HV1C157M0607PZ
HV1C157M0607PZ
    HONOR(荣誉)
    SMD,D6.3xL7.7mm
HV1C157M0607PZ 数据手册
SOLID POLYMER ELECTROLYTIC CAPACITOR 导电性高分子固体铝电解电容 HV series Low Leakage Current Features(特点) «Designed for surface mounting on high density PC board ,Applicable to automatic mounting machine uing emboss carrier tape 用于高密度表面贴装,吸塑载带封装成盘后用于自动机贴装 «Low ESR at high frequency range & Large permissible ripple current (在高频范围内的低ESR ,允许大纹波电流) Specifications (产品规格) item 项目 Operating Temperature Range 工作温度范围 Rated Voltage Range 额定电压范围 Performance Characteristics 性能 特点 -55~+105°C 2.5~80vdc Capacitance Tolerance(容量公差) Leakage Current(+20°C max) 漏电流 Dissipation Factor(损耗系数) tanδ at 20°C,120Hz ±20%(120Hz,+20°C) ≤0.2cv(uA.After 2 minutes) 充电2分钟后漏电≤0.2vc Not to exceed the value specified 不超过指定值 Not to exceed the value specified 不超过指定值 ESR(100KHz) Capacitance Change Leakage Current Endurance(耐久性) 105°C,2000H at rated voltage 105°C 2000h 不超过额定电压 ESR Dissipation Factor Capacitance Change Leakage Current Moisture Resistance(耐湿性) Stored at 60°C,RH90~95% 2000H 存放在60°C,RH90~95% 2000h ESR Dissipation Factor Within ±20% of the value before test 测试前的值的±20%以内 Not to exceed the value specified 不超过指定值 Not to exceed 150% of the value specified 不超过指定值的150% Not to exceed 150% of the value specified 不超过指定值的150% Within ±20% of the value before test 测试前的值的±20%以内 Not to exceed the value specified 不超过指定值 Not to exceed 150% of the value specified 不超过指定值的150% Not to exceed 150% of the value specified 不超过指定值的150% Srequency Coefficient For Ripple Current (纹波电流的频率系数) Frequency Coefficient 120Hz≤freq.
HV1C157M0607PZ 价格&库存
很抱歉,暂时无法提供与“HV1C157M0607PZ”相匹配的价格&库存,您可以联系我们找货
HV1C157M0607PZ
    • 5+0.94618
    • 50+0.76089
    • 150+0.68147
    • 1000+0.55589
    • 2000+0.51177
    • 5000+0.48530
    库存:18
