AOD407-MS
AOD407-MS
    MSKSEMI(美森科)
    TO252
    类型:P沟道;漏源电压(Vdss):60V;连续漏极电流(Id):14A;功率(Pd):20W;
AOD407-MS 数据手册
www.msksemi.com AOD407-MS Semiconductor TO252 Pin Configuration Compiance Features  -60V,-14A, RDS(ON) =68mΩ@VGS = -10V D S G  Improved dv/dt capability  Fast switching  100% EAS Guaranteed  Green Device Available Applications D  Motor Drive  Power Tools  LED Lighting G S Absolute Maximum Ratings VGS ID RDSON ID -60V 55m -14A Tc=25℃ unless otherwise noted Symbol VDS BVDSS Parameter Rating Units Drain-Source Voltage -60 V Gate-Source Voltage ±20 V Drain Current – Continuous (TC=25℃) -14 A Drain Current – Continuous (TC=100℃) -8 A Pulsed1 -52 A 31 mJ -25 A IDM Drain Current – EAS Single Pulse Avalanche Energy IAS Single Pulse Avalanche Current 2 2 Power Dissipation (TC=25℃) PD Power Dissipation – Derate above 25℃ 20 W 0.16 W/℃ TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ Thermal Characteristics Symbol Parameter Typ. Max. Unit RθJA Thermal Resistance Junction to ambient --- 62 ℃/W RθJC Thermal Resistance Junction to Case --- 6.1 ℃/W www.msksemi.com AOD407-MS Semiconductor Compiance Electrical Characteristics (TJ=25 ℃, unless otherwise noted) Off Characteristics Symbol BVDSS Parameter Drain-Source Breakdown Voltage △BVDSS/△TJ BVDSS Temperature Coefficient IDSS Drain-Source Leakage Current IGSS Gate-Source Leakage Current Conditions Min. Typ. Max. Unit VGS=0V , ID=-250uA -60 --- --- V Reference to 25℃ , ID=-1mA --- -0.05 --- V/℃ VDS=-60V , VGS=0V , TJ=25℃ --- --- -1 uA VDS=-48V , VGS=0V , TJ=125℃ --- --- -10 uA VGS=±20V , VDS=0V --- --- ±100 nA VGS=-10V , ID=-6A --- 55 65 m VGS=-4.5V , ID=-3A --- 65 80 m -1.0 -1.5 -2.5 V --- 5 --- mV/℃ --- 8.5 --- S --- 16.4 --- 2.8 --- 3.6 On Characteristics RDS(ON) Static Drain-Source On-Resistance VGS(th) Gate Threshold Voltage △VGS(th) gfs VGS(th) Temperature Coefficient Forward Transconductance VGS=VDS , ID=-250uA VDS=-10V , ID=-6A Dynamic and switching Characteristics Qg Total Gate Charge3 , 4 Qgs Gate-Source Charge3 , 4 Qgd Td(on) Gate-Drain VDS=-30V , VGS=-10V , ID=-6A Charge3 , 4 --- 8.3 VDD=-30V , VGS=-10V , RG=6 --- 29.6 ID=-1A --- 51.7 Fall Time3 , 4 --- 15.6 Ciss Input Capacitance --- 870 Coss Output Capacitance --- 70 Crss Reverse Transfer Capacitance --- 42 Rg Gate resistance --- 16 Min. Typ. Max. Unit --- --- -14 A --- --- -52 A --- --- -1 V Tr Td(off) Tf Turn-On Delay Time nC Rise 3,4 Time3 , 4 Turn-Off Delay Time3 , 4 VDS=-30V , VGS=0V , F=1MHz VGS=0V, VDS=0V, F=1MHz ns pF  Drain-Source Diode Characteristics and Maximum Ratings Symbol Parameter IS Continuous Source Current ISM Pulsed Source Current VSD Diode Forward Voltage Conditions VG=VD=0V , Force Current VGS=0V , IS=-1A , TJ=25℃ Note : 1. Repetitive Rating : Pulsed width limited by maximum junction temperature. 2. VDD=-25V,VGS=-10V,L=0.1mH,IAS=-25A.,RG=25,Starting TJ=25℃. 3. The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%. 4. Essentially independent of operating temperature. www.msksemi.com AOD407-MS TC , Case Temperature (℃) Continuous Drain Current vs. TC Fig.2 TJ , Junction Temperature (℃) Fig.5 Fig.4 Qg , Gate Charge (nC) Gate Charge Waveform -ID , Continuous Drain Current (A) Normalized Vth vs. TJ Normalized Thermal Response Fig.3 TJ , Junction Temperature (℃) Normalized RDSON vs. TJ -VGS , Gate to Source Voltage (V) Normalized Gate Threshold Voltage Fig.1 Compiance Normalized On Resistance -ID , Continuous Drain Current (A) Semiconductor Square Wave Pulse Duration (s) Normalized Transient Impedance -VDS , Drain to Source Voltage (V) Fig.6 Maximum Safe Operation Area www.msksemi.com AOD407-MS Semiconductor EAS= V DS 90% 10% VGS Td(on) Tr Ton Fig.7 Td(off) 1 L x IAS2 x 2 Compiance BVDSS BVDSS-VDD BVDSS VDD IAS Tf Toff Switching Time Waveform VGS Fig.8 EAS Waveform www.msksemi.com AOD407-MS Semiconductor Compiance PACKAGE MECHANICAL DATA D A D1 c V L3 h E φ L4 L A1 L2 L1 D2 b e θ Symbol A A1 b c D D1 D2 E e L L1 L2 L3 L4 Φ θ h V Dimensions In Millimeters Min. Max. 2.200 2.400 0.000 0.127 0.635 0.770 0.460 0.580 6.500 6.700 5.100 5.460 4.830 REF. 6.000 6.200 2.186 2.386 9.712 10.312 2.900 REF. 1.400 1.700 1.600 REF. 0.600 1.000 1.100 1.300 0° 8° 0.000 0.300 5.250 REF. Dimensions In Inches Min. Max. 0.087 0.094 0.000 0.005 0.025 0.030 0.018 0.023 0.256 0.264 0.201 0.215 0.190 REF. 0.236 0.244 0.086 0.094 0.382 0.406 0.114 REF. 0.055 0.067 0.063 REF. 0.024 0.039 0.043 0.051 0° 8° 0.000 0.012 0.207 REF. REEL SPECIFICATION P/N AOD407-MS PKG QTY TO-252 2500 www.msksemi.com AOD407-MS Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
AOD407-MS 价格&库存
很抱歉,暂时无法提供与“AOD407-MS”相匹配的价格&库存,您可以联系我们找货
