CGA3EAC0G2A472JT000E 数据手册
AUT-ESD-002
DELIVERY SPECIFICATION
SPEC. No. A-ESD-d
D A T E : Feb, 2020
To
Non-Controlled Copy
Upon the acceptance of this
spec. previous spec.
(C2012-0629) shall be abolished.
CUSTOMER’S PRODUCT NAME
TDK PRODUCT NAME
MULTILAYER CERAMIC CHIP CAPACITORS
Bulk and Tape packaging 【RoHS compliant】
CGA3EA ESD Protection Series
Please return this specification to TDK representatives with your signature.
If orders are placed without returned specification, please allow us to judge that specification is
accepted by your side.
RECEIPT CONFIRMATION
DATE:
YEAR
MONTH
DAY
Test conditions in this specification based on AEC-Q200 for automotive application.
TDK Corporation
Sales
Electronic Components
Sales & Marketing Group
APPROVED
Person in charge
Engineering
Electronic Components Business Company
Ceramic Capacitors Business Group
APPROVED
CHECKED
Person in charge
AUT-ESD-002
■CATALOG NUMBER CONSTRUCTION
CGA
(1)
3
(2)
E
A
(3)
(4)
NP0
2A
(5)
(6)
(1) Series
(7)
J
(8)
080
(9)
A
(10)
C
(11)
(7) Nominal capacitance (pF)
(2) Dimensions L x W (mm)
Dimensions
EIA
Length
code
3
103
CC0603
1.60
Width
Terminal
width
0.80
0.20
The capacitance is expressed in three digit
codes and in units of pico Farads (pF). The first
and second digits identify the first and second
significant figures of the capacitance. The third
digit identifies the multiplier. R designates a
decimal point.
(3) Thickness code
Code
Thickness
E
0.80mm
(Example)
(4) Function identification code
Symbol
Condition
A
ESD protection
(8) Capacitance tolerance
Code
Tolerance
J
±5%
(5) Temperature characteristics
Temperature
Capacitance
characteristics change
C0G
0±30 ppm/°C
NP0
0±30 ppm/°C
0R5 = 0.5pF
101 = 100pF
225 = 2,200,000pF = 2.2μF
(9) Thickness
Code
Thickness
080
0.80mm
Temperature
range
-55 to +125℃
-55 to +150℃
(10) Packaging style
Code
Style
A
178mm reel, 4mm pitch
(6) Rated voltage (DC)
Code
Voltage (DC)
2A
100V
(11) Special reserved code
Code
Tolerance
A,C
TDK internal code
—1—
AUT-ESD-002
SCOPE
This delivery specification shall be applied to Multilayer ceramic chip capacitors to be delivered to
PRODUCTION PLACES
Production places defined in this specification shall be TDK Corporation, TDK(Suzhou)Co.,Ltd
and TDK Components U.S.A.,Inc.
PRODUCT NAME
The name of the product to be defined in this specifications shall be CGA3EA○○○2A□□□×.
REFERENCE STANDARD
JIS C 5101-1:2010
C 5101-21:2014
Fixed capacitors for use in electronic equipment-Part 1: Generic specification
Fixed capacitors for use in electronic equipment-Part21 : Sectional specification
: Fixed surface mount multilayer capacitors of ceramic dielectric,Class1
C 0806-3:2014
Packaging of components for automatic handling - Part 3: Packaging of
surface mount components on continuous tapes
JEITA RCR-2335 C 2014 Safety application guide for fixed ceramic capacitors for use in electronic
equipment
CONTENTS
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
CODE CONSTRUCTION
OPERATING TEMPERATURE RANGE
STORING CONDITION AND TERM
INDUSTRIAL WASTE DISPOSAL
PERFORMANCE
INSIDE STRUCTURE AND MATERIAL
PACKAGING
SETTING UP FOR ESD TEST
CAUTION
TAPE PACKAGING SPECIFICATION
When the mistrust in the spec arises, this specification is given priority. And it will be confirmed by written
spec change after conference of both posts involved.
This specification warrants the quality of the ceramic chip capacitor. Capacitors should be evaluated or
confirmed a state of mounted on your product.
If the use of the capacitors goes beyond the bounds of this specification, we can not afford to guarantee.
Division
Date
SPEC. No.
Feb, 2020
A-ESD-d
—2—
AUT-ESD-002
1. CODE CONSTRUCTION
(Example)
CGA
(1)
3
(2)
E
(3)
A
(4)
C0G
(5)
2 A
(6)
103
(7)
(1) Series
J
(8)
Symbol
T
(9)
〇〇〇〇
(10)
Series
Ceramic chip capacitor for
CGA
Terminal electrode
(2) Case size
L
B
W
G
B
T
Internal electrode
Ceramic dielectric
Symbol
3
Case size
Dimensions (Unit : mm)
TDK(EIA style)
L
W
T
B
G
CGA3(CC0603)
1.60±0.10
0.80±0.10
0.80±0.10
0.20 min.
