CK45-B3AD681KYNNA
CK45-B3AD681KYNNA
    TDK(东电化)
    CAP_D5.5X5MM_TM
    直插陶瓷电容/独石电容 CAP_D5.5X5MM_TM 680pF ±10% 1KV
CK45-B3AD681KYNNA 数据手册
C A P A C I T O R S February 2016 Disc Type Capacitors with Lead High Voltage Ceramic Capacitors Commercial Grade CK45 series Type: CK45 [B, E characteristics, Edc: 1kV to 3kV] (2/11) C A P A C I T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and product temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications Please refer to the guideline of notabilia for fixed ceramic capacitors issued by JEITA(Japan Electronics and Information Technology Association, EIAJ RCR-2335). When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 20160219 / leaddisc_commercial_ck45_en.fm (3/11) C A P A C I T O R S Disc Type Capacitors with Lead Product compatible with RoHS directive Halogen-free High Voltage Ceramic Capacitors, Commercial Grade Overview of CK45 Series FEATURES These products shall conform to RoHS Directive due to lead(Pb) free of lead wire and internal solder material. Compatible with halogen-free external resin coating. APPLICATION For use in DC ballast PART NUMBER CONSTRUCTION CK45 Series name B 3AD 102 K Y □ N A Temperature characteristics Rated voltage Nominal capacitance Capacitance tolerance Class Lead type Application classification Internal code B ±10% E +20, –55% 3AD 1kV 3DD 2kV 3FD 3kV 101 100pF 222 2,200pF 103 10,000pF K Z ±10% +80, –20% G N V Long lead Short lead Taping N General use A Halogen-free Please refer to P-5~10 about the product dimensions. OPERATING TEMPERATURE RANGE Temperature characteristics B E Temperature range Operating temperature (°C) –25 to +105 –25 to +105 Storage temperature (°C) –25 to +105 –25 to +105 The maximum operating temperature of 105°C includes capacitor self-generated heat of up to 20°C. The storage temperature range applies to after MLCC is mounted on board. PACKAGE QUANTITY Package quantity Type Taping (pieces / box) Bulk (pieces / bag) 1000 1000 CK45 500 pieces applies to the following part. CK45-E3DD103ZYVNA RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45_en.fm (4/11) C A P A C I T O R S Overview of CK45 Series RECOMMENDED FLOW PROFILE Soldering Preheating Natural cooling T: Temperature T2 T1 t1 t2 t3 t: Time Preheating Temp. T1 110°C min. Time t1 30 to 60s. Peak Temp. T2 260°C Time t2 Within 10s. Natural cooling Time t3 Over 60s. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45_en.fm (5/11) C A P A C I T O R S CK45 Type CAPACITANCE AND DIMENSIONS Temperature Characteristics: B (±10%) Rated Voltage Edc: 1kV Capacitance (pF) 100 150 220 330 470 680 1,000 1,500 2,200 3,300 4,700 Dimensions (mm) Capacitance F tolerance D max. T max. (Applied to bulk) ±10% 5.5 5.0 5.0±1.5 ±10% 5.5 5.0 5.0±1.5 ±10% 5.5 5.0 5.0±1.5 ±10% 5.5 5.0 5.0±1.5 ±10% 5.5 5.0 5.0±1.5 ±10% 5.5 5.0 5.0±1.5 ±10% 6.0 5.0 5.0±1.5 ±10% 7.0 5.0 5.0±1.5 ±10% 8.5 5.0 5.0±1.5 ±10% 9.5 5.0 5.0±1.5 ±10% 11.0 5.0 5.0±1.5 F (Applied to taping) 5.0+0.8,–0.2 5.0+0.8,–0.2 5.0+0.8,–0.2 5.0+0.8,–0.2 5.0+0.8,–0.2 5.0+0.8,–0.2 5.0+0.8,–0.2 5.0+0.8,–0.2 5.0+0.8,–0.2 5.0+0.8,–0.2 5.0+0.8,–0.2 d Taping Part No. dimensions 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 V1 CK45-B3AD101KY□NA CK45-B3AD151KY□NA CK45-B3AD221KY□NA CK45-B3AD331KY□NA CK45-B3AD471KY□NA CK45-B3AD681KY□NA CK45-B3AD102KY□NA CK45-B3AD152KY□NA CK45-B3AD222KY□NA CK45-B3AD332KY□NA CK45-B3AD472KY□NA * The part numbers are TDK’s standard specification products. The " □ " of the Part Number contains the lead type, G, N or V. Please refer to the details of each shape is shown below. Please refer to P-11 about the taping dimemsions. LIST OF STANDARD LEAD SHAPES Dimemsions in mm Symbol V Taping T F d 5±1 25min. Vertical kink F T 4max. D 4max. D T 4max. D Symbol N Bulk/Short lead 16+1.5 –0.5 Symbol G Bulk/Long lead d F d • TDK’s standard product is vertical kink. • TDK’s recommendation is short lead type with the symbol N for bulk products. