XC6206
■ DESCRIPTION
The XC6206 series are precise, low power consumption, high voltage; positive voltage regulators
manufactured using CMOS and laser trimming technologies. The series provides large currents with a
significantly small dropout voltage. The XC6206 consists of a current limiter circuit, a driver transistor, a
precision reference voltage and an error correction circuit. The series is compatible with low ESR
ceramic capacitors. The current limiter's foldback circuit also operates as a short protect for the output
current limiter and the output pin. Output voltage can be set internally by laser trimming technologies. It
is selectable in 100mV increments within a range of 1.2V to 5.0V. SOT-89-3, SOT-23-3 ,SOT353 and
SOT23-3B packages are available.
■ FEATURES
z
z
z
z
z
z
z
Output Voltage Range
Highly Accurate
Dropout Voltage
Low Power Consumption
Maximum Output Current
Internal protector
Small packages
1.2V to 5.0V (selectable in 100mV steps)
± 2%
160mV @ 50mA (3.0V type)
2μA (TYP.)
100mA (Vin≥Vout+1V)
current limiter and short protector
SOT-89-3, SOT-23-3, SOT23-3B,SOT353 and other required
■ APPLICATIONS
z
z
z
z
z
Battery powered equipment
Reference voltage sources
Cameras, Video cameras
Mobile phones
Communication tools
■ PACKAGE
z
z
z
z
SOT-89-3
SOT-23-3, SOT23-3B
SOT353
Other required
■ BLOCK DIAGRAM
Figure 1
- 1-
2012-7-8
XC6206
■ ABSOLUTE MAXIMUM RATINGS
PARAMETER
SYMBOL
MAXIMUM RATING
Input Voltage
VIN
VSS-0.3~VSS+6
Output Current
VOUT
VSS-0.3~VIN+0.3
Power Dissipation
Topr
Storage
Temperature
Tstg
V
SOT-23-3, SOT23-3B
250
SOT353
250
SOT-89-3
500
PD
Operating Ambient
Temperature
UNIT
mW
-40~+85
°C
-40~+125
Caution: The absolute maximum ratings are rated values exceeding which the product could suffer physical
damage. These values must therefore not be exceeded under any conditions.
■ Electrical Characteristics
Item
Symbol
Condition
Output Voltage
VOUT(E)1
VIN =VOUT(S)+1.0 V, IOUT=1 mA
Output Current
IOUT
VIN≥VOUT(S)+1.0 V
Dropout Voltage
Vdrop
Line Regulations
Input Voltage
Output Voltage
Temperature
Characteristics
∆VOUT 1
∆VIN • VOUT
∆VOUT 2
∆VOUT
∆Ta • VOUT
IOUT=50
mA
MIN
VOUT(S)
×0.98
100
TYP
VOUT(S)
MAX
VOUT(S)
×1.02
UNIT
CIRCUIT
V
1
mA
1
1.5 V ≤VOUT(S)≤2.5 V
0.20
0.28
2.6 V ≤VOUT(S)≤3.3 V
0.16
0.24
3.4 V ≤VOUT(S)≤5.0 V
0.12
0.20
0.05
0.3
%/V
mV
±100
ppm/℃
VOUT(S)+0.5 V ≤VIN≤5.5 V
IOUT=1 mA
VIN=VOUT(S)+1.0 V
1.0 mA ≤IOUT ≤50 mA
V
1
VIN=VOUT(S)+1.0 V,
IOUT=10 mA
-40°C ≤ Ta ≤85°C
Supply Current
ISS1
VIN=VOUT(S)+1.0 V
2
Input Voltage
VIN
1.8
Ripple-Rejection
|RR|
VIN=VOUT(S)+1.0 V,f=1.0 kHz
Vrip=0.5 Vrms, IOUT=10 mA
μA
2
6
V
40
dB
1
Short current
Ishort
VIN=VOUT(S)+1.5 V,
30
mA
1
Current Limiter
Ilim
VIN=VOUT(S)+1.5 V,
380
mA
1
- 2-
2012-7-8
XC6206
■ TEST CIRCUITS
■ TYPICAL APPLICATION CIRCUIT
1、Basic circuit
2、High output current positive voltage regulator
XC6206
XC6206
3、Circuit for increasing output voltage
4、Circuit for increasing output voltage
XC6206
XC6206
5、Constant current regulator
6、Dual supply
XC6206
XC6206
XC6206
Caution The above connection diagram and constant will not guarantee successful operation. Perform thorough
evaluation using the actual application to set the constant.
- 3-
2012-7-8
XC6206
■ Application Conditions
Input capacitor (CIN): 1.0µF or more
Output capacitor (CL):0.1 µF or more (tantalum capacitor)
Caution A general series regulator may oscillate, depending on the external components selected. Check that no
oscillation occurs with the application using the above capacitor.
■ TYPICAL PERFORMANCE CHARACTERISTICS(3.0V output)
1. Output Voltage vs. Output Current
2. Output Voltage vs. Input Voltage
3. Dropout Voltage vs. Output Current
4、Dropout Voltage vs. Output Voltage
5. Output Voltage vs. Ambient Temperature
6. Ripple Rejection Rate
- 4-
2012-7-8
XC6206
7. Transient Response
Input Transient Response
Load Transient Response
■ ORDERING INFORMATION
XC6206P①②③④⑤
DESIGNATOR
SYMBOL
① ②
Integer
③
2
Accuracy: within ±2%
M
SOT-23
P
SOT-89
K
SOT353
V
SOT23-3B
R
Embossed Tape: Standard Feed
L
Embossed Tape: Reverse Feed
④
⑤
DESCRIPTION
Output Voltage:
e.g. ① =3, ② =0
3.0V
■ MARKING RULE
SOT-23,SOT23-3B & SOT-89
-5 -
2012-7-8
XC6206
① Represents product series
SYMBOL
PRODUCT SERIES
6
XC6206Pxxxxx
② Represents the type of regulator
VOLTAGE(V)
SYMBOL
0.1~3.0
5
3.1~6.0
6
6.1~9.0
7
③ Represents the Output Voltage
SYMBOL OUTPUT VOLTAGE(V) SYMBOL
2
3
4
5
6
7
8
9
A
B
C
D
E
1.2
1.3
1.4
1.5
3.1
3.2
3.3
3.4
3.5
3.6
3.7
3.8
3.9
4
4.1
4.2
4.3
4.4
4.5
F
H
K
L
M
N
P
R
S
T
U
V
X
Y
Z
OUTPUT VOLTAGE
(V)
1.6 4.6 1.7 4.7 1.8 4.8 1.9 4.9 2
5.0 2.1 5.1 2.2 5.2 2.3 5.3 2.4 5.4 2.5 5.5 2.6 5.6 2.7 5.7 2.8 5.8 2.9 5.9 3
6.0 -
④Represents the assembly lot no.
0~9,A~Z repeated (G,I,J,O,Q,W excepted)
■ PIN CONFIGURATION
Remark Please contact the Natlinear marketing department for other packages.
- 6-
2012-7-8
XC6206
■ PACKAGING INFORMATION
SOT23-3/SOT23-3B
SOT-89-3
SOT353
- 7-
2012-7-8
很抱歉,暂时无法提供与“XC6206P282MR”相匹配的价格&库存,您可以联系我们找货