0.30 min.
(3) Thickness
(4) Identification for ESD capacitor
* Details are shown in Table 1 No.16 at 5.PERFORMANCE.
Symbol
Dimension(mm)
E
0.80
Symbol
Identification
A
ESD capacitor
Symbol
Rated Voltage
2A
DC 100 V
※ As for applied ESD level, please refer to detail
page on TDK Web.
(5) Temperature Characteristics
* Details are shown in Table 1 No.6 at 5.PERFORMANCE.
(6) Rated Voltage
(Example)
(7) Rated Capacitance
Stated in three digits and in units of pico farads (pF).
The first and Second digits identify the first and
second significant figures of the capacitance,
the third digit identifies the multiplier.
(9) Packaging
(10) TDK internal code
―3―
Symbol
1 03
Rated
Capacitance
10,000 pF
Symbol
Tolerance
J
± 5%
Symbol
Packaging
B
Bulk
T
Taping
AUT-ESD-002
2. OPERATING TEMPERATURE RANGE
T.C.
Min. operating
Temperature
Max. operating
Temperature
Reference
Temperature
C0G
-55°C
125°C
25°C
NP0
-55°C
150°C
25°C
3. STORING CONDITION AND TERM
Storing temperature
Storing humidity
Storing term
5~40°C
20~70%RH
Within 6 months
upon receipt.
4. INDUSTRIAL WASTE DISPOSAL
Dispose this product as industrial waste in accordance with the Industrial Waste Law.
―4―
AUT-ESD-002
5. PERFORMANCE
Table 1
Item
No.
Performance
Test or inspection method
1
External Appearance
No defects which may affect
performance.
Inspect with magnifying glass(3×)
2
Insulation Resistance
10,000MΩ min.
Measuring voltage:Rated voltage
Voltage application time:60s.
3
Voltage Proof
Withstand test voltage without
insulation breakdown or other
damage.
Apply voltage : 3 × rated voltage
Voltage application time : 1s.
Charge/discharge current : 50mA or
lower
4
Capacitance
Within the specified tolerance.
5
Q
6
Temperature
Characteristics
of Capacitance
Please refer to detail page on
TDK Web.
T.C.
Temperature Coefficient
(ppm/°C)
C0G
0 ± 30
NP0
0 ± 30
Rated
Capacitance
Measuring
frequency
1000pF
1MHz±10%
Over
1000pF
1kHz±10%
Measuring
voltage
0.5 ~ 5V
rms.
See No.4 in this table for measuring
condition.
Temperature coefficient shall be
calculated based on values at 25°C and
85°C temperature.
Measuring temperature below 25°C
shall be -10°C and -25°C.
Capacitance Within ± 0.2% or
± 0.05pF,
drift
whichever larger.
7
Robustness of
Terminations
No sign of termination coming off,
breakage of ceramic, or other
abnormal signs.
Reflow solder the capacitors on a
P.C.Board shown in Appendix 2.
Apply a pushing force gradually at the
center of a specimen in a horizontal
direction of P.C.board.
Pushing force : 17.7N
Holding time : 10±1s.
17.7N
Capacitor
―5―
P.C.Board
AUT-ESD-002
(continued)
Item
No.
8
Bending
Performance
No mechanical damage.
Reflow solder the capacitor on a
P.C.Board shown in Appendix1.
F
R230
2
45
45
(Unit:mm)
9
10
Solderability
Resistance
to solder
heat
New solder to cover over 75% Solder :
Sn-3.0Ag-0.5Cu or
of termination.
Sn-37Pb
25% may have pin holes or
rough spots but not concentrated Flux :
Isopropyl alcohol (JIS K
in one spot.
8839) Rosin (JIS K 5902)
Ceramic surface of A sections
25% solid solution.
shall not be exposed due to
melting or shifting of termination Solder temp. : 245±5°C (Sn-3.0Ag-0.5Cu)
material.
235±5°C (Sn-37Pb)
A section
No cracks are allowed and
External
appearance terminations shall be covered
at least 60% with new solder.
Capacitance
Dwell time :
3±0.3s.(Sn-3.0Ag-0.5Cu)
2±0.2s.(Sn-37Pb)
Solder
position :
Until both terminations
are completely soaked.
Solder :
Sn-3.0Ag-0.5Cu or
Sn-37Pb
Flux :
25% solid solution.
Change from the
Characteristics
value before test
C0G
NP0
±2.5%
Solder temp. : 260±5°C
Q
Meet the initial spec.
Dwell time :
10±1s.
Insulation
Resistance
Solder
position :
Voltage
proof
No insulation breakdown or
other damage.
