MT9222WT-30BR5
MT9222WT-30BR5
    MAGNTEK(麦歌恩)
    SOP16_300mil
MT9222WT-30BR5 数据手册
MT9222 Fully Integrated, Hall Effect-Based Linear Current Sensor IC with 4.8 kV High-Isolation SOP-16 Wide Body Package 1 Product Description 2 Features The MagnTek® MT9222 product series is a fully integrated Hall Effect-based isolated linear current sensor device family designed for AC or DC current sensing in industrial, commercial, and communications systems. Each of the MT9222 consists of a precise, lowoffset, linear Hall circuit with a low-resistance current conductor path located near the surface of the die. Applied current flowing through this low-resistance current conductor path generates a magnetic field that the Hall IC converts into a proportional voltage. The current is sensed differentially in order to reject common-mode fields, improving accuracy in magnetically noisy environments. Device accuracy is optimized through the close proximity of the magnetic field to the Hall transducer. ■ ±0.5% Typical Linearity Over Temperature ■ Fast Output Response Time: 4 μs (typ.) ■ 150kHz Signal Bandwidth ■ 5.0V Single Supply Operation ■ -40℃~125℃ Operating Temperature ■ Primary Conductor Resistance ■ Output Voltage Proportional to AC or DC Current A precise, proportional voltage is provided by the lowoffset, chopper-stabilized BCD Hall IC, which has been accurately calibrated when it is manufactured. The output of the device has a positive slope (>VOQ) when an increasing current flows through the primary current conduction path (from pins 1,2,3 and 4, to pins 5,6,7 and 8). The internal resistance of this conductive path is 0.85 mΩ typical, providing low-power loss. The terminals of the conductive path are electrically isolated from the signal leads (pins 9 through 16). This allows the MT9222 current sensor IC to be used in high-side current sense applications without use other costly isolation techniques. ■ Ratiometric Output from Supply Voltage ■ Extremely Stable Quiescent Output Voltage ■ Device Bandwidth is Set via FILTER Pin ■ Near Zero Magnetic Hysteresis ■ Safety Parameters: (CB Certificate Number: DK-116879-UL) ---4.8kVrms 1min Dielectric Surge Isolation ---1097Vrms, 1550VDC or VPK Working Voltage ---7.5mm Clearance Distance ---8.2mm Creepage Distance ■ Package Option: The MT9222 family provides SOP-16W package to customers, The package is RoHS compliant. ■ ---0.85mΩ ■ Sensing Current Range: (AC or DC) ---±20A, ±25A, ±30A, ±50A, ±65A ---+40A, +50A ---SOP-16W RoHS Compliant: (EU)2015/863 3 Applications ■ Low-power inverter current sensing ■ Motor phase and rail current sensing ■ PV String Inverters ■ Chargers and Converters ■ Switching Power Supplies ■ Overcurrent Protection ■ UPS Power 4 Product Overview of MT9222 CB Certificate Number: DK-116879-UL Not to scale magntek.com.cn | Magnetic Tech Makes Magic Change 1 Part No. Description MT9222WT SOP-16W Tape & Reel (1000 pcs/bag) Rev 1.0 MT9222 Fully Integrated, Hall Effect-Based Linear Current Sensor IC with 4.8 kV High-Isolation SOP-16 wide Body Package Table of Contents 1 Product Description………...…….……………….……...…………………………………….…….………1 2 Features……………………………….……..……………………………………………………………….…….1 3 Applications……………………………………………………………………………………………………….1 4 Product Overview of MT9222…………………………………………………………………………….1 5 Functional Block Diagram …………………………………………………….………………….3 6 Pin Configuration and Function…..……………………………………………………………………..3 7 Naming Specification.………………………….…………………………………………………………….4 8 Selection Guide………………………………………………………………………………………………….4 9 Output Voltage vs. Input Current.………………………………………………………………………5 10 Typical Application Circuit………...…………………………………………………………………….....5 11 Electrical and Magnetic Characteristics………………………………………………………………6 11.1 Absolute Maximum Ratings………………….…………………………………………………………….6 11.2 Isolation and Package Characteristics…..……………………………………………………………..6 11.3 Life Time Characteristics………………….…..……………………………………………………………..6 11.4 ESD Rating……………………….…………………………………………………………………………………7 11.5 Electrical Characteristics…...………………………………………………………………………7 11.6 Accuracy Specifications…………….………..…………………………………………………………….8 12 Characteristic Definitions……….