PESDHC2FD12VUHF
PESDHC2FD12VUHF
    PRISEMI(上海芯导电子)
PESDHC2FD12VUHF 数据手册
PESDHC2FD12VUHF Uni-directional 12V High Capacitance ESD Protector Description The PESDHC2FD12VUHF ESD protector is designed to replace multilayer varistors (MLVs) in portable applications such as cell phones, notebook computers, and PDA’s. They feature large cross-sectional area junctions for conducting high transient currents, offer desirable electrical characteristics for board level protection, such as fast response time, lower operating voltage, lower clamping voltage and no device degradation when compared to MLVs. The PESDHC2FD12VUHF protects DFN1006-2L(Bottom View) sensitive semiconductor components from damage or upset due to electrostatic discharge (ESD) and other voltage induced transient events. The PESDHC2FD12VUHF is available in a DFN1006-2L package with working voltages of 15 volt. It gives designer the flexibility to protect one unidirectional line in applications where Pin1 Pin2 arrays are not practical. Additionally, it may be “sprinkled” around the board in applications where board space is at a Circuit Diagram premium. Feature  860W peak pulse power per line (tP = 8/20μs)  DFN1006-2L package  Response time is typically < 1 ns 12F Pin1  Unidirectional configurations Pin2  Low clamping voltage  RoHS compliant Marking (Top View)  Transient protection for data lines to IEC 61000-4-2(ESD) ±30kV(air), ± 30kV(contact); IEC 61000-4-5 (Lightning) 40A (8/20us) Applications Mechanical Characteristics  Cell phone handsets and accessories  Mounting position: Any  Personal digital assistants (PDA’s)  Qualified max reflow temperature:260℃  Notebooks, desktops, and servers  Device meets MSL 1 requirements  Portable instrumentation  DFN1006-2L without plating  Cordless phones  Digital cameras  Peripherals Rev.06.0 1 www.prisemi.com ESD Protector PESDHC2FD12VUHF Electronics Parameter Symbol Parameter VRWM Peak Reverse Working Voltage IR Reverse Leakage Current @ VRWM VBR Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP PPP Peak Pulse Power CJ Junction Capacitance IF Forward Current VF Forward Voltage @ IF I IF VC V VBRVRWM IR IT VF IPP Electrical characteristics per line@25℃ (unless otherwise specified) Parameter Symbol Conditions Min. Typ. Max. Units Peak Reverse Working Voltage VRWM - - - 12 V Forward Voltage VF IF =10mA - - 1.0 V Breakdown Voltage VBR It = 1mA 13.5 14.5 - V Reverse Leakage Current IR VRWM = 12V - - 1.0 μA Clamping Voltage1) VC TLP = 16A, tp = 100ns - 15 - V RDYN - - 0.015 - Ω IPP = 30A,tP = 8/20μs - 20.5 23 V IPP = 40A,tP = 8/20μs - 21.5 24 V VR = 0V,f = 1MHz - 100 130 pF Dynamic resistance1) Clamping Voltage2) VC Junction Capacitance CJ Notes: 1.TLP parameter: Z0=50Ω, tp=100ns, tr=2ns, averaging window from 70ns to 90ns. RDYN is calculated from 4A to 16A. 2.Non-repetitive current pulse, according to IEC61000-4-5. Absolute maximum rating@25℃ Rating Symbol Value Units Peak Pulse Power ( tP = 8/20μs ) PPP 860 W Peak Pulse Current ( tP = 8/20μs ) IPP 40 A Lead Soldering Temperature TL 260 (10 sec) ℃ TJ,TSTG -55~+150 ℃ ESD Protection-Contact Discharge VESD ±30 kV ESD Protection-Air Discharge VESD ±30 kV Junction and Storage Temperature