Preliminary Datasheet SLM2003E
200V Half-Bridge Driver
PRODUCT SUMMARY
VOFFSET
IO+/- (min.)
VOUT
ton/off (typ.)
Deadtime (typ.)
FEATURES
200 V max.
130mA/270mA
10 V - 18 V
125 ns/125 ns
500 ns
Floating channel designed for bootstrap
operation
Fully operational to +200 V
Tolerant to negative transient voltage, dV/dt
immune
Gate drive supply range from 10 V to 18 V
Under-voltage lockout
3.3 V, 5 V logic compatible
Cross-conduction prevention logic
Matched propagation delay for both channels
Internal set deadtime
High-side output in phase with HIN input
Low-side output out of phase with LIN input
RoHS compliant
SOP8 package
GENERAL DESCRIPTION
The SLM2003E is a high voltage, high speed power
MOSFET and IGBT drivers with dependent high- and
low-side referenced output channels. Proprietary
HVIC and latch immune CMOS technologies enable
ruggedized monolithic construction. The logic input is
compatible with standard CMOS or LSTTL output,
down to 3.3 V logic. The output drivers feature a high
pulse current buffer stage designed for minimum
driver cross conduction. The floating channel can be
used to drive an N-channel power MOSFET in the
high-side configuration which operates up to 200 V.
TYPICAL APPLICATION CIRCUIT
up to 200V
VCC
VCC
VB
HIN
HIN
HO
LIN
LIN
VS
COM
LO
to
load
SLM2003E
(Refer to Pin Configuration for correct configuration. This diagram shows electrical connections only.)
Sillumin Semiconductor Co., Ltd. – www.sillumin.com
Rev0.2 May 2022
1
Table of Contents
Product Summary .......................................................................................................................................................1
General Description ....................................................................................................................................................1
Features ......................................................................................................................................................................1
Typical Application Circuit ...........................................................................................................................................1
PIN Configuration........................................................................................................................................................3
PIN Description ...........................................................................................................................................................3
Ordering Information ...................................................................................................................................................3
Functional Block Diagram ...........................................................................................................................................4
Absolute Maximum Ratings ........................................................................................................................................5
Recommended Operation Conditions ........................................................................................................................5
Dynamic Electrical Characteristics ..............................................................................................................................6
Static Electrical Characteristics ...................................................................................................................................6
Package Case Outlines ..............................................................................................................................................8
Revision History ..........................................................................................................................................................9
Rev0.2 May 2022
2
PIN CONFIGURATION
Package
Pin Configuration (Top View)
1
VCC
VB
8
2
HIN
HO
7
3
LIN
VS
6
4
COM
LO
5
SOP8
PIN DESCRIPTION
No.
Pin
Description
1
VCC
Low-side and logic fixed supply
2
HIN
Logic input for high-side gate driver output (HO), in phase
3
Logic input for low-side gate driver output (LO), out of phase
4
LIN
COM
5
LO
Low-side gate drive output
6
VS
High-side floating supply return
7
HO
High-side gate drive output
8
VB
Low-side return
ORDERING INFORMATION
Industrial Range: -40°C to +125°C
Order Part No.
Package
QTY
SLM2003ECA-DG
SOP8, Pb-Free
2500/Reel
Rev0.2 May 2022
3
FUNCTIONAL BLOCK DIAGRAM
VB
UV
DETECT
R
Pulse
Filter
HIN
S
Pulse
Gen
VCC
Dead time &
Shoot-Through
Prevention
R
Q
HO
VS
VCC
UVLO
VCC
LO
LIN
COM
Rev0.2 May 2022
4
ABSOLUTE MAXIMUM RATINGS
Symbol
Definition
Min.
Max.
-0.3
220
Units
VB
High-side floating absolute voltage
VS
High-side floating supply offset voltage
VB - 20
VB + 0.3
VHO
High-side floating output voltage
VS - 0.3
VB + 0.3
VCC
Low-side and logic fixed supply voltage
-0.3
VLO
Low-side output voltage
-0.3
VCC + 0.3
VIN
Logic input voltage (HIN & LIN )
-0.3
10
Allowable offset supply voltage transient
50
V/ns
PD
Package power dissipation at TA ≤ +25°C
0.625
W
θJA
Thermal resistance, junction to ambient
200
°C/W
TJ
Junction temperature
150
TS
Storage temperature
-55
150
TL
Lead temperature (soldering, 10 seconds)
300
dVS/dt
V
°C
Note: Absolute maximum ratings indicate sustained limits beyond which damage to the device may occur. All
voltage parameters are absolute voltages referenced to COM. The thermal resistance and power dissipation
ratings are measured under board mounted and still air conditions.
