VIS30040
VIS30040
    VOLTAIC(沃达科)
    TO252
VIS30040 数据手册
VIS30040 30V N-Channel Power Trench MOSFET General Description Product Summary • Trench Power MOSFET Technology VDS • Low RDS(ON) ID (at VGS=10V) 90A • Optimized for High Reliable Switch Application RDS(ON) (at VGS=10V, typ) 4.1mΩ • High Current Capability RDS(ON) (at VGS=4.5V, typ) 5.4mΩ 30V • RoHS and Halogen-Free Compliant Applications • Motor Drive 100% UIS Tested • Load Switch 100% RG Tested • Battery Protection • General DC/DC Converters D TO-252 Top View Bottom View D D S G G G S S Orderable Part Number Package Type Form Minimum Order Quantity VIS30040 TO-252 Tape & Reel 2500 Absolute Maximum Ratings TA=25°C unless otherwise noted Parameter Symbol Drain-Source Voltage Gate-Source Voltage TC=25°C Continuous Drain Current (5) Pulsed Drain Current Continuous Drain Current (3) VDS 30 V VGS ±20 V 90 A 66 A 230 A 30 A 19 A 33.3 IDM TA=25°C IDSM TA=100°C IAS Avalanche Energy L=0.1mH Power Dissipation (1) Units ID TC=100°C Avalanche Current (3) Power Dissipation (2) Maximum (3) EAS TC=25°C PD TC=100°C TA=25°C PDSM TA=100°C Junction and Storage Temperature Range TJ, TSTG 55 A mJ 83.3 W 33.3 W 6.25 W 2.5 W °C -55 to 150 Thermal Characteristics Parameter Maximum Junction-to-Ambient Symbol (1) t ≤ 10s Maximum Junction-to-Ambient (1,4) Steady-State Maximum Junction-to-Case Steady-State Rev0.93 (03/2021) RθJA RθJC Typ Max Units 16 20 °C/W 41 50 °C/W 1.2 1.5 °C/W Voltaic Semiconductor Confidential and Proprietary Information 1 VIS30040 30V N-Channel Power Trench MOSFET Electrical Characteristics (TJ=25°C unless otherwise noted) Symbol Parameter Conditions Min Typ Max Units STATIC PARAMETERS BVDSS Drain-Source Breakdown Voltage ID=250µA, VGS=0V IDSS Zero Gate Voltage Drain Current IGSS Gate-Body leakage current VDS=0V, VGS=±20V VGS(th) Gate Threshold Voltage VDS=VGS, ID=250µA V VDS=30V, VGS=0V 1 TJ=55°C VGS=10V, ID=20A RDS(ON) 30 Static Drain-Source On-Resistance TJ=125° VGS=4.5V, ID=20A 5 1.4 μA ±100 nA 1.8 2.2 V 4.1 4.9 5.8 5.4 mΩ 7.3 gFS Forward Transconductance VDS=5V, ID=20A 71 S VSD Diode Forward Voltage IS=1A, VGS=0V 0.71 V IS Maximum Body-Diode Continuous Current 81 A DYNAMIC PARAMETERS Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Rg Gate resistance VGS=0V, VDS=15V, f=1MHz f=1MHz 2366 pF 350 pF 225 pF 0.6 Ω 45.5 nC 21.6 nC 9.7 nC SWITCHING PARAMETERS Qg(10V) Total Gate Charge Qg(4.5V) Total Gate Charge Qgs Gate Source Charge Qgd Gate Drain Charge 9.4 nC tD(on) Turn-On Delay Time 12.3 ns tr Turn-On Rise Time tD(off) Turn-Off Delay Time tf Turn-Off Fall Time trr Body Diode Reverse Recovery Time IF=20A, di/dt=200A/μs 6.8 ns Qrr Body Diode Reverse Recovery Charge IF=20A, di/dt=200A/μs 10.2 nC 1) 2) 3) 4) 5) VGS=10V, VDS=15V, ID=20A VGS=10V, VDS=15V, RL=0.75Ω, RGEN=3Ω 9.4 ns 28.5 ns 9.8 ns 2 RθJA is measured with the device mounted on 1in FR-4 board with 2oz. Copper, in a still air environment with TA =25°C. The Power dissipation PDSM is based on RθJA t≤ 10s and the maximum allowed junction temperature of 150°C. The value in any given application depends on the user's specific board design. The power dissipation PD is based on TJ(MAX)=150°C, using junction-to-case thermal resistance, and is more useful in setting the upper dissipation limit for cases where additional heatsinking is used. Single pulse width limited by junction temperature TJ(MAX)=150°C. RθJA is the sum of the thermal impedance from junction to case RθJC and case to ambient. The maximum current rating is package limited. Rev0.93 (03/2021) Voltaic Semiconductor Confidential and Proprietary Information 2 VIS30040 30V N-Channel Power Trench MOSFET TYPICAL ELECTRICAL AND THERMAL CHARACTERISTICS 150.00 100 4.5V 125.00 VDS=5V 80 7V 60 3.5V 10V ID (A) ID (A) 100.00 75.00 40 TJ=150°C 50.00 3V TJ=25°C 20 