CGA8L1X7R3A472KT0Y0N 数据手册
August 2016
MULTILAYER CERAMIC CHIP CAPACITORS
CGA Series
Automotive Grade
High Voltage (1000V and over)
Type:
CGA6 [EIA CC1210]
CGA7 [EIA CC1808]
CGA8 [EIA CC1812]
CGA9 [EIA CC2220]
(1/1)
REMINDERS
Please read before using this product
SAFETY REMINDERS
REMINDERS
1.
If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage,
you must contact our company’s sales window.
2.
We may modify products or discontinue production of a product listed in this catalog without prior notification.
3.
We provide “Delivery Specification” that explain precautions for the specifications and safety of each product
listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers
that use one of these products.
4.
If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the
“Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission
in harmony with this law.
5.
Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our
company.
6.
We are not responsible for problems that occur related to the intellectual property rights or other rights of our
company or a third party when you use a product listed in this catalog. We do not grant license of these rights.
7.
This catalog only applies to products purchased through our company or one of our company’s official agencies.
This catalog does not apply to products that are purchased through other third parties.
Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging
specification detail. This new catalog number should be referenced on all catalog orders going forward, and is
not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ
from the item description (internal control number) on the product label. Contact your local TDK Sales
representative for more information.
(Example)
Catalog Issued date
Prior to January 2013
January 2013 and Later
Catalog Number
C1608C0G1E103J(080AA)
C1608C0G1E103J080AA
Item Description (On Delivery Label)
C1608C0G1E103JT000N
C1608C0G1E103JT000N
20160829 / mlcc_reminders.fm
(1/4)
Pb
Lead
Free
CGA Series
RoHS
COMPLIANT
Ecological
Type: CGA6 [EIA CC1210], CGA7 [EIA CC1808], CGA8 [EIA CC1812],
CGA9 [EIA CC2220]
Features
• Advanced design provides improved withstand voltage characteristics.
• TDK's proprietary intemal electrode structure and the use of low-dielectric-strength material result in highly reliable performance in high-voltage
applications.
• Complies with ISO8802-3 for LAN applications.
• Designed exclusively for reflow soldering.
• AEC-Q200 compliant.
Applications
Cautions
• A slit of about 1mm on the circuit board is recommended to improve
removal of the flux after soldering.
• Ensure that this product is completely dried following washing.
• Because this product will be subjected to high voltages,use only lowactivity rosin flux (with 0.2% max. of chlorine).
• Using this product with aluminum circuit boards must be considered a
special implementation because the high heat stress levels are involved.
In case of using aluminum circuit boards, please contact TDK.
Shape &
Dimensions
Catalog Number
Construction
• Wireless Charging units, such as a DC-DC
converter, a charger on board, etc for EV and
PHEV.
• Snubber of a high voltage circuit, resonant
circuit, time constant circuit and surge
protection for EV and HEV.
L
W
T
B
G
Body Length
Body Width
Body Height
Terminal Width
Terminal Spacing
CGA • 8 • M • 1 • X7R • 3A • 103 • K • 200 • K • A
Series Name
Dimensions L x W (mm)
Code
6
7
8
9
Length
3.20 ± 0.40
4.50 ± 0.40
4.50 ± 0.40
5.70 ± 0.40
Width
Terminal
2.50 ± 0.30 0.20 min.
2.00 ± 0.30 0.20 min.
3.20 ± 0.40 0.20 min.
5.00 ± 0.40 0.20 min.
