MBRA320T3G
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
FEATURES
DO-214AC(SMA)
Ideal for surface mount applications
Easy pick and place
Built-in strain relief
Low forward voltage drop
MECHANICAL DATA
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.063 grams
Dimensions in inches and (millimeters)
1
Cathode
2
Anode
MAXIMUM RATINGS
Rating
Symbol
Value
Unit
VRRM
VRWM
VR
V
IO
3.0
A
Non−Repetitive Peak Surge Current
(Surge Applied at Rated Load Conditions
Halfwave, Single Phase, 60 Hz)
IFSM
80
A
Storage Temperature
Tstg
−65 to +150
°C
Operating Junction Temperature
TJ
−65 to +125
°C
dv/dt
10,000
V/ms
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Average Rectified Forward Current
(At Rated VR, TL = 100°C)
Voltage Rate of Change
(Rated VR, TJ = 25°C)
MARKING DIAGRAM
1
SS34
2
ORDERING INFORMATION
www.tokmas.com
Device
SS34
Package
Shipping
SMA
(Pb−Free)
2000 /
Tape & Reel
MBRA320T3G
THERMAL CHARACTERISTICS
Characteristic
Thermal Resistance − Junction−to−Lead (Note 1)
Thermal Resistance − Junction−to−Ambient (Note 1)
Symbol
Value
Unit
RθJL
RθJA
15
80
°C/W
VF
0.50
Volts
ELECTRICAL CHARACTERISTICS
Maximum Instantaneous Forward Voltage (Note 2)
(IF = 3.0 A, TJ = 25°C)
Maximum Instantaneous Reverse Current (Note 2)
IR
TJ = 25°C
TJ = 100°C
2.0
(VR = 20 V)
mA
TYPICAL CHARACTERISTICS
1
10
IF, FORWARD CURRENT (AMPS)
10
TJ = 125°C
TJ = 100°C
TJ = 25°C
0.1
0.0
TJ = −65°C
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.9
0.8
VF, INSTANTANEOUS FORWARD VOLTAGE (V)
1.0
1
TJ = 100°C
TJ = 125°C
TJ = 25°C
0.1
0.0
TJ = −65°C
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9 1.0
VF, MAXIMUM INSTANTANEOUS FORWARD VOLTAGE (V)
Figure 1. Typical Forward Voltage
www.tokmas.com
Figure 2. Maximum Forward Voltage
MBRA320T3G
1.E−01
IR, REVERSE CURRENT (AMPS)
1.E−01
1.E−02
1.E−02
1.E−03
TJ = 100°C
1.E−03
TJ = 100°C
TJ = 25°C
1.E−04
1.E−04
TJ = 25°C
1.E−05
1.E−06
IR, MAXIMUM REVERSE CURRENT (AMPS)
1.E−05
10
5
1.E−06
5
VR, REVERSE VOLTAGE (V)
dc
4
SQUARE WAVE
3
2
1
60
70
80
90
100
110
120
130
PFO, AVERAGE POWER DISSIPATION (W)
RqJL = 15°C/W
6
5
SQUARE
WAVE
4
3
2
dc
1
TL, LEAD TEMPERATURE (°C)
2
4
Figure 6. Forward Power Dissipation
700
TJ = 25°C
600
500
400
300
200
100
3
IO, AVERAGE FORWARD CURRENT (A)
Figure 5. Current Derating
Figure 4. Maximum Reverse Current
6
C, CAPACITANCE (pF)
IO, AVERAGE FORWARD CURRENT (AMPS)
Figure 3. Typical Reverse Current
5
15
10
8
12
16
28
32
Figure 7. Typical Capacitance
www.tokmas.com
36
40
5
MBRA320T3G
R(t), TRANSIENT THERMAL RESISTANCE (°C/W)
1000
D = 0.5
100
10
1
0.2
0.1
0.05
0.02
0.01
0.1
SINGLE PULSE
0.01
0.000001
0.00001
0.0001
0.001
0.01
0.1
1
10
100
10
100
1000
t, TIME (S)
Figure 8. Thermal Response, Junction−to−Ambient (min pad)
100
D = 0.5
0.2
10
0.1
0.05
1 0.02
0.01
0.1
SINGLE PULSE
0.01
0.000001
0.00001
0.0001
0.001
0.01
0.1
1
t, TIME (S)
Figure 9. Thermal Response, Junction to Ambient (1 inch pad)
www.tokmas.com
1000
很抱歉,暂时无法提供与“MBRA320T3G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.75582
- 20+0.68913
- 100+0.62244
- 500+0.55575
- 1000+0.52463
- 2000+0.50240