―6―
Pre-heating : Temp. ― 110~140°C
Time ― 30~60s.
Leave the capacitors in ambient condition
for 6~24h before measurement.
AUT-ESD-002
(continued)
No.
11
Item
Vibration
Performance
External
appearance
Capacitance
Q
12
Characteristics
Change from the
value before test
C0G
NP0
±2.5%
Temperature External
cycle
appearance
Capacitance
Characteristics
C0G
NP0
Q
Change from the
value before test
Please contact
with our sales
representative.
Applied force : 5G max.
Frequency : 10~2,000Hz
Reciprocating sweep time : 20 min.
Cycle : 12 cycles in each 3 mutually
perpendicular directions.
P.C.Board shown in Appendix 2 before
testing.
Expose the capacitors in the condition
step1 through step 4 listed in the
following table.
Temp. cycle:1,000 cycles
Step
Temperature(°C) Time (min.)
1
Min. operating
temp. ±3
30 ± 3
2
Ambient Temp.
2~5
3
Max. operating
temp. ±2
30 ± 2
4
Ambient Temp.
2~5
Insulation
Resistance
Voltage
proof
No insulation breakdown or other
damage.
As for Min./ Max. operating temp.,
please refer to "3.OPERATING
TEMPERATURE RANGE".
testing.
13
Moisture
Resistance
(Steady
State)
External
appearance
Capacitance
Characteristics
C0G
NP0
Q
Change from the
value before test
Please contact
with our sales
representative.
350 min.
Insulation
1,000MΩ min.
Resistance
―7―
Test temp.:40±2°C
Test humidity:90~95%RH
Test time:500 +24,0h
P.C.Board shown in Appendix2 before
testing.
AUT-ESD-002
(continued)
Item
No.
14
Moisture
Resistance
Performance
External
appearance
Capacitance
Characteristics
C0G
NP0
Q
Insulation
Resistance
15
Life
Change from the value
before test
Please contact
with our sales
representative.
testing.
500MΩ min.
External
appearance
Characteristics
C0G
NP0
before test
Please contact
with our sales
representative.
Test temp.:Maximum operating
temperature±2°C
Applied voltage:Please contact with
our sales representative.
Test time:1,000 +48,0h
Charge/discharge current:50mA or
lower
Q
350 min.
Insulation
Resistance
1,000MΩ min.
ESD
lower
200 min.
Capacitance
16
Test temp.:85±2°C
Test humidity:85%RH
Applied voltage:Rated voltage
testing.
Withstand ESD voltage without insulation Reflow Solder the capacitors on a
breakdown.
P.C.Board shown in Appendix3 before
testing.
Rc
Voltage
Source
Rd
Cs
Test
specimen
Rc:Charge current limit resistor
Rd:Discharge resistor
Cs:Energy storage capacitor
ESD gun
―8―
Circuit condition:IEC 61000-4-2
(Cs:150pF / Rd:330Ω)
Test method:Direct contact
Number of ESD pulse:±10 times
to detail page on TDK Web.
After each ESD pulse, dissipation of
residual charge shall be done with
applying 1MΩ resistance for 1 sec min.
AUT-ESD-002
Appendix1
Appendix2
P.C.Board for bending test
P.C. Board for reliability test
100
100
c
b
40
b a
Solder resist
a
Solder resist
40
Copper
1.0
c
Copper
Appendix3
P.C. Board for ESD test
b
a
100.5
c
36
Copper
Solder resist
30.5
Copper
Appendix 1, 2
Case size
1. Material : Glass Epoxy
(As per JIS C6484 GE4)
TDK(EIA style)
2. Thickness:1.6mm
CGA3(CC0603)
Copper(Thickness:0.035mm)
Solder resist
(Unit : mm)
a
b
c
1.0
3.0
1.2
Appendix 3 (ESD TEST)
Case size
a
TDK(EIA style)
CGA3(CC0603)
―9―
1.0
(Unit : mm)
b
c
3.0
0.75
AUT-ESD-002
6. INSIDE STRUCTURE AND MATERIAL
3
4
5
2
1
No.
NAME
MATERIAL
1
Dielectric
CaZrO 3
2
Electrode
Nickel (Ni)
3
Copper (Cu)
Termination
4
Nickel (Ni)
5
Tin (Sn)
7. PACKAGING
Packaging shall be done to protect the components from the damage during transportation and
storing, and a label which has the following information shall be attached.
7.1 Each plastic bag for bulk packaging contains 1000pcs. And the minimum quantity for
Bulk packaging is 1000pcs.
7.2 Tape packaging is as per 11. TAPE PACKAGING SPECIFICATION.
1)
2)
3)
4)
Inspection No.
TDK P/N
Customer's P/N
Quantity
*Composition of Inspection No.