RECOMMENDED OPERATION CONDITIONS
Symbol
Definition
Min.
Max.
VS + 10
VS + 18
VB
VS
VHO
VS
VB
VCC
10
18
VLO
VCC
VIN
TA
Ambient temperature
- 40
125
Units
200
V
°C
Note: For proper operation the device should be used within the recommended conditions. The VS offset rating is
tested with all supplies biased at a 15 V differential.
Rev0.2 May 2022
5
DYNAMIC ELECTRICAL CHARACTERISTICS
VBIAS (VCC, VBS) = 15 V, CL = 1000 pF and TA = 25°C unless otherwise specified.
Symbol
Parameter
Condition
Min.
Typ.
Max.
ton
Turn-on propagation delay
VS = 0 V
125
200
toff
Turn-off propagation delay
VS = 0 V
125
200
tr
Turn-on rise time
70
100
tf
Turn-off fall time
25
40
DT
Deadtime, LS turn-off to HS turn-on &
HS turn-on to LS turn-off
500
MT
Delay matching, HS & LS turn-on/off
60
Unit
ns
Note: See timing diagram in Figure 1, Figure 2,Figure 3 and Figure 4.
STATIC ELECTRICAL CHARACTERISTICS
VBIAS (VCC, VBS) = 15 V and TA = 25°C unless otherwise specified. The VIN, VTH, and IIN parameters are referenced
to COM. The VO and IO parameters are referenced to COM and are applicable to the respective output leads: HO
or LO.
Symbol
Parameter
VIH
Logic “1” (HIN) & Logic “0” ( LIN ) input
voltage
VIL
VOH
Condition
Min.
Typ.
Max.
2.5
Logic “0” (HIN) & Logic “1” ( LIN ) input
voltage
0.8
High level output voltage, VBIAS - VO
0.4
0.6
0.13
0.2
50
105
160
245
390
Unit
VCC = 10 V to 18V
V
IO = 20 mA
VOL
Low level output voltage, VO
ILK
Offset supply leakage current
IQBS
Quiescent VBS supply current
VB = VS = 200 V
Vo = 0 V
IQCC
Quiescent VCC supply current
Logic “1” input bias current on HIN
HIN = 5 V
100
150
Logic “1” input bias current on LIN
LIN = 0 V
80
Logic “0” input bias current on HIN
HIN = 0 V
5
Logic “0” input bias current on LIN
LIN = 5 V
-80
8
8.6
9.5
µA
IIN+
IIN-
VCCUV+
VCC supply under-voltage positive going
threshold
Rev0.2 May 2022
V
6
Symbol
Parameter
Condition
Min.
Typ.
Max.
7.6
8.2
9
VCCUV-
going threshold
negative
VBSUV+
VBS supply under-voltage positive going
threshold
8.6
VBSUV-
going threshold
7.9
negative
Unit
VO = 0 V, VIN = VIH
IO+
Output high short circuit pulsed current
130
PW ≤ 10 µs
290
mA
VO = 15 V, VIN = VIL
IO-
Output low short circuit pulsed current
270
PW ≤ 10 µs
HIN
600
50%
50%
HIN
LIN
tr
ton
tf
toff
HO
90%
HO
90%
10%
10%
LO
Figure 1. Input/Output Timing Diagram
HIN
Figure 2. High Side Switching Time Waveform
LIN
50%
50%
50%
50%
LIN
90%
ton
HO
DT
LO
tr
tf
toff
10%
DT
90%
90%
90%
LO
10%
10%
10%
Figure 3. Dead Time Waveform
Rev0.2 May 2022
Figure 4. Low Side Switching Time Waveform
7
PACKAGE CASE OUTLINES
Figure 5. SOP8 Outline Dimensions
Rev0.2 May 2022
8
REVISION HISTORY
Note: page numbers for previous revisions may differ from page numbers in current version
Page or Item
Subjects (major changes since previous revision)
Rev 0.1 preliminary datasheet 2021-10-29
Whole document
Rev 0.1 preliminary datasheet release
Rev 0.2 preliminary datasheet 2022-05-09
Whole document
Rev 0.2 preliminary datasheet release
Rev0.2 May 2022
9
很抱歉,暂时无法提供与“SLM2003ECA-DG”相匹配的价格&库存,您可以联系我们找货
