RJE0605JPD-00-J3
www.VBsemi.com
P-Channel 60 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
RDS(on) ()
ID (A)d
0.046 at VGS = - 10 V
- 35
0.058 at VGS = - 4.5 V
- 30
VDS (V)
- 60
• Halogen-free According to IEC 61249-2-21
Definition
• TrenchFET® Power MOSFET
• 100 % UIS Tested
Qg (Typ)
26
• Compliant to RoHS Directive 2002/95/EC
APPLICATIONS
• High Side Switch for Full Bridge Converter
• DC/DC Converter for LCD Display
TO-252
S
G
Drain Connected to Tab
G
D
S
Top View
D
P-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise note)
Parameter
Symbol
Limit
Drain-Source Voltage
VDS
- 60
Gate-Source Voltage
VGS
± 20
Continuous Drain Current (TJ = 150 °C)
TC = 25 °C
TC = 125 °C
Avalanche Current, Single Pulse
Repetitive Avalanche Energy, Single Pulsea
Power Dissipation
L = 0.1 mH
TC = 25 °C
TA = 25 °C
- 25
A
- 100
IAS
- 22
EAS
24.2
38.5
PD
mJ
c
W
2.3b, c
TJ, Tstg
Operating Junction and Storage Temperature Range
V
- 35
ID
IDM
Pulsed Drain Current
Unit
- 55 to 150
°C
THERMAL RESISTANCE RATINGS
Parameter
Maximum Junction-to-Ambientb
Maximum Junction-to-Case
Notes:
a. Duty cycle 1 %.
b. When mounted on 1" square PCB (FR-4 material).
c. See SOA curve for voltage derating.
d. Based up on TC = 25 °C.
Symbol
t 10 s
Steady State
RthJA
RthJC
Typical
Maximum
Unit
17
45
2.7
21
55
3.25
°C/W
服务热线:400-655-8788
1
RJE0605JPD-00-J3
www.VBsemi.com
SPECIFICATIONS (TJ = 25 °C, unless otherwise note)
Parameter
Symbol
Test Conditions
Min .
Typ.
Max.
Unit
-3
V
nA
Static
Drain-Source Breakdown Voltage
Gate Threshold Voltage
Gate-Body Leakage
VDS
VGS = 0 V, ID = - 250 µA
- 60
VGS(th)
VDS = VGS, ID = - 250 µA
-1
IGSS
VDS = 0 V, VGS = ± 20 V
± 100
VDS = - 60 V, VGS = 0 V
-1
VDS = - 60 V, VGS = 0 V, TJ = 125 °C
- 50
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currenta
ID(on)
V
VDS = - 60 V, VGS = 0 V, TJ = 150 ° C
Drain-Source On-State Resistancea
a
Forward Transconductance
RDS(on)
VDS - 5 V, VGS = - 10 V
- 125
- 20
A
VGS = - 10 V, ID = - 10 A
0.046
VGS = - 10 V, ID = - 10 A, TJ = 125 °C
0.095
VGS = - 10 V, ID = - 10 A, TJ = 150 °C
0.115
VGS = - 4.5 V, ID = - 5 A
0.058
VDS = - 15 V, ID = - 10 A
22
gfs
µA
S
Dynamicb
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
90
Total Gate Chargec
Qg
26
c
Gate-Source Charge
Qgs
Gate-Drain Chargec
Qgd
c
Rise Timec
Turn-Off Delay
VDS = - 30 V, VGS = - 10 V, ID = - 10 A
Fall Timec
f = 1 MHz
td(on)
tr
Timec
td(off)
VDD = - 30 V, RL = 3
ID - 19 A, VGEN = - 10 V, Rg = 2.5
tf
Drain-Source Body Diode and Characteristics (TC = 25
pF
130
40
nC
4.5
7
Rg
Gate Resistance
Turn-On Delay Time
1900
VGS = 0 V, VDS = - 25 V, f = 1 MHz
7
8
15
9
15
65
100
30
45
ns
°C)b
IS
- 20
Pulsed Current
ISM
- 30
Forward Voltagea
VSD
IF = - 19 A, VGS = 0 V
-1
- 1.5
V
trr
IF = - 19 A, di/dt = 100 A/µs
41
61
ns
Continuous Current
Reverse Recovery Time
A
Notes:
a. Pulse test; pulse width 300 µs, duty cycle 2 %.