…………………………………………………………………………12 13 Package Material Information…………………………………………………………………………15 13.1 SOP-16W Package Information…………………………………………………………..15 14 Copy Rights and Disclaimer………………………………………………………………………..……..16 1 2 Originally Version 1.0 Version Reversion History magntek.com.cn | Magnetic Tech Makes Magic Change Update Logo and UL CB Certificate Number 2 Rev 1.0 MT9222 Fully Integrated, Hall Effect-Based Linear Current Sensor IC with 4.8 kV High-Isolation SOP-16 wide Body Package 5 Functional Block Diagram Figure.1 Functional Block Diagram 6 Pin Configuration and Functions Top View No. Name Description 1, 2, 3, 4 IP+ Input Current Positive Pin IP+ 1 16 NC 5, 6, 7, 8 IP- Input Current Negative Pin IP+ 2 15 GND 9 NC No Internal Connection IP+ 3 14 NC 10 VCC Power Supply IP+ 4 13 FILTER 11 NC No Internal Connection IP- 5 12 VOUT 12 VOUT Analog Output Signal IP- 6 11 NC IP- 7 10 VCC 13 FILTER Filter Pin to Set Bandwidth IP- 8 9 NC 14 NC No Internal Connection 15 GND Signal Ground 16 NC No Internal Connection Figure.2 Pin Configuration & Functions (SOP-16W) magntek.com.cn | Magnetic Tech Makes Magic Change 3 Rev 1.0 MT9222 Fully Integrated, Hall Effect-Based Linear Current Sensor IC with 4.8 kV High-Isolation SOP-16 wide Body Package 7 Naming Specification Part Number MT9222 WT 50 B R 5 ❶ ❷ ❸ ❹ ❺ ❻ ❹ Current Polarity ❶ Series Name ❷ Package Type Type Package Type WT SOP-16W Type Current Polarity B Bidirectional---AC Current U Unidirectional---DC Current ❺ Output Mode ❸ Input Current Range Type Input Current Range 20 Full scale sensing range: 20A 25 Full scale sensing range: 25A 30 Full scale sensing range: 30A 40 Full scale sensing range: 40A 50 Full scale sensing range: 50A 65 Full scale sensing range: 65A Type Output Mode R Ratiometry output ❻ Power Supply Type Power Supply 5 VCC=5V 8 Selection Guide Current Range (A) VCC (V) Sensitivity (mV/A) Package Qty per Reel (pcs) MT9222WT-40UR5 +40 5 100 SOP-16W 1000 MT9222WT-50UR5 +50 5 80 SOP-16W 1000 MT9222WT-20BR5 ±20 5 100 SOP-16W 1000 MT9222WT-25BR5 ±25 5 80 SOP-16W 1000 MT9222WT-30BR5 ±30 5 66.7 SOP-16W 1000 MT9222WT-50BR5 ±50 5 40 SOP-16W 1000 MT9222WT-65BR5 ±65 5 30.8 SOP-16W 1000 Ordering Part Number magntek.com.cn | Magnetic Tech Makes Magic Change 4 Rev 1.0 MT9222 Fully Integrated, Hall Effect-Based Linear Current Sensor IC with 4.8 kV High-Isolation SOP-16 wide Body Package 3.5 2.5 Output Voltage (V) 3.5 1.5 2.5 1.5 0.5 0.5 Output Voltage (V) 4.5 4.5 9 Output Voltage vs. Input Current 0 10 20 30 40 50 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 Input Current (A) Figure.3 Input Current (A) Output Voltage vs. Input Current 10 Typical Application Circuit The typical application circuits of MT9222 series products include a bypass capacitor (CBYPASS capacitor between VCC and GND is necessary) and a filter capacitor as an additional external components. On the input side, pins 1,2,3 and 4 are shorted together, pins 5,6,7 and 8 are shorted together. The analog signal output is measured directly from the VOUT pin. The signal is proportional to the IP of the primary sensing current of AC or DC within the specified measurement range. The FILTER pin can be used to reduce bandwidth to optimize noise performance, but at the same time proportionally increase response time. CFILTER Recommends “Open”, and the response time is the fastest. VCC ADC IP+ IP- IP+ IP+ IP+ IP+ NC GND NC Filter IPIPIPIP- VOUT NC VCC NC CBYPASS CFILTER CLOAD GND 0.1uF 1nF VIN VREF fc=1/(2*π*RF*CFILTER) RF=1.8KΩ Figure.4 Typical Application Circuit magntek.com.cn | Magnetic Tech Makes Magic Change 5 Rev 1.0 MT9222 Fully Integrated, Hall Effect-Based Linear Current Sensor IC with 4.8 kV High-Isolation SOP-16 wide Body Package 11 Electrical Magnetic Characteristics 11.1 Absolute Maximum Ratings Absolute maximum ratings are limited values to be applied individually, and beyond which the serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to absolute maximum rating conditions for an extended period of time may affect device reliability. Symbol Parameters Min Max Units VCC Supply Voltage - 6 V VRCC Reverse Battery Voltage -0.1 - V VOUT Output Voltage - VCC+0.5 V VROUT Reverse Output Voltage -0.1 - V IOUT(source) Continuous Output Current - 80 mA IOUT(sink) Continuous Output Current - 40 mA TA Operating Ambient Temperature -40 125 ℃ TS Storage Temperature -50 150 ℃ TJ Junction Temperature - 175 ℃ 11.2 Isolation and Package Characteristics Symbol Parameters Test Conditions Value Units VSURGE Dielectric Surge Strength Test Voltage Tested ±5 pulses at 30 seconds in compliance to IEC 61000-4-5 1.2 / 50 μs (width). 