F 9 A – 23 – 001
(a) (b) (c)
(d)
(e)
Line code
Last digit of the year
Month and A for January and B for February and so on. (Skip I)
Inspection Date of the month.
Serial No. of the day
Example
(a)
(b)
(c)
(d)
(e)
*Composition of new Inspection No.
(Will be implemented on and after May 1, 2019)
Example
I
F
9
E
(a) (b) (c) (d)
2 3
A 0
0 1
(e)
(f)
(g)
(a) Prefix
(b) Line code
(c) Last digit of the year
(d) Month and A for January and B for February and so on. (Skip I)
(e) Inspection Date of the month.
(f) Serial No. of the day(00 ~ ZZ)
(g) Suffix(00 ~ ZZ)
* It is planned to shift to the new inspection No. on and after May 2019, but the implementation timing
may be different depending on shipment bases.
Until the shift is completed, either current or new composition of inspection No. will be applied.
― 10 ―
AUT-ESD-002
8. SETTING UP FOR ESD TEST
ESD Gun
(150pF/ 330Ω)
Horizontal coupling plane
(HCP)
Non-conductive table
(Wooden)
Cable for dissipation of
residual charge (1MΩ)
Test board
470kΩ
470kΩ
Power supply
Ground reference plane
(GRP)
― 11 ―
Resistor
AUT-ESD-002
9. CAUTION
No.
1
Process
Operating
Condition
(Storage, Use,
Transportation)
Condition
1-1. Storage, Use
1) The capacitors must be stored in an ambient temperature of 5 to 40°C with a relative
humidity of 20 to 70%RH. The products should be used within 6 months upon receipt.
2) The capacitors must be operated and stored in an environment free of dew
condensation and these gases such as Hydrogen Sulphide, Hydrogen Sulphate,
Chlorine, Ammonia and sulfur.
3) Avoid storing in sun light and falling of dew.
4) Do not use capacitors under high humidity and high and low atmospheric pressure
which may affect capacitors reliability.
5) Capacitors should be tested for the solderability when they are stored for long time.
2
Circuit design
△Caution
E
A
1-2. Handling in transportation
In case of the transportation of the capacitors, the performance of the capacitors
may be deteriorated depending on the transportation condition.
(Refer to JEITA RCR-2335C 9.2 Handling in transportation)
2-1. Operating temperature
Operating temperature should be followed strictly within this specification,
especially be careful with maximum temperature.
1) Do not use capacitors above the maximum allowable operating temperature.
2) Surface temperature including self heating should be below maximum operating
temperature.
(Due to dielectric loss, capacitors will heat itself when AC is applied. Especially at
high frequencies around its SRF, the heat might be so extreme that it may
damage itself or the product mounted on. Please design the circuit so that the
maximum temperature of the capacitors including the self heating to be below the
maximum allowable operating temperature. Temperature rise at capacitor surface
shall be below 20°C)
3) The electrical characteristics of the capacitors will vary depending on the
temperature. The capacitors should be selected and designed in taking the
temperature into consideration.
2-2. Operating voltage
1) Operating voltage across the terminals should be below the rated voltage.
When AC and DC are super imposed, V 0-P must be below the rated voltage.
――― (1) and (2)
AC or pulse with overshooting, V P-P must be below the rated voltage.
――― (3), (4) and (5)
When the voltage is started to apply to the circuit or it is stopped applying, the
irregular voltage may be generated for a transit period because of resonance or
switching. Be sure to use the capacitors within rated voltage containing these
Irregular voltage.
R
R
Voltage
(1) DC voltage
Positional
Measurement V 0-P
(Rated voltage)
R
R
(2) DC+AC voltage
V P-P
R
R
V 0-P
R
Voltage
(3) AC voltage
(4) Pulse voltage (A) (5) Pulse voltage (B)
Positional
V
Measurement P-P
(Rated voltage)
V P-P
R
R
— 12 —
AUT-ESD-002
No.
2
Process
Circuit design
! Caution
A
E
Condition
2) Even below the rated voltage, if repetitive high frequency AC or pulse is applied,
the reliability of the capacitors may be reduced.
A
3) The effective capacitance will vary depending on applied DC and AC voltages.
The capacitors should be selected and designed in taking the voltages into
consideration.
2-3. Frequency
When the capacitors (Class 2) are used in AC and/or pulse voltages, the
capacitors may vibrate themselves and generate audible sound.
3
Designing
P.C.board
The amount of solder at the terminations has a direct effect on the reliability of the
capacitors.
1) The greater the amount of solder, the higher the stress on the chip capacitors,
and the more likely that it will break. When designing a P.C.board, determine the
shape and size of the solder lands to have proper amount of solder on the
terminations.
2) Avoid using common solder land for multiple terminations and provide individual
solder land for each terminations.