25.00 VGS=2.5V 0.00 0 0.00 1.00 2.00 3.00 4.00 5.00 0.0 1.0 2.0 VDS (V) 4.0 5.0 Fig 2. Typical Transfer Characteristics 1.600 4000 1.500 3500 1.400 Capacitance (pF) Normalized On-Resistance Fig 1. Typical Output Characteristics VGS=4.5V ID=20A 1.300 3.0 VGS (V) 1.200 1.100 VGS=10V ID=20A 1.000 3000 Ciss 2500 2000 1500 Coss Crss 1000 0.900 500 0.800 0 25 50 75 100 125 0 150 0 5 10 TJ, Junction Temperature (℃) 15 20 25 30 1 1.2 VDS (V) Fig 3. Normalized On-Resistance vs. Temperature Fig 4. Typical Capacitance vs. VDS 10 1000 9 8 100 TJ=150°C 6 IS(A) VGS(V) 7 5 TJ=25°C 10 4 3 1 2 1 0 0.1 0 10 20 30 40 50 0 0.2 0.4 Qg(nC) Fig 5. Typical Gate Charge vs. VGS Rev0.93 (03/2021) 0.6 0.8 VSD(V) Fig 6. Typical Source-Drain Diode Forward Voltage Voltaic Semiconductor Confidential and Proprietary Information 3 VIS30040 30V N-Channel Power Trench MOSFET TYPICAL ELECTRICAL AND THERMAL CHARACTERISTICS 1000 100 100 10μs RDS(ON) limited ID (A) 100μs 10 TJ(MAX)=150℃ 1ms 10ms DC TC=25℃ 1 Current Rating ID (A) 90 80 70 60 50 40 30 20 10 0 0.1 0.01 0.1 1 10 0 100 25 50 VDS(V) Fig 7. Maximum Safe Operating Area ZθJC Normalized Transient Thermal Resistance 100 125 150 Fig 8. Maximum Drain Current vs. Case Temperature 10 1 75 TCASE (℃) In descending order D=0.5, 0.3, 0.1, 0.05, 0.02, 0.01, 0.005, single pulse D=Ton/T TJ,PK=TA+PDM∙ZθJC∙RθJC RθJC=1.5℃/W 0.1 PD 0.01 TON T 0.001 0.00001 0.0001 0.001 0.01 0.1 1 10 Pulse Width (s) Fig 9. Normalized Maximum Transient Thermal Impedance, Junction-to-Case ZθJA Normalized Transient Thermal Resistance 10 1 In descending order D=0.5, 0.3, 0.1, 0.05, 0.02, 0.01, 0.005, single pulse D=Ton/T TJ,PK=TA+PDM∙ZθJA∙RθJA RθJA=50℃/W 0.1 PD 0.01 TON T 0.001 0.001 0.01 0.1 1 10 100 1000 Pulse Width (s) Fig 10. Normalized Maximum Transient Thermal Impedance, Junction-to-Ambient Rev0.93 (03/2021) Voltaic Semiconductor Confidential and Proprietary Information 4 VIS30040 30V N-Channel Power Trench MOSFET TYPICAL ELECTRICAL AND THERMAL CHARACTERISTICS 1000 10000 TJ(MAX)=150℃ 800 TA=25℃ 1000 Power (W) Power (W) TJ(MAX)=150℃ TC=25℃ 600 400 100 10 200 0 0.00001 0.0001 0.001 0.01 0.1 1 1 0.00001 10 0.001 Pulse Width (s) 0.1 10 Fig 11. Single Pulse Power Rating Junction-to-Case Fig 12. Single Pulse Power Rating Junction-to-Ambient 90 15.00 ID=20A 80 12.50 70 60 RDSON (mΩ) Power Dissipation (W) 1000 Pulse Width (s) 50 40 30 10.00 7.50 150℃ 5.00 20 25℃ 2.50 10 0 0 25 50 75 100 125 150 0.00 2.0 4.0 TCASE (℃) 6.0 8.0 10.0 VGS (V) Fig 13. Maximum Power Rating vs. Temperature Fig 14. On-Resistance vs. VGS 8 RDSON (mΩ) 7 VGS=4.5V 6 5 4 VGS=10V 3 2 0 10 20 30 40 50 60 ID (A) Fig 15. On-Resistance vs. Drain Current Rev0.93 (03/2021) Voltaic Semiconductor Confidential and Proprietary Information 5 VIS30040 30V N-Channel Power Trench MOSFET TEST CIRCUIT BV DSS VDS L IAS + VDD DUT IAS Fig16. Unclamped Inductive Test Circuit Fig17. Unclamped Inductive Waveform VDS Qg VGS 10V L DUT VCC Qg s Fig18. Qg Test Circuit Qgd Fig19. Qg Waveform RL VDS 90% + VGS RG DUT VDD 10% tr td (on ) td(off) to n Fig18. Resistive Switching Test Circuit Rev0.93 (03/2021) tf to ff Fig19. Switching Time Waveform Voltaic Semiconductor Confidential and Proprietary Information 6 VIS30040 30V N-Channel Power Trench MOSFET TEST CIRCUIT VDS+ VG S DUT VDS- L ISD ISD IF dI/ dt + VGS VDD trr VD D VD S Fig20. Diode Recovery Test Circuit Fig21. Diode Recovery Test Waveform TO-252 OUTLINE a1 D B d1 c A DIM d2 d3 SYMBOL a2 L K c c b3 Rev0.93 (03/2021) MIN [mm] MAX [mm] A 6.50 6.70 B 2.30 2.50 C a3 b1 b2 MILLIMITERS b4 5° D 5.50 a1 5.20 5.70 5.40 a2 2.30 a3 2.30 b1 0.52 b2 0.50 b3 0.60 0.80 b4 1.80 2.00 L 8.80 9.20 K 7.00 7.40 d1 1.15 1.35 d2 0.45 0.85 d3 2.45 2.85 Voltaic Semiconductor Confidential and Proprietary Information 7
VIS30040 价格&库存
很抱歉,暂时无法提供与“VIS30040”相匹配的价格&库存,您可以联系我们找货
