PNMT60V02E
N-Channel MOSFET
Description
PNMT60V02E is designed for high speed switching applications
The enhancement mode MOS is extremely high density cell and low on-resistance.
D(3)
MOSFET Product Summary
VDS(V)
RDS(on)(Ω)
VGS(th)(V)
ID(A)
60
7.5@ VGS=10V
0.5 to 1.5
0.18
G(1)
S(2)
Electrical characteristics per line@25℃( unless otherwise specified)
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Units
OFF CHARACTERISTICS
Drain-Source Breakdown Voltage
VDSS
ID =10μA,VGS=0V
60
V
Zero Gate Voltage Drain Current
IDSS
VDS =40V,VGS=0V
0.5
μA
Gate-Body Leakage Current
IGSS
VDS =0V,VGS=±20V
±10
μA
Gate Threshold Voltage
VGS(th)
VDS =VGS, ID =250μA
0.5
1.5
V
Static Drain-Source On-Resistance
RDS(ON)
VGS=5V, ID =0.05A
7.5
Ω
VGS=10V, ID =0.1A
7.5
Ω
Diode Forward Voltage
VSD
0.72
1
V
IS
0.2
A
14.5
40
pF
5.0
pF
0.25
5
pF
0.23
0.05
0.06
Maximum Body-Diode Continuous
Current
DYNAMIC PARAMETERS
Input Capacitance
CISS
Output Capacitance
CDSS
Reverse Transfer Capacitance
CRSS
Total Gate Charge
Qg
Gate-to-Source Charge
Qgs
Gate-to-Drain(Miller) Charge
Qgd
Rev.06.6
VGS=0V, VDS =25V,
f=1MHz
ID =0.2A, VDS =6V,
VGS =4.5V
1
nC
www.prisemi.com
N-Channel MOSFET
PNMT60V02E
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Units
ns
ns
SWITCHING PARAMETERS
Turn-On Delay Time
td(on)
Turn-Off Delay Time
td(off)
Reverse recovery time
trr
Reverse recovery charge
Qrr
Reverse recovery current
Irrm
VDS=30V, VGS =10V,
RG=25Ω, RL=150Ω
ID =0.2A
IF=0.2A, dI/dt=100A/μs
11.3
nS
7.5
nC
0.66
A
Absolute maximum rating@25℃
Rating
Symbol
Value
Units
Drain-Source Voltage
VDS
60
V
Gate-Source Voltage
VGS
±20
V
Continuous
ID
0.18
A
Pulsed
ID
0.36
A
TA=25℃
PD
150
mW
VESD(G-S)
1000
V
Drain Current
Total Power Dissipation
Gate to Source ESD:HBM_C=100pF,R=1.5KΩ
Rev.06.6
2
www.prisemi.com
N-Channel MOSFET
PNMT60V02E
Typical Characteristics
1.0
1.0
0.8
ID – Drain Current (A)
T=25°C
VGS=6.0V
0.8
0.6
VGS=4.5V
0.4
0.2
T=-55°C
0.6
0.4
T=125°C
0.2
VGS=3.5V
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
0.0
0.5
1.0
2.5
3.0
Fig 2. Transfer Characteristics
80
6
VGS=3.0V
5
Ciss
(pF)
60
4
C – Capacitance
(Ω)
2.0
VGS – Gate to Source Voltage (V)
VDS – Drain Source Voltage (V)
Fig 1. Output Characteristics
rDS(on) – On-Resistance
1.5
VGS=7.0V
3
2
VGS=11.5V
40
COss
1
CRss
0.4
0.6
0.8
8
12
16
Fig 3. On-Resistance vs. Drain Current
Rev.06.6
4
Fig 4. Capacitance
3
www.prisemi.com
N-Channel MOSFET
PNMT60V02E
Product dimension(SOT-23)
A
D(3)
C
θ
B
G(1)
D
H
S(2)
F
G
E
J
L
K
Millimeters
Inches
Dim
Rev.06.6
MIN
MAX
MIN
MAX
A
2.80
3.00
0.1102
0.1197
B
1.20
1.40
0.0472
0.0551
C
2.10
2.50
0.0830
0.0984
D
0.89
1.02
0.0350
0.0401
E
0.45
0.60
0.0177
0.0236
F
1.78
2.04
0.0701
0.0807
G
0.085
0.177
0.0034
0.0070
H
0.45
0.60
0.0180
0.0236
J
0.37
0.50
0.0150
0.0200
K
0.89
1.11
0.0350
0.0440
L
0.013
0.100
0.0005
0.0040
θ
0°
10°
0°
10°
4
www.prisemi.com
N-Channel MOSFET
PNMT60V02E
IMPORTANT NOTICE
and
are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi
reserves the right to make changes without further notice to any products herein. Prisemi makes
no warranty, representation or guarantee regarding the suitability of its products for any particular
purpose, nor does Prisemi assume any liability arising out of the application or use of any
product or circuit, and specifically disclaims any and all liability, including without limitation
special, consequential or incidental damages. “Typical” parameters which may be provided in
Prisemi data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be
validated for each customer application by customer’s technical experts. Prisemi does not
convey any license under its patent rights nor the rights of others. The products listed in this
document are designed to be used with ordinary electronic equipment or devices, Should you
intend to use these products with equipment or devices which require an extremely high level of
reliability and the malfunction of with would directly endanger human life (such as medical
instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety
devices), please be sure to consult with our sales representative in advance.
Website: http://www.prisemi.com
For additional information, please contact your local Sales Representative.
©Copyright 2009, Prisemi Electronics
is a registered trademark of Prisemi Electronics.
All rights are reserved.
Rev.06.6
5
www.prisemi.com
很抱歉,暂时无法提供与“PNMT60V02E”相匹配的价格&库存,您可以联系我们找货