b. Guaranteed by design, not subject to production testing.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
2
RJE0605JPD-00-J3
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
30
30
VGS = 10 thru 5 V
4V
25
ID - Drain Current (A)
25
10
3V
5
10
TC = 125 °C
5
25 °C
- 55 °C
4
6
8
10
0.5
1.0
VDS - Drain-to-Source Voltage (V)
Output Characteristics
2.5
3.0
3.5
4.0
4.5
0.12
TC = - 55 °C
0.10
RDS(on) - On-Resistance (Ω)
30
g fs - Transconductance (S)
2.0
Transfer Characteristics
35
25 °C
25
125 °C
10
5
VGS = 4.5 V
0.06
VGS = 10 V
0.04
0.02
0.00
10
15
30
10
15
30
VGS - Gate-to-Source Voltage (V)
Transconductance
On-Resistance vs. Drain Current
1800
V GS - Gate-to-Source Voltage (V)
1500
C - Capacitance (pF)
1.5
Ciss
1200
900
600
300
Coss
Crss
VDS = 30 V
ID = 10 A
16
12
8
4
40
Capacitance
50
60
40
50
Qg - Total Gate Charge (nC)
Gate Charge
服务热线:400-655-8788
3
RJE0605JPD-00-J3
www.VBsemi.com
40
ID = 10 A
I S - Source Current (A)
RDS(on) - On-Resistance (normalized)
1.9
VGS = 10 V
1.6
1.3
1.0
10
TJ = 150 °C
TJ = 25 °C
0.7
1
0.4
- 50
- 25
50
75
100
125
150
0.0
0.3
0.6
0.9
1.2
1.5
VSD - Source-to-Drain Voltage (V)
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
Source-Drain Diode Forward Voltage
THERMAL RATINGS
25
100
Limited by rDS(on)*
100 ms
10
I D - Drain Current (A)
10
5
1s
DC
0.1
BVDSS Limited
0.01
50
75
100
125
150
10 s
1
TC = 25 °C
Single Pulse
0.001
0.1
TC - Case Temperature (°C)
* VGS
Maximum Drain Current
vs. Case Temperature
1
10
100
1000
minimum VGS at which rDS(on) is specified
Safe Operating Area
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10- 4
10- 3
10 - 2
10 - 1
1
Square Wave Pulse Duration (sec)
10
100
600
Normalized Thermal Transient Impedance, Junction-to-Ambient
服务热线:400-655-8788
4
RJE0605JPD-00-J3
www.VBsemi.com
THERMAL RATINGS
2
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10 -4
10 -3
10- 2
10 -1
1
10
100
Normalized Thermal Transient Impedance, Junction-to-Case
服务热线:400-655-8788
5
RJE0605JPD-00-J3
www.VBsemi.com
TO-252AA Case Outline
E
C2
L3
H
D
b2
D1
e1
E1
L
gage plane height (0.5 mm)
e
L5
L4
b
C
A1
INCHES
MILLIMETERS
A
b3
DIM.
MIN.
MAX.
MIN.
MAX.
A
2.18
2.38
0.086
0.094
A1
0.127
0.005
b
0.64
0.88
0.025
0.035
b2
0.76
1.14
0.030
0.045
b3
4.95
5.46
0.195
0.215
0.024
C
0.46
0.61
0.018
C2
0.46
0.89
0.018
0.035
D
5.97
6.22
0.235
0.245
D1
4.10
0.161
E
6.35
6.73
0.250
0.265
E1
4.32
0.170
H
9.40
10.41
0.370
0.410
e
2.28 BSC
e1
0.090 BSC
4.56 BSC
0.180 BSC
L
1.40
1.78
0.055
0.070
L3
0.89
1.27
0.035
0.050
L4
1.02
0.040
L5
1.01
1.52
0.040
0.060
ECN: T16-0236-Rev. P, 16-May-16
DWG: 5347
Notes
• Dimension L3 is for reference only.
服务热线:400-655-8788
6
RJE0605JPD-00-J3
www.VBsemi.com
RECOMMENDED MINIMUM PADS FOR DPAK (TO-252)
0.224
0.243
0.087
(2.202)
0.090
(2.286)
(10.668)
0.420
(6.180)
(5.690)
0.180
0.055
(4.572)
(1.397)
Recommended Minimum Pads
Dimensions in Inches/(mm)
Return to Index
服务热线:400-655-8788
7
RJE0605JPD-00-J3
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