Range Rev.06.0 2 www.prisemi.com ESD Protector PESDHC2FD12VUHF Typical Characteristics tr=8μs IPP – Peak Pulse Current - % of IPP 100 100 % Of Rated Power 80 60 tP =20μs(IPP /2) 40 60 40 20 20 0 80 0 5 10 15 20 25 0 30 0 25 50 75 100 125 t - Time -μs TL – Lead Temperature - ℃ Fig 1.Pulse Waveform(8/20μs) Fig 2.Power Derating Curve 30 300 f = 1MHz Pulse waveform: tp=8/20us Pin1-Pin2 250 C - Junction Capacitance - pF VC - Clamping Voltage - V 25 20 15 10 5 0 150 200 150 100 50 0 10 20 30 0 40 0 3 IPP - Peak pulse current - A 6 9 12 VR - Reverse voltage - V Fig 4. Capacitance vs. Reveres voltage Fig 3. Clamping voltage vs. Peak pulse current 100000 20 V_pulse Pulse from a Transmission line 16 TLP_V TLP Current - A Peak Pulse Power - W 12 + DUT - 10000 1000 TLP_I 100ns Pin 1 to Pin 2 T = 25 ℃ 8 4 0 -4 -8 100 -12 -16 10 1 10 100 1000 Pulse Duration - μs -2 0 2 4 6 8 10 12 14 16 TLP Voltage - V Fig 5. Non Repetitive Peak Pulse Power vs. Pulse time Rev.06.0 -20 3 Fig 6. TLP Measurement www.prisemi.com ESD Protector PESDHC2FD12VUHF 10 40 30 0 VCL-max-peak = 31.8V Voltage - V Voltage - V VCL-30ns-peak = 15.5V 20 10 VCL-max-peak = -23.1V -10 VCL-30ns-peak = -1.25V -20 0 -10 -20 0 20 40 60 80 100 120 -30 -20 140 0 20 Times - ns 40 60 80 100 120 140 Times - ns Fig 7. Clamping Voltage at IEC61000-4-2 +8kV Pulse Waveform Fig 8. Clamping Voltage at IEC61000-4-2 -8kV Pulse Waveform Solder Reflow Recommendation 300 Preliminary Heating Soldering Cooling(in air) Temperature of Soldering 260℃ (+0,-5℃) 250 245℃ (+0,-5℃) 200 150 120℃ 100 100℃ 50 0 2 to 5 min more than 1 min Less than 10s Remark: Pb free for 260℃;Pb for 245℃. Rev.06.0 4 www.prisemi.com ESD Protector PESDHC2FD12VUHF PCB Design For TVS diodes a low-ohmic and low-inductive path to chassis earth is absolutely mandatory in order to achieve good ESD protection. Novices in the area of ESD protection should take following suggestions to heart:  Do not use stubs, but place the cathode of the TVS diode directly on the signal trace.  Do not make false economies and save copper for the ground connection.  Place via holes to ground as close as possible to the anode of the TVS diode.  Use as many via holes as possible for the ground connection.  Keep the length of via holes in mind! The longer the more inductance they will have. Ordering information Device Package Reel Shipping PESDHC2FD12VUHF DFN1006-2L (Pb-Free) 7" 10000 / Tape & Reel Load with information USER DIRECTION OF FEED 4.0±0.1 Ø1.50±0.1 2.0±0.10 Pin1 3.5±0.05 8.0±0.3 1.75±0.1 2.0±0.05 Unit:mm Rev.06.0 5 www.prisemi.com ESD Protector PESDHC2FD12VUHF Product dimension (DFN1006-2L) C D E F Top View H Bottom View A B Dim Millimeters Side View Inches Min Max Min Max A 0.340 0.498 0.013 0.020 B 0.000 0.050 0.000 0.002 C 0.950 1.080 0.037 0.043 D 0.550 0.680 0.022 0.027 E 0.400 0.600 0.016 0.024 F 0.200 0.300 0.008 0.012 H 0.400 Typ. 0.015 Typ. 1.20 0.50 0.60 0.70 Unit:mm Suggested PCB Layout Rev.06.0 6 www.prisemi.com ESD Protector PESDHC2FD12VUHF IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi), Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06.0 7 www.prisemi.com
PESDHC2FD12VUHF 价格&库存
很抱歉,暂时无法提供与“PESDHC2FD12VUHF”相匹配的价格&库存,您可以联系我们找货
