HE2028 series
800mA Low Power LDO
Features
Good Transient Response
High input voltage (up to 50V)
Output voltage accuracy: tolerance ±2%
Low Power Consumption: 2µA (Typ)
SOT223-3L,and TO252-3L package
Maximum Output Current: 800mA
PSRR:85dB@1KHz
Voltage drop:360mV@100mA(3.3V)
Applications
Portable, Battery Powered Equipmpm
Audio/Video equipment
Microcontroller Applications
Weighting Scales
Smoke detector and sensor
Home Automation
General Description
The HE2028 series is a high voltage,ultralow-power,low dropout voltage regulator. The
device can deliver 800mA output current with a dropout voltage of 360mV and allows an
input voltage as high as 50V. The typical quiescent current is only 2µA. The device is
available in fixed output voltages of 3.3 and 5.0V.The device features integrated shortcircuit and thermal shutdown protection.Although designed primarily as fixed voltage
regulators, the device can be used with external components to obtain variable voltages.
Selection Table
Part No.
Output Voltage
Package
HE2028A33FR
3.3V
SOT223
HE2028A50FR
5.0V
SOT223
HE2028A33GR
3.3V
TO252
HE2028A50GR
5.0V
TO252
Marking
Application Circuits
HE2028Axx
Ver1.1
1
Aug 3,2021
HE2028 series
800mA Low Power LDO
Pin Assignment
SOT223 (Top View)
VIN
TO252 (Top View)
GND
GND
Mark
Mark
GND
VOUT
VIN
VOUT
Functional Block Diagrara
Ver1.1
2
Aug 3,2021
HE2028 series
800mA Low Power LDO
Absolute Maximum Ratings
(1) (2)
Parameter
Symbol
Maximum Rating
Unit
VIN
VSS -0.3~VSS+50.0
V
VOUT
VSS -0.3~VSS+6.0
V
IOUT
800
mA
Input Voltage
Output Current
Power Dissipation
Thermal Resistance
SOT223-3L
1200
Pd
TO252-3L
SOT223-3L
RθJA
TO252-3L
mW
1800
(3)
200
℃/W
150
℃/W
Operating Temperature
Topr
-40~85
Storage Temperature
Tstg
-40~125
Soldering Temperature & Time
Tsolder
260℃, 10s
Note (1): Exceeding these ratings may damage the device.
Note (2): The device is not guaranteed to function outside of its operating conditions
Note (3): The package thermal impedance is calculated in accordance to JESD 51-7.
ESD Ratings
Item
Description
Value
Unit
V(ESD-HBM)
Human Body Model (HBM)
ANSI/ESDA/JEDEC JS-001-2014
Classification, Class: 2
±4000
V
V(ESD-CDM)
Charged Device Mode (CDM)
ANSI/ESDA/JEDEC JS-002-2014
Classification, Class: C0b
±200
V
JEDEC STANDARD NO.78E APRIL 2016
Temperature Classification, Class: I
±150
mA
ILATCH-UP
ESD testing is performed according to the respective JESD22 JEDEC standard.The human body model is a 100 pF capacitor discharged
through a 1.5kΩ resistor into each pin. The machine model is a 200pF capacitor discharged directly into each pin.
Recommended Operating Conditions
Parameter
MIN.
MAX.
Units
Supply voltage at VIN
30
V
Operating junction temperature range, Tj
-40
125
°C
Operating free air temperature range, TA
-40
85
°C
Note : All limits specified at room temperature (TA = 25°C) unless otherwise specified. All room temperature limits are 100% production
tested. All limits at temperature extremes are ensured through correlation using standard Statistical Quality Control (SQC) methods. All
limits are used to calculate Average Outgoing Quality Level (AOQL).
Ver1.1
3
Aug 3,2021
HE2028 series
800mA Low Power LDO
Electrical characteristics
(At TA=25°C, CIN=1uF, VIN=VOUTNOM+1.0V, COUT=10µF, unless otherwise noted)
Min
Typ.
Max
Units
3.0
50
V
VIN=12V
No load
2.0
5.0
μA
VIN=12V
IOUT =10mA
-2.0
+2.0
VIN=0V
0.1
μA
0.1
μA
800
mA
IOUT =10mA
VIN = VOUTNOM-0.1V
36
mV
IOUT =100mA
VIN = VOUTNOM-0.1V
360
mV
ΔLOAD Load Regulation
VIN= VOUT +1V
1mA≤IOUT≤100mA
40
mV
ΔLINE Line Regulation
IOUT=1mA,
VOUTNOM +0.5V≤VIN≤50V
0.01
%/V
PSRR Power Supply Rejection Ratio
VIN=12V , IOUT =10mA
f=1KHz, VOUT =3.3V
85
dB
Symbol
VIN
IQ
Parameter
Input Voltage
Quiescent Current
VOUT Output Voltage
ISD
ILEAK
Test Conditions
Shutdown Ground Current
VOUT Shutdown Leakage Current VOUT = 0V
IOUT_MAX Output Current
VDROP Dropout Voltage(1)
VIH
EN Threshold Voltage,Logic-High VIN=5.0V, IOUT=1mA
1.0
V
VIL
EN Threshold Voltage,Logic-Low VIN=5.0V
0.4
V
300
450
mA
ILIMIT Current Limit
VIN= VOUT +1V
ISHORT Short /Start Load Current
RL=1
eNO
Output Noise Voltage
TSD
ΔTSD
10Hz to 100kHz
100
mA
100
μVRMS
Thermal Shutdown Temperature
150
Thermal Shutdown Hysteresis
COUT=1µF
Note:*1 Dropout Voltage is the voltage difference between the input and the output at which the output voltage
drops 2% below its nominal value.
