CMD60N68K/CMU60N68K
68V N-Channel MOSFET
General Description
Product Summary
The 60N68K uses advanced technology
and design to provide excellent R DS(ON) .
BVDSS
RDSON
ID
68V
11mΩ
60A
This device is ideal for boost converters
Applications
and synchronous rectifiers for consumer,
telecom, industrial power supplies and
LED controller
Power Supplies
LED backlighting.
DC-DC Converters
TO-252 /251 Pin Configuration
Features
D
D
Low On-Resistance
100% Avalanche Tested
G
S
TO-252
RoHS Compliant
Absolute Maximum Ratings
G
D
G
S
TO-251
S
Type
Package
Marking
CMD60N68K
TO-252
CMD60N68K
CMU60N68K
TO-251
CMU60N68K
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
60
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current1
60
A
1
48
A
180
A
ID@TC=100℃
IDM
Pulsed Drain Current
2
3
EAS
Single Pulse Avalanche Energy
312
mJ
PD@TC=25℃
Total Power Dissipation
110
W
TSTG
Storage Temperature Range
-55 to 175
TJ
Operating Junction Temperature Range
-55 to 175
Thermal Data
Symbol
CA03O1
Max.
Unit
RθJA
Thermal Resistance Junction-ambient
Parameter
40
℃/W
RθJC
Thermal Resistance Junction -Case
1.36
℃/W
www.cmosfet.com
Typ.
Page 1 of 2
CMD60N68K/CMU60N68K
Electrical Characteristics (TJ=25℃ , unless otherwise noted)
Symbol
Min.
Typ.
Max.
Unit
BVDSS
RDS(ON)
Drain-Source Breakdown Voltage
Parameter
VGS=0V , ID=250μA
Conditions
68
V
Static Drain-Source On-Resistance
VGS=10V , ID=20A
11
mΩ
VGS(th)
Gate Threshold Voltage
VGS=VDS , ID =250μA
2
4
V
VDS=60V , VGS=0V , TJ=25℃
1
VDS=60V , VGS=0V , TJ=125℃
100
VGS = ±20V , VDS=0V
±100
nA
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
uA
gfs
Forward Transconductance
VDS=5V , ID=20A
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2.0
Ω
Qg
Total Gate Charge
36
Qgs
Gate-Source Charge
16
Gate-Drain Charge
10
Turn-On Delay Time
21
Qgd
Td(on)
Tr
Td(off)
Tf
VDS=48V , VGS=10V , ID=65A
Rise Time
VDD=27V , VGS=10V , RGEN =4.7Ω
51
Turn-Off Delay Time
ID=1A
37
nC
ns
Fall Time
12
Ciss
Input Capacitance
3000
Coss
Output Capacitance
500
Crss
Reverse Transfer Capacitance
25
Min.
Typ.
Max.
Unit
60
A
180
A
1.2
V
VDS=25V , VGS=0V , f=1MHz
pF
Diode Characteristics
Symbol
IS
Parameter
Conditions
Continuous Source Current1
2
ISM
Pulsed Source Current
VSD
Diode Forward Voltage
VG=VD=0V , Force Current
VGS=0V , IS=20A ,TJ=25℃
Note :
2
1.The data tested by surface mounted on a 1 inch FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≤ 300us , duty cycle ≤ 2%.
3.The EAS data shows Max. rating . The test condition is VDD=20V,VGS=10V,L=1.0mH,IAS=25A.
This product has been designed and qualified for the counsumer market.
Cmos assumes no liability for customers' product design or applications.
Cmos reserver the right to improve product design ,functions and reliability wihtout notice.
CA03O1
www.cmosfet.com
Page 2 of 2
很抱歉,暂时无法提供与“CMD60N68K”相匹配的价格&库存,您可以联系我们找货