10000 V ISURGE Surge Current Tested ±5 pulses at 30 seconds in compliance to IEC 61000-4-5 8 / 20 μs (width). 13000 A VISO Dielectric Strength Test Voltage Test method per UL standard 60950-1 (edition 2). VTEST = VISO, t = 60 s (qualification); VTEST = 1.2 × VISO, t = 1 s (100% production) 4800 Vrms VIOWM Maximum Working Isolation Voltage Maximum working voltage for Basic isolation according to UL60950-1 1550 VPK or VDC 1097 Vrms CTI Comparative Tracking Index Comparative tracking index according to IEC60112:2009 600 V DCL External Clearance Measured from input terminals to output terminals, shortest distance through air. 7.5 mm DCR External Creepage Measured from input terminals to output terminals, shortest distance path along body. 8.2 mm 11.3 Life Time Characteristics Symbol Parameters Test Condition Min Typ Max Unit ESNST_DRIFT Sensitivity Error Lifetime Drift TA=-40~125℃ - ±3 - % ETOT_DRIFT Total Output Error Lifetime Drift TA=-40~125℃ - ±3 - % * Based on characterization data obtained during AEC-Q100 stress testing. magntek.com.cn | Magnetic Tech Makes Magic Change 6 Rev 1.0 MT9222 Fully Integrated, Hall Effect-Based Linear Current Sensor IC with 4.8 kV High-Isolation SOP-16 wide Body Package 11.4 ESD Ratings Parameters Reference Grade Human-body model (HBM) AEC-Q100-002 Class IIIA Charged-device model (CDM) AEC-Q100-011 Class C3 Latch up AEC-Q100-004 Class IIA 11.5 Electrical Specifications At TA =-40~125 ℃, VCC=5V (unless otherwise specified) Symbol Parameters Test Condition Min Typ Max Unit VCC Supply Voltage - 4.5 5 5.5 V ICC Supply Current TA = 25°C - 14 20 mA RIP Primary Conductor Resistance TA = 25°C - 0.85 - mΩ BW Internal Bandwidth Small signal –3 dB; CL = 1 nF - 150 - KHz TPO Power on time TA = 25°C, CL = 1nF, IP=IPR(max) applied - 190 - us TR Rise time IP = IPR(max), A = 25°C, CL = 1nF - 3 - us TPD Propagation Delay IP = IPR(max), TA = 25°C, CL = 1nF - 2 - us TRESP Response Time IP = IPR(max), TA = 25°C, CL = 1nF - 4 5 us VOL Analog Output Low Saturation Level RL>=4.7KΩ - - 0.3 V VOH Analog Output High Saturation Level RL>=4.7KΩ VCC-0.3 - - V CL Output CAP Load OUT to GND - 1 10 nF ROUT DC Output resistance - - 5 Ω RL Output RES Load OUT to GND 4.7 - - KΩ OUT to VCC 4.7 - - KΩ RF(int) Internal filter resistance - 1.8 - KΩ IND Noise Density Input-referenced noise density; TA = 25°C, CL = 1 nF - 450 - uA/√Hz ELIN Nonlinearity error Through full range of IP -1.5 - 1.5 % ERAT_SNST Ratiometry Sensitivity Error VCC = 4.5 to 5.5 V, TA = 25°C - ±1.5 - % ERAT_VOQ Ratiometry Quiescent Voltage Output Error VCC = 4.5 to 5.5 V, TA = 25°C - ±1 - % * Device may be operated at higher primary current levels, ambient temperatures, and internal leadframe temperatures, provided the Maximum Junction Temperature, is not exceeded. Continued on the next page… magntek.com.cn | Magnetic Tech Makes Magic Change 7 Rev 1.0 MT9222 Fully Integrated, Hall Effect-Based Linear Current Sensor IC with 4.8 kV High-Isolation SOP-16 wide Body Package Electrical Specifications (continued) At TA =-40~125 ℃, VCC=5V (unless otherwise specified) Symbol Parameters Test Condition Min Typ Max Unit CMFRR Common Mode Field Rejection Ratio Uniform external magnetic field - 40 - dB SNST(match) Hall Plate Sensitivity Matching TA = 25°C ±1 - % VPORH Power-On Reset High Voltage TA = 25°C, VCC rising 3.75 4 4.25 V VPORL Power-On Reset Low Voltage TA = 25°C, VCC falling - 3.5 - V VPORHYS Power-On Reset Hysteresis TA = 25°C - 0.5 - V TPORR Power-On Reset Release Time TA = 25°C, VCC rising - 30 - us TPORA Power-On Reset Analog Delay TA = 25°C, VCC rising - 5 - us ISCLP Source Current of Over-CurrentLimit - - 80 - mA ISCLN Sink Current of Over-CurrentLimit - - 40 - mA TSCLD Detect Time for Over-CurrentLimit TA = 25°C, IOUT>ISCLP or IOUT
MT9222WT-30BR5 价格&库存
很抱歉,暂时无法提供与“MT9222WT-30BR5”相匹配的价格&库存,您可以联系我们找货