Ver1.1
4
Aug 3,2021
HE2028 series
800mA Low Power LDO
Typical Performance Ch
Cha
aracteristics:
Test Condition: TA=25°C,Iout=1mA,
A, C
COUT=10uF, unless otherwise noted
Ver1.1
5
Aug 3,2021
HE2028 series
800mA Low Power LDO
Line Transient Response (VIN=5 to 24V VOUT=3.3V)
Line Transient Response (VIN=24 to 5V VOUT=3.3V)
3.3V
VOUT
3.3V
24V
VIN
24V
VOUT
0V
5V
5V
VIN
0V
0V
Time(4us/div)
Load Transient Response (VIN=5V VOUT=0V IOUT=140mA)
Time(4us/div)
Load Transient Response (VIN=5V VOUT=0V IOUT=140-0mA)
140mA
140mA
IOUT
0A
0V
VOUT
0A
IOUT
0V
VOUT
-280mV
5V
VIN
5V
VIN
0V 5V
0V
Time(20us/div)
Start Up
(VIN=24V VOUT=3.3V)
Start Up
Time(20us/div)
(VIN=24V VOUT=3.3V IOUT=150mA)
IOUT
150mA
VOUT
3.3V
VOUT
0mA
H
E
2
1
A
x
x
0V
24V
24V
VIN
VIN
0V
0V
Time(100us/div)
Time(100us/div)
Short Circuit Protection (VIN=6V VOUT= short to 3.3V
Short Circuit Protection (VIN=5V VOUT=3.3V to short)
3.3V
3.3V
VOUT
VOUT
0V
500mA
500mA
IOUT
0mA
VIN
5V
0V
0mA
IOUT
6V
VIN
0V
0V
Time(20ms/div)
Ver1.1
Time(20ms/div)
6
Aug 3,2021
HE2028 series
800mA Low Power LDO
Application Guideline
Input Capacitor
A 10μF ceramic capacitor is recommended to connect between VDD and GND pins to decouple input
power supply glitch and noise. The amount of the capacitance may be increased without limit. This
input capacitor must be located as close as possible to the device to assure input stability and less
noise. For PCB layout, a wide copper trace is required for both VIN and GND.
Output Capacitor
An output capacitor is required for the stability of the LDO. The recommended output capacitance is
10μF, ceramic capacitor is recommended, and temperature characteristics are X7R or X5R. Higher
capacitance values help to improve load/line transient response. The output capacitance may be
increased to keep low undershoot/overshoot. Place output capacitor as close as possible to VOUT
and GND pins.
Dropout Voltage
The dropout voltage refers to the voltage difference between the VIN and VOUT pins while operating
at specific output current. The dropout voltage VDROP also can be expressed as the voltage drop on
the pass-FET at specific output current (IRATED) while the pass-FET is fully operating at ohmic
region and the pass-FET can be characterized asan resistance RDS(ON). Thus the dropout voltage
can bedefined as (VDROP = VIN − VOUT = RDS(ON) x IRATED). Fornormal operation, the
suggested LDO operating range is (VIN > VOUT + VDROP) for good transient response and PSRR
ability. Vice versa, while operating at the ohmic region will degrade the performance severely.
Thermal Application
For continuous operation, do not exceed the absolute maximum junction temperature. The maximum
power dissipation depends on the thermal resistance of the IC package, PCB layout, rate of
surrounding airflow, and difference between junction and ambient temperature. The maximum power
dissipation can be calculated as below: TA=25°C, PCB,
The max PD= (125°C − 25°C) / (Thermal Resistance °C/W)
Power dissipation (PD) is equal to the product of the output current and the voltage drop across the
output pass element, as shown in the equation below:
PD = (VIN – VOUT) × IOUT
Ver1.1
7
Aug 3,2021
HE2028 series
800mA Low Power LDO
■ PACKAGING INFORMATION(Continued)
Ver1.1
8
Aug 3,2021
HE2028 series
800mA Low Power LDO
Ver1.1
9
Aug 3,2021
很抱歉,暂时无法提供与“HE2028A50FR”相匹配的价格&库存,您可以联系我们找货
