Silicon N-Channel Power MOSFET
Features:
FQD2N100TM
CI5930-30A
V DSS
1000
V
Fast Switching
ID
2
A
Low Gate Charge and Rdson
P D (T C =25℃)
85
W
Low Reverse transfer capacitances
R DS(ON).TYPE.
7.8
Ω
100% Single Pulse avalanche energy Test
TO-252
Applications:
Power switch circuit of adaptor and charger.
Absolute(Tc= 25℃ unless otherwise specified):
Symbol
V DSS
Parameter
Rating
Units
1000
V
2
A
1.2
A
8
A
Gate-to-Source Voltage
±30
V
160
mJ
Drain-to-Source Voltage
Continuous Drain Current
ID
Continuous Drain Current T C = 100 °C
I DM a1
V GS
Pulsed Drain Current
E AS
a2
Single Pulse Avalanche Energy
E AR
a1
Avalanche Energy ,Repetitive
10
mJ
I AR
a1
Avalanche Current
2.1
A
Peak Diode Recovery dv/dt
5.0
V/ns
Power Dissipation
85
W
0.68
W/℃
150, –55 to 150
300
dv/dt
a3
PD
T J , T stg
TL
Derating Factor above 25°C
Operating Junction and Storage Temperature Range
Maximum Temperature for Soldering
www.tokmas.com
FQD2N100TM
CI5930-30A
Electrical Characteristics(Tc=25℃ unless otherwise specified):
OFF Characteristics
Symbol
V DSS
Parameter
Test Conditions
Drain to Source Breakdown Voltage V GS =0V,I D =250µA
ΔBV DSS /ΔT J Bvdss Temperature Coefficient
Rating
Min. Typ. Max.
1000
I D =250uA,Reference25℃
1.5
V DS =1000V,V GS = 0V,T a =25℃
1
V DS =800V,V=0V,Ta=125℃
250
Units
V
V/℃
I DSS
Drain to Source Leakage Current
µA
I GSS(F)
Gate to Source Forward Leakage
V GS =+30V
100
nA
I GSS(R)
Gate to Source Reverse Leakage
V GS =-30V
100
nA
ON Characteristics
Symbol
Parameter
Test Conditions
R DS(ON)
Drain-to-Source On-Resistance
V GS =10V,I D =1.0A
V GS(TH)
Gate Threshold Voltage
V DS =V GS ,I D =250µA
Rating
Min. Typ. Max.
Units
7.8
8.8
Ω
2.0
3.0
4.0
V
Pulse width tp≤380µs,δ≤2%
Dynamic Characteristics
Parameter
Symbol
g fs
Forward Transconductance
C iss
Input Capacitance
C oss
Output Capacitance
C rss
Reverse Transfer Capacitance
Test Conditions
V DS =15V,I D =2.0A
V GS =0V,V DS =25V
f=1.0MHz
Rating
Min. Typ. Max.
2.1
380
40
4
Units
S
pF
Resistive Switching Characteristics
Parameter
Symbol
t d(ON)
tr
t d(OFF)
tf
Test Conditions
Turn-on Delay Time
Rating
Min. Typ. Max.
8
Rise Time
I D =2.0A,V DD =500V
6
Turn-Off Delay Time
V GS =10V,R G =12Ω
36
15
15
2.1
6
Fall Time
Qg
Total Gate Charge
Q gs
Gate to Source Charge
Q gd
Gate to Drain (“ Miller ” )Charge
V GS =10V
www.tokmas.com
Units
ns
nC
FQD2N100TM
CI5930-30A
Source-Drain Diode Characteristics
Test Conditions
Rating
Symbol
Parameter
IS
Continuous Source Current (Body Diode)
2
A
I SM
Maximum Pulsed Current (Body Diode)
8
A
V SD
Diode Forward Voltage
I S =2.0A,V GS =0V
1.5
V
t rr
Reverse Recovery Time
I S =2.0A,T j = 25°C
500
ns
Q rr
Reverse Recovery Charge
dI F /dt=100A/us,V GS =0V
1.2
uC
Min. Typ. Max.
Units
Symbol
Parameter
Typ.
Units
R θJC
Junction-to-Case
1.47
℃ /W
100
℃ /W
R θJA
Junction-to-Ambient
a1 : Repetitive
a2 : L=10.0mH,
a3 : I
SD
rating; pulse width limited by maximum junction temperature
Start T J =25℃
=2.0A,di/dt ≤100A/us,V DD ≤BV DS, Start T J =25℃
www.tokmas.com
www.tokmas.com
FQD2N100TM
CI5930-30A
www.tokmas.com
FQD2N100TM
CI5930-30A
很抱歉,暂时无法提供与“FQD2N100TM”相匹配的价格&库存,您可以联系我们找货