Thickness T Code (mm)
Code
F
G
K
L
Thickness
0 85 mm
1 10 mm
1 30 mm
1 60 mm
Code
M
N
P
Q
Thickness
2 00 mm
2 30 mm
2 50 mm
2.80 mm
Voltage Condition for Life Test
Symbol
1
Condition
1× V
Temperature Characteristics
Temperature
Temperature Coefficient or Temperature
Characteristics Capacitance Change
Range
C0G
X7R
0±30 ppm/°C
±15%
55 to +125°C
55 to +125°C
Rated Voltage (DC)
Code
3A
3D
3F
Voltage (DC)
1,000V
2,000V
3,000V
Nominal Capacitance (pF)
The capacitance i e pre ed in
three digit code and in un of
pico Farad (pF
The fir and
econd d
entify the fir t
an econ
nificant figure of
the capacitan
The third digit
identifie the mu
100=10pF; 101=100pF;
333=33,000pF
Capacitance Tolerance
Code
F
J
K
M
Tolerance
± 1pF
± 5%
± 10%
± 20%
Nominal Thickness
Code
085
110
130
Thickness
0 85 mm
1 10 mm
1 30 mm
Code
160
200
230
Thickness
1 60 mm
2 00 mm
2 30 mm
Code
250
280
Thickness
2 50 mm
2.80 mm
Packaging Style
Code
A
K
Style
178 mm Reel, 4 mm Pitch
178 mm Reel, 8 mm Pitch
Special Reserved Code
Code
A, C
Description
TDK Internal Code
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
20160829 / mlcc_automotive_highvoltage_en.fm
(2/4)
Capacitance
Range Chart
CGA6(3225) [EIA CC1210]
Capacitance Range Chart
Temperature Characteristics: C0G (0±30ppm/℃)
Rated Voltage:1KV (3A)
Capacitance
C0G
Tolerance
(pF)
1,000
1,200
1,500
1,800
2,200
2,700
3,300
3,900
4,700
5,600
6,800
8,200
10,000
12,000
15,000
18,000
22,000
Code
102
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
3A
(1KV)
J: ± 5%
Standard Thickness
2.00 mm
2.30 mm
2.50 mm
Capacitance
Range Chart
CGA7(4520) [EIA CC1808]
Temperature Characteristics: C0G (0±30ppm/℃), X7R (±15%)
Rated Voltage:3000V (3F), 2000V (3D), 1000V (3A)
Capacitance
C0G
Tolerance
(pF)
10
12
15
18
22
27
33
39
47
56
68
82
100
470
1,000
Code
100
120
150
180
220
270
330
390
470
560
680
820
101
471
102
3F
(3KV)
X7R
3D
(2KV)
3A
(1KV)
F: ± 1pF
K: ± 10%
Standard Thickness
0.85 mm
1.10 mm
1.30 mm
K: ± 10%
M: ± 20%
1.60 mm
2.00 mm
(3/4)
Capacitance
Range Chart
CGA8(4532) [EIA CC1812]
Capacitance
C0G
Tolerance
(pF)
100
120
150
180
220
270
330
2,200
4,700
10,000
Code
101
121
151
181
221
271
331
222
472
103
3F
(3KV)
X7R
3D
(2KV)
3A
(1KV)
K: ± 10%
Standard Thickness
1.30 mm
1.60 mm
2.00 mm
K: ± 10%
M: ± 20%
2.30 mm
2.50 mm
Capacitance
Range Chart
CGA9(5750) [EIA CC2220]
Capacitance
C0G
Tolerance
(pF)
10,000
12,000
15,000
18,000
22,000
27,000
33,000
Code
103
123
153
183
223
273
333
3A
(1KV)
J: ± 5%
Standard Thickness
2.80 mm
(4/4)
Capacitance
Range Table
Class 1 (Temperature Compensating)
Temperature Characteristics: C0G (-55 to +125℃, 0±30ppm/℃)
Capacitance
Size
Thickness
(mm)
Capacitance
Tolerance
10 pF
12 pF