3) Size and recommended land dimensions.
Chip capacitors
C
Solder land
Solder resist
A
B
Flow soldering(mm)
Case size
Symbol
A
CGA3 (CC0603)
B
0.8 ~ 1.0
C
0.6 ~ 0.8
0.7 ~ 1.0
Reflow soldering (mm)
Case size
CGA3 (CC0603)
Symbol
A
0.6 ~ 0.8
B
0.6 ~ 0.8
C
0.6 ~ 0.8
— 13 —
AUT-ESD-002
No.
3
Process
Designing
P.C.board
Condition
4) Recommended chip capacitors layout is as following.
Disadvantage against
bending stress
Advantage against
bending stress
Perforation or slit
Perforation or slit
Break P.C.board with
mounted side up.
mounted side down.
Mount perpendicularly to
perforation or slit
Mount in parallel with
perforation or slit
Mounting
face
Perforation or slit
Perforation or slit
Chip
arrangement
(Direction)
Closer to slit is higher stress
ℓ1
Away from slit is less stress
ℓ
R
2
R
Distance
from slit
( ℓ1 < ℓ2 )
R
— 14 —
R
R
R
R
R
( ℓ 1< ℓ 2 )
R
R
R
R
R
R
AUT-ESD-002
No.
Process
3
Designing
P.C.board
Condition
5) Mechanical stress varies according to location of chip capacitors on the P.C.board.
E
D
Perforation
C
B
A
Slit
The stress in capacitors is in the following order.
A>B=C>D>E
6) Layout recommendation
Example
Use of common
solder land
Soldering with
chassis
Use of common
solder land with
other SMD
Lead wire Chassis
Chip
Solder
land
Excessive solder
Solder
Need to
avoid
Excessive solder
PCB Adhesive
Solder land
ℓ1
Missing
solder
Lead wire
Solder land
Solder resist
Solder resist
Recommendation
Solder resist
ℓ2
ℓ 2 >ℓ 1
— 15 —
AUT-ESD-002
No.
4
Process
Mounting
Condition
4-1. Stress from mounting head
If the mounting head is adjusted too low, it may induce excessive stress in the chip
capacitors to result in cracking. Please take following precautions.
1) Adjust the bottom dead center of the mounting head to reach on the P.C.board
surface and not press it.
2) Adjust the mounting head pressure to be 1 to 3N of static weight.
3) To minimize the impact energy from mounting head, it is important to provide
support from the bottom side of the P.C.board.
See following examples.
Not recommended
Recommended
Crack
Single sided
mounting
Support pin
Double-sides
mounting
Solder
peeling
Crack
Support pin
When the centering jaw is worn out, it may give mechanical impact on the capacitors
to cause crack. Please control the close up dimension of the centering jaw and
provide sufficient preventive maintenance and replacement of it.
— 16 —
AUT-ESD-002
Condition
5-1. Flux selection
Flux can seriously affect the performance of capacitors. Confirm the following to
select the appropriate flux.
1) It is recommended to use a mildly activated rosin flux (less than 0.1wt% chlorine).
Strong flux is not recommended.
2) Excessive flux must be avoided. Please provide proper amount of flux.
3) When water-soluble flux is used, enough washing is necessary.
5-2. Recommended soldering profile by various methods
Reflow soldering
Wave soldering
Soldering
Natural cooling
Soldering
Preheating
Natural cooling
Peak
Temp
Temp..(°C)
ΔT
Preheating
Peak
Temp
Temp.(°C)
Process
Soldering
Over 60 sec.
Over 60 sec.
ΔT
Over 60 sec.
Peak Temp time
Peak Temp time
Manual soldering
(Solder iron)
Peak
Temp
Temp..(°C)
No.
5
ΔT
Preheating
3sec. (As short as possible)
※ As for peak temperature of manual soldering, please refer“5-6. Solder repair by solder iron”.
5-3. Recommended soldering peak temp and peak temp duration
Temp./Duration
Wave soldering
Reflow soldering
Peak temp(°C)
Duration(sec.)
Peak temp(°C)
Duration(sec.)
Sn-Pb Solder
250 max.
3 max.
230 max.
20 max.
Lead Free Solder
260 max.
5 max.
260 max.
10 max.
Solder
Recommended solder compositions
Lead Free Solder : Sn-3.0Ag-0.5Cu
Sn-Pb solder : Sn-37Pb
— 17 —
AUT-ESD-002
No.
5
Process
Soldering
Condition
5-4. Avoiding thermal shock
1)
2)
Preheating condition
Soldering
Temp. (°C)
Wave soldering
ΔT ≦ 150
Reflow soldering
ΔT ≦ 150
Manual soldering
ΔT ≦ 150
Cooling condition
Natural cooling using air is recommended. If the chips are dipped into a solvent for
cleaning, the temperature difference (ΔT) must be less than 100°C.
