3 mA
Charge
IG
ID
Current sampling resistors
Fig. 13b - Gate Charge Test Circuit
Fig. 13a - Basic Gate Charge Waveform
Peak Diode Recovery dV/dt Test Circuit
D.U.T.
Circuit layout considerations
• Low stray inductance
• Ground plane
• Low leakage inductance
current transformer
Rg
dV/dt controlled by Rg
Driver same type as D.U.T.
ISD controlled by duty factor “D”
D.U.T. - device under test
VDD
Driver gate drive
P.W.
Period
D=
P.W.
Period
VGS = 10 Va
D.U.T. lSD waveform
Reverse
recovery
current
Body diode forward
current
dI/dt
D.U.T. VDS waveform
Diode recovery
dV/dt
Re-applied
voltage
Inductor current
VDD
Body diode forward drop
Ripple ≤ 5 %
ISD
Note
a. VGS = 5 V for logic level devices
Fig. 14 - For N-Channel
服务热线:400-655-8788
7
VBL1203M
www.VBsemi.com
TO-263AB (HIGH VOLTAGE)
A
(Datum A)
3
A
4
4
L1
B
A
E
c2
H
Gauge
plane
4
0° to 8°
5
D
B
Detail A
Seating plane
H
1
2
C
3
C
L
L3
L2
B
A1
L4
Detail “A”
Rotated 90° CW
scale 8:1
B
A
2 x b2
c
2xb
E
0.010 M A M B
± 0.004 M B
2xe
Plating
5
b1, b3
Base
metal
c1
(c)
D1
4
5
(b, b2)
Lead tip
MILLIMETERS
DIM.
MIN.
MAX.
4
E1
Section B - B and C - C
Scale: none
View A - A
MILLIMETERS
INCHES
MIN.
MAX.
DIM.
MIN.
INCHES
MAX.
MIN.
MAX.
A
4.06
4.83
0.160
0.190
D1
6.86
0.270
A1
0.00
0.25
0.000
0.010
E
9.65
10.67
0.380
0.420
6.22
0.245
b
0.51
0.99
0.020
0.039
E1
b1
0.51
0.89
0.020
0.035
e
b2
1.14
1.78
0.045
0.070
H
14.61
15.88
0.575
0.625
b3
1.14
1.73
0.045
0.068
L
1.78
2.79
0.070
0.110
2.54 BSC
0.100 BSC
c
0.38
0.74
0.015
0.029
L1
1.65
0.066
c1
0.38
0.58
0.015
0.023
L2
1.78
0.070
c2
1.14
1.65
0.045
0.065
L3
D
8.38
9.65
0.330
0.380
L4
0.25 BSC
4.78
5.28
0.010 BSC
0.188
0.208
ECN: S-82110-Rev. A, 15-Sep-08
DWG: 5970
Notes
1. Dimensioning and tolerancing per ASME Y14.5M-1994.
2. Dimensions are shown in millimeters (inches).
3. Dimension D and E do not include mold flash. Mold flash shall not exceed 0.127 mm (0.005") per side. These dimensions are measured at the
outmost extremes of the plastic body at datum A.
4. Thermal PAD contour optional within dimension E, L1, D1 and E1.
5. Dimension b1 and c1 apply to base metal only.
6. Datum A and B to be determined at datum plane H.
7. Outline conforms to JEDEC outline to TO-263AB.
服务热线:400-655-8788
8
VBL1203M
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
