DSR1M
DSR1M
    JUXING(钜兴)
    SOD-123FL-2
    二极管配置:独立式;直流反向耐压(Vr):1kV;平均整流电流(Io):1A;正向压降(Vf):1.1V@1A;
DSR1M 数据手册
DSR1A THRU DSR1M Surface Mount Standard Rectifiers Reverse Voltage - 50 to 1000 V PINNING Forward Current - 1 A PIN FEATURES ▪For surface mounted applications ▪Low profile package ▪Glass Passivated Chip Juntion ▪Ideal for automated placement ▪Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code: S1A-S1M Simplified outline SOD-123FL and symbol MECHANICAL DATA ▪Case: SOD-123FL ▪Terminals: Solderable per MIL-STD-750, Method 2026 ▪Approx. Weight:15mg 0.00048oz Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols DSR1A DSR1B DSR1D DSR1G DSR1J DSR1K DSR1M Units Parameter Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at Ta = 65 °C I F(AV) 1 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) I FSM 30 A Maximum Instantaneous Forward Voltage at 1 A VF 1.1 V IR 5 50 μA Cj 8 pF RθJA 60 °C/W T j , T stg -55 ~ +150 °C Maximum DC Reverse Current at Rated DC Blocking Voltage Typical Junction Capacitance Typical Thermal Resistance Ta = 25 °C Ta =125 °C 1) 2) Operating and Storage Temperature Range 1)Measured at 1 MHz and applied reverse voltage of 4 V D.C 2)P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas. version: 02 http://www.trr-jx.com DSR1A THRU DSR1M Surface Mount Standard Rectifiers Characteristic Curves (TA=25 ℃ unless otherwise noted) Fig.2 Typical Instaneous Reverse Characteristics Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current ( μ A) Fig.1 Forward Current Derating Curve 100 T J =150°C T J =125°C 10 T J =100°C 1.0 T J =75°C T J =50°C 0.1 T J =25°C 0.01 Case Temperature (°C) 800 Fig.4 Typical Junction Capacitance 1.0 Junction Capacitance ( pF) 12 2 5° C TJ = °C 00 TJ =1 =1 50 °C 0.5 TJ Instaneous Forward Current (A) 600 Instaneous Reverse Voltage (V) Fig.3 Typical Forward Characteristic 0.2 0.1 0.6 0.7 0.8 0.9 1.0 Instaneous Forward Voltage (V) version: 02 400 200 0 http://www.trr-jx.com 1.1 10 8 6 4 2 0 0 5 10 15 20 25 30 Reverse Voltage (V) 35 40 DSR1A THRU DSR1M Surface Mount Standard Rectifiers PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123FL ∠ALL ROUND C A ∠ALL ROUND HE VM g Top View mil Bottom View A C D E e g HE max 1.30 0.20 2.9 1.95 1.1 0.9 3.8 min 1.00 0.12 2.6 1.60 0.7 0.7 3.5 max 51.2 7.9 114 77 43 35 150 min 39.4 4.7 102 63 31 27.6 138 UNIT mm g pad e E A pad D E A 7° The recommended mounting pad size Marking Type number 2.0 (79) 1.2 (47) 1.2 (47) 1.2 (47) Unit: mm (mil) version: 02 ∠ http://www.trr-jx.com Marking code DSR1A S1A DSR1B S1B DSR1D S1D DSR1G S1G DSR1J S1J DSR1K S1K DSR1M S1M
DSR1M 价格&库存
很抱歉,暂时无法提供与“DSR1M”相匹配的价格&库存,您可以联系我们找货