5-5. Amount of solder
Excessive solder will induce higher tensile force in chip capacitors when
temperature changes and it may result in chip cracking. In sufficient solder may
detach the capacitors from the P.C.board.
Higher tensile force in
chip capacitors to cause
crack
Excessive
solder
Maximum amount
Minimum amount
Adequate
Low robustness may
cause contact failure or
chip capacitors come off
the P.C.board.
Insufficient
solder
1) Selection of the soldering iron tip
Tip temperature of solder iron varies by its type, P.C.board material and solder land
size. The higher the tip temperature, the quicker the operation. However, heat
shock may cause a crack in the chip capacitors.
Please make sure the tip temp. before soldering and keep the peak temp and time
in accordance with following recommended condition.
Recommended solder iron condition (Sn-Pb Solder and Lead Free Solder)
Temp. (°C)
Duration (sec.)
Wattage (W)
Shape (mm)
350 max.
3 max.
20 max.
φ3.0 max.
* Please preheat the chip capacitors with the condition in 5-4 to avoid the thermal shock.
2) Direct contact of the soldering iron with ceramic dielectric of chip capacitors may
cause crack. Do not touch the ceramic dielectric and the terminations by solder
iron.
— 18 —
AUT-ESD-002
No.
Process
5
Soldering
Condition
5-7.Soldering rework using spot heater
Heat stress during rework may possibly be reduced by using a spot heater
(also called a “blower”) rather than a soldering iron.
It is applied only to adding solder in the case of insufficient solder amount.
1) Reworking using a spot heater may suppress the occurrence of cracks in the
capacitor compared to using a soldering iron. A spot heater can heat up a capacitor
uniformly with a small heat gradient which leads to lower thermal
stress caused by quick heating and cooling or localized heating.
Moreover, where ultra-small capacitors are mounted close together on a printed
circuit board, reworking with a spot heater can eliminate the risk of direct contact
between the tip of a soldering iron and a capacitor.
2) Rework condition
If the blower nozzle of a spot heater is too close to a capacitor, a crack in the
capacitor may occur due to heat stress. Below are recommendations for avoiding
such an occurrence.
Keep more than 5mm between a capacitor and a spot heater nozzle.
The blower temperature of the spot heater shall be lower than 400°C.
The airflow shall be set as weak as possible.
The diameter of the nozzle is recommended to be 2mm(one-outlet type).The size is
standard and common.
Duration of blowing hot air is recommended to be 10s or less, considering surface
area of the capacitor and melting temperature of solder.
The angle between the nozzle and the capacitor is recommended to be 45degrees
in order to work easily and to avoid partial area heating.
As is the case when using a soldering iron, preheating reduces thermal stress on
capacitors and improves operating efficiency.
・Recommended rework condition(Consult the component manufactures for details.)
Distance from nozzle
5mm and over
Nozzle angle
45degrees
Nozzle temp.
400°C and less
Set as weak as possible
(The airflow shall be the minimum value necessary for
solder to melt in the conditions mentioned above.)
Airflow
Nozzle diameter
φ2mm(one-outlet type)
Blowing duration
10s and less
・Example of recommended spot heater use
One-outlet type nozzle
Angle : 45degrees
3) Amount of solder should be suitable to from a proper fillet shape.
Excess solder causes mechanical and thermal stress on a capacitor and
results in cracks. Insufficient solder causes weak adherence of the capacitor to
the substrate and may result in detachment of a capacitor and deteriorate
reliability of the printed wiring board.
See the example of appropriate solder fillet shape for 5-5.Amount of solder.
— 19 —
AUT-ESD-002
No.
Process
5
Soldering
Condition
5-8. Sn-Zn solder
Sn-Zn solder affects product reliability.
Please contact TDK in advance when utilize Sn-Zn solder.
5-9. Countermeasure for tombstone
The misalignment between the mounted positions of the capacitors and the land
patterns should be minimized. The tombstone phenomenon may occur especially
the capacitors are mounted (in longitudinal direction) in the same direction of the
reflow soldering.
(Refer to JEITA RCR-2335C Annex A (Informative) Recommendations to prevent
the tombstone phenomenon)
6
Cleaning
1) If an unsuitable cleaning fluid is used, flux residue or some foreign articles may
stick to chip capacitors surface to deteriorate especially the insulation resistance.
2) If cleaning condition is not suitable, it may damage the chip capacitors.
2)-1. Insufficient washing
(1) Terminal electrodes may corrode by Halogen in the flux.
(2) Halogen in the flux may adhere on the surface of capacitors, and lower the
(3) Water soluble flux has higher tendency to have above mentioned problems (1)
and (2).