15 pF
18 pF
22 pF
27 pF
33 pF
39 pF
47 pF
56 pF
68 pF
82 pF
4520
4520
4520
4520
4520
4520
4520
4520
4520
4520
4520
4520
4520
4532
4532
4532
4532
4532
4532
4532
3225
3225
3225
3225
3225
3225
3225
3225
3225
3225
3225
3225
3225
5750
3225
5750
3225
5750
3225
5750
3225
5750
5750
5750
0.85 ± 0.15
0.85 ± 0.15
1.10 ± 0.20
1.10 ± 0.20
1.10 ± 0.20
1.60 ± 0.20
1.60 ± 0.20
1.60 ± 0.20
1.60 ± 0.20
2.00 ± 0.20
2.00 ± 0.20
2.00 ± 0.20
2.00 ± 0.20
1.60 ± 0.20
1.60 ± 0.20
1.60 ± 0.20
1.60 ± 0.20
2.00 ± 0.20
2.30 ± 0.20
2.50 ± 0.30
2.00 ± 0.20
2.00 ± 0.20
2.00 ± 0.20
2.00 ± 0.20
2.00 ± 0.20
2.00 ± 0.20
2.00 ± 0.20
2.00 ± 0.20
2.00 ± 0.20
2.00 ± 0.20
2.00 ± 0.20
2.30 ± 0.20
2.50 ± 0.30
2.80 ± 0.30
2.50 ± 0.30
2.80 ± 0.30
2.50 ± 0.30
2.80 ± 0.30
2.50 ± 0.30
2.80 ± 0.30
2.50 ± 0.30
2.80 ± 0.30
2.80 ± 0.30
2.80 ± 0.30
± 1pF
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
± 5%
100 pF
120 pF
150 pF
180 pF
220 pF
270 pF
330 pF
1 nF
1.2 nF
1.5 nF
1.8 nF
2.2 nF
2.7 nF
3.3 nF
3.9 nF
4.7 nF
5.6 nF
6.8 nF
8.2 nF
10 nF
12 nF
15 nF
18 nF
22 nF
27 nF
33 nF
Catalog Number
Rated VoltageEdc:3KV
Rated VoltageEdc:1KV
CGA7F1C0G3F100F085KA
CGA7F1C0G3F120K085KA
CGA7G1C0G3F150K110KA
CGA7G1C0G3F180K110KA
CGA7G1C0G3F220K110KA
CGA7L1C0G3F270K160KA
CGA7L1C0G3F330K160KA
CGA7L1C0G3F390K160KA
CGA7L1C0G3F470K160KA
CGA7M1C0G3F560K200KA
CGA7M1C0G3F680K200KA
CGA7M1C0G3F820K200KA
CGA7M1C0G3F101K200KA
CGA8L1C0G3F101K160KA
CGA8L1C0G3F121K160KA
CGA8L1C0G3F151K160KA
CGA8L1C0G3F181K160KA
CGA8M1C0G3F221K200KA
CGA8N1C0G3F271K230KA
CGA8P1C0G3F331K250KA
CGA6M1C0G3A102J200AC
CGA6M1C0G3A122J200AC
CGA6M1C0G3A152J200AC
CGA6M1C0G3A182J200AC
CGA6M1C0G3A222J200AC
CGA6M1C0G3A272J200AC
CGA6M1C0G3A332J200AC
CGA6M1C0G3A392J200AC
CGA6M1C0G3A472J200AC
CGA6M1C0G3A562J200AC
CGA6M1C0G3A682J200AC
CGA6N1C0G3A822J230AC
CGA6P1C0G3A103J250AC
CGA9Q1C0G3A103J280KC
CGA6P1C0G3A123J250AC
CGA9Q1C0G3A123J280KC
CGA6P1C0G3A153J250AC
CGA9Q1C0G3A153J280KC
CGA6P1C0G3A183J250AC
CGA9Q1C0G3A183J280KC
CGA6P1C0G3A223J250AC
CGA9Q1C0G3A223J280KC
CGA9Q1C0G3A273J280KC
CGA9Q1C0G3A333J280KC
Class 2 (Temperature Stable)
Temperature Characteristics: X7R (-55 to +125℃, ±15%)
Capacitance
Size
Thickness
(mm)
470 pF
4520
1.30 ± 0.20
1 nF
4520
1.30 ± 0.20
2.2 nF
4532
1.30 ± 0.20
4.7 nF
4532
1.60 ± 0.20
10 nF
4532
2.00 ± 0.20
Capacitance
Tolerance
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
Catalog Number
Rated VoltageEdc:2KV
CGA7K1X7R3D471K130KA
CGA7K1X7R3A471K130KA
CGA7K1X7R3D471M130KA
CGA7K1X7R3A471M130KA
CGA7K1X7R3D102K130KA
CGA7K1X7R3A102K130KA
CGA7K1X7R3D102M130KA
CGA7K1X7R3A102M130KA
CGA8K1X7R3D222K130KA
CGA8K1X7R3D222M130KA
CGA8L1X7R3A472K160KA
CGA8L1X7R3A472M160KA
CGA8M1X7R3A103K200KA
CGA8M1X7R3A103M200KA