2)-2. Excessive washing
When ultrasonic cleaning is used, excessively high ultrasonic energy output
can affect the connection between the ceramic chip capacitor's body and the
terminal electrode. To avoid this, following is the recommended condition.
Power : 20W/ ℓ max.
Frequency : 40kHz max.
Washing time : 5 minutes max.
2)-3. If the cleaning fluid is contaminated, density of Halogen increases, and it may
bring the same result as insufficient cleaning.
7
Coating and
1) When the P.C.board is coated, please verify the quality influence on the product.
molding of the
P.C.board
2) Please verify carefully that there is no harmful decomposing or reaction gas
emission during curing which may damage the chip capacitors.
3) Please verify the curing temperature.
8
Handling after
chip mounted
! Caution
A
E
A
1) Please pay attention not to bend or distort the P.C.board after soldering in handling
otherwise the chip capacitors may crack.
Bend
— 20 —
Twist
AUT-ESD-002
No.
8
Process
Handling after
chip mounted
! Caution
A
E
A
Condition
2) Printed circuit board cropping should not be carried out by hand, but by using the
proper tooling. Printed circuit board cropping should be carried out using a board
cropping jig as shown in the following figure or a board cropping apparatus to
prevent inducing mechanical stress on the board.
(1)Example of a board cropping jig
Recommended example: The board should be pushed from the back side,
close to the cropping jig so that the board is not bent and the stress applied to
the capacitor is compressive.
Unrecommended example: If the pushing point is far from the cropping jig and
the pushing direction is from the front side of the board, large tensile stress is
applied to the capacitor, which may cause cracks.
Outline of jig
Recommended
V-groove
Printed
circuit
board
Unrecommended
Direction of
load
Printed
circuit
board
Direction
of load
Load point
Components
Printed
circuit
board
Components
Load point
Slot
Board
cropping jig
V-groove
V-groove
Slot
Slot
(2)Example of a board cropping machine
An outline of a printed circuit board cropping machine is shown below. The
top and bottom blades are aligned with one another along the lines with the
V-grooves on printed circuit board when cropping the board.
Unrecommended example: Misalignment of blade position between top and
bottom, right and left, or front and rear blades may cause a crack in the
capacitor.
Outline of machine
Principle of operation
Top blade
Top
blade
Bottom blade
V-groove
Cross-section diagram
Top blade
Bottom blade
V-groove
Unrecommended
Recommended
Top-bottom
misalignment
Left-right
misalignment
Front-rear
misalignment
Top blade
Top blade
Top blade
Bottom blade
Bottom blade
Bottom blade
Top blade
Board
Bottom blade
— 21 —
AUT-ESD-002
No.
8
Process
Handling after
chip mounted
△Caution
A
E
A
Condition
3) When functional check of the P.C.board is performed, check pin pressure tends
to be adjusted higher for fear of loose contact. But if the pressure is excessive
and bend the P.C.board, it may crack the chip capacitors or peel the terminations
off. Please adjust the check pins not to bend the P.C.board.
Item
Not recommended
Recommended
Termination
peeling
Support pin
Board
bending
Check pin
Check pin
9
Handling of loose
chip capacitors
1) If dropped the chip capacitors may crack. Once dropped do not use it.
Especially, the large case sized chip capacitors are tendency to have cracks
easily, so please handle with care.
Crack
Floor
2) Piling the P.C.board after mounting for storage or handling, the corner of the P.C.
board may hit the chip capacitors of another board to cause crack.
P.C.board
Crack
10
Capacitance aging
The capacitors have aging in the capacitance. They may not be used in precision
time constant circuit. In case of the time constant circuit, the evaluation should be
done well.
11
Estimated life and
estimated failure
rate of capacitors
As per the estimated life and the estimated failure rate depend on the temperature
and the voltage. This can be calculated by the equation described in JEITA
RCR-2335C Annex F(Informative) Calculation of the estimated lifetime and the
estimated failure rate (Voltage acceleration coefficient : 3 multiplication rule,
Temperature acceleration coefficient : 10°C rule)
The failure rate can be decreased by reducing the temperature and the voltage but
they will not be guaranteed.
— 22 —
AUT-ESD-002
No.
12
Process
Caution during
operation of
equipment
Condition
1) A capacitor shall not be touched directly with bare hands during operation in
order to avoid electric shock.
Electric energy held by the capacitor may be discharged through the human
body when touched with a bare hand.
Even when the equipment is off, a capacitor may stay charged. The capacitor
should be handled after being completely discharged using a resistor.
2) The terminals of a capacitor shall not be short-circuited by any accidental
contact with a conductive object. A capacitor shall not be exposed to a
conductive liquid such as an acid or alkali solution. A conductive object or liquid,
such as acid and alkali, between the terminals may lead to the breakdown of a
capacitor due to short circuit
3) Confirm that the environment to which the equipment will be exposed during
transportation and operation meets the specified conditions. Do not to use the
equipment in the following environments.
(1) Environment where a capacitor is spattered with water or oil
(2) Environment where a capacitor is exposed to direct sunlight
(3) Environment where a capacitor is exposed to Ozone, ultraviolet rays or
radiation
(4) Environment where a capacitor exposed to corrosive gas(e.g. hydrogen
sulfide, sulfur dioxide, chlorine. ammonia gas etc.)
(5) Environment where a capacitor exposed to vibration or mechanical shock
exceeding the specified limits.
(6) Atmosphere change with causes condensation
13
Others
△Caution
A
E
The product listed in this specification is intended for use in automotive applications
under normal operation and usage conditions.
S
S
A
The product is not designed or warranted to meet the requirements of application
listed below, whose performance and/or quality requires a more stringent level of
safety or reliability, or whose failure, malfunction or defect could cause serious
damage to society, person or property. Please understand that we are not
responsible for any damage or liability caused by use of the products in any of the
applications below or for any other use exceeding the range or conditions set forth in
this specification sheet. If you intend to use the products in the applications listed
below or if you have special requirements exceeding the range or conditions set forth
in this specification, please contact us.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (electric trains, ships etc.)
(3) Medical equipment (Excepting Pharmaceutical Affairs Law classification Class1, 2)
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose applications
When designing your equipment even for general-purpose applications, you are
kindly requested to take into consideration securing protection circuit/device or
providing backup circuits in your equipment.
In addition, although the products listed in this specification is intended for use in
automotive application as described above, it is not prohibited to use for general
electronic equipment, whose performance and/or quality doesn’t require a more
stringent level of safety or reliability, or whose failure, malfunction or defect could not
cause serious damage to society, person or property.
Therefore, the description of this caution will be applied, when the products are used
in general electronic equipment under a normal operation and usage conditions.
— 23 —
AUT-ESD-002
10. TAPE PACKAGING SPECIFICATION
1. CONSTRUCTION AND DIMENSION OF TAPING
1-1. Dimensions of carrier tape
Dimensions of paper tape shall be according to Appendix 4.
1-2. Bulk part and leader of taping
Trailer(Empty)
Chips
Empty
160mm min
160mm min
Leader
Drawing direction
400mm min
1-3. Dimensions of reel
Dimensions of φ178 reel shall be according to Appendix 5.
Dimensions of φ330 reel shall be according to Appendix 6.
1-4. Structure of taping
Top cover tape
Pitch hole
Cavity (Chip insert)
Bottom cover tape
2. CHIP QUANTITY
Please refer to detail page on TDK web.
― 24 ―
Paper carrier tape
AUT-ESD-002
3. PERFORMANCE SPECIFICATIONS
3-1. Fixing peeling strength (top tape)
0.05N < Peeling strength < 0.7N
Direction of cover tape pulling
Top cover tape
Carrier tape
0~15°
Direction of pulling
Paper tape should not adhere to top
cover tape when pull the cover tape.
3-2. Carrier tape shall be flexible enough to be wound around a minimum radius
of 30mm with components in tape.
3-3. The missing of components shall be less than 0.1%
3-4. Components shall not stick to fixing tape.
3-5. When removing the cover tape, there shall not be difficulties by unfitting clearance gap,
burrs and crushes of cavities. Also the sprocket holes shall not be covered by
absorbing dust into the suction nozzle.
― 25 ―
AUT-ESD-002
Appendix 4
Paper Tape
U
Pitch hole
J
E
A
D
B
T
H
G
C
F
(Unit:mm)
Symbol
Case size
CGA3
(CC0603)
Symbol
Case size
CGA3
(CC0603)
A
B
C
D
E
F
( 1.10 )
( 1.90 )
8.00 ± 0.30
3.50 ± 0.05
1.75 ± 0.10
4.00 ± 0.10
G
H
J
T
2.00 ± 0.05
4.00 ± 0.10
φ1.50
+0.10
1.20 max.
― 26 ―
) Reference value.
AUT-ESD-002
Appendix 5
Dimensions of reel (Material : Polystyrene)
U
U
W2
E
C
B
D
R
W1
A
(Unit:mm)
Symbol
Dimension
A
φ178±2.0
B
C
D
E
W1
φ60±2.0
φ13±0.5
φ21±0.8
2.0±0.5
9.0±0.3
Symbol
W2
R
Dimension
13.0±1.4
1.0
Appendix 6
U
U
E
C
B
D
R
W
A
Symbol
A
φ382 max.
Dimension (Nominalφ330)
t
B
C
D
E
φ50 min.
φ13±0.5
φ21±0.8
2.0±0.5
Symbol
t
R
Dimension
2.0±0.5
1.0
― 27 ―
(Unit:mm)
W
10.0±1.5