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45_en.fm (6/11) C A P A C I T O R S CK45 Type CAPACITANCE AND DIMENSIONS Temperature Characteristics: B (±10%) Rated Voltage Edc: 2kV Capacitance (pF) 100 150 220 330 470 680 1,000 1,500 2,200 3,300 4,700 Dimensions (mm) Capacitance F tolerance D max. T max. (Applied to bulk) ±10% 5.5 5.0 5.0±1.5 ±10% 5.5 5.0 5.0±1.5 ±10% 5.5 5.0 5.0±1.5 ±10% 5.5 5.0 5.0±1.5 ±10% 5.5 5.0 5.0±1.5 ±10% 6.5 5.0 5.0±1.5 ±10% 7.5 5.0 5.0±1.5 ±10% 8.5 5.0 5.0±1.5 ±10% 10.0 5.0 5.0±1.5 ±10% 11.5 5.0 7.5±1.5 ±10% 14.0 5.0 7.5±1.5 F (Applied to taping) 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 7.5±0.8 7.5±0.8 d Taping Part No. dimensions 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 V1 V1 V1 V1 V1 V1 V1 V1 V1 V2 V2 CK45-B3DD101KY□NA CK45-B3DD151KY□NA CK45-B3DD221KY□NA CK45-B3DD331KY□NA CK45-B3DD471KY□NA CK45-B3DD681KY□NA CK45-B3DD102KY□NA CK45-B3DD152KY□NA CK45-B3DD222KY□NA CK45-B3DD332KY□NA CK45-B3DD472KY□NA * The part numbers are TDK’s standard specification products. The " □ " of the Part Number contains the lead type, G, N or V. Please refer to the details of each shape is shown below. Please refer to P-11 about the taping dimemsions. LIST OF STANDARD LEAD SHAPES Dimemsions in mm Symbol V Taping T F d 5±1 25min. Vertical kink F T 4max. D 4max. D T 4max. D Symbol N Bulk/Short lead 16+1.5 –0.5 Symbol G Bulk/Long lead d F d • TDK’s standard product is vertical kink. • TDK’s recommendation is short lead type with the symbol N for bulk products. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45_en.fm (7/11) C A P A C I T O R S CK45 Type CAPACITANCE AND DIMENSIONS Temperature Characteristics: B (±10%) Rated Voltage Edc: 3kV Capacitance (pF) 100 150 220 330 470 680 1,000 1,500 2,200 Dimensions (mm) Capacitance F tolerance D max. T max. (Applied to bulk) ±10% 5.5 6.0 7.5±1.5 ±10% 5.5 6.0 7.5±1.5 ±10% 5.5 6.0 7.5±1.5 ±10% 6.5 6.0 7.5±1.5 ±10% 7.0 6.0 7.5±1.5 ±10% 8.0 6.0 7.5±1.5 ±10% 9.0 6.0 7.5±1.5 ±10% 10.5 6.0 7.5±1.5 ±10% 12.5 6.0 7.5±1.5 F (Applied to taping) 7.5±0.8 7.5±0.8 7.5±0.8 7.5±0.8 7.5±0.8 7.5±0.8 7.5±0.8 7.5±0.8 7.5±0.8 d Taping Part No. dimensions 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 V2 V2 V2 V2 V2 V2 V2 V2 V2 CK45-B3FD101KY□NA CK45-B3FD151KY□NA CK45-B3FD221KY□NA CK45-B3FD331KY□NA CK45-B3FD471KY□NA CK45-B3FD681KY□NA CK45-B3FD102KY□NA CK45-B3FD152KY□NA CK45-B3FD222KY□NA * The part numbers are TDK’s standard specification products. The " □ " of the Part Number contains the lead type, G, N or V. Please refer to the details of each shape is shown below. Please refer to P-11 about the taping dimemsions. LIST OF STANDARD LEAD SHAPES Dimemsions in mm Symbol V Taping T F d 5±1 25min. Vertical kink F T 4max. D 4max. D T 4max. D Symbol N Bulk/Short lead 16+1.5 –0.5 Symbol G Bulk/Long lead d F d • TDK’s standard product is vertical kink. • TDK’s recommendation is short lead type with the symbol N for bulk products. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45_en.fm (8/11) C A P A C I T O R S CK45 Type CAPACITANCE AND DIMENSIONS Temperature Characteristics: E (+20, –55%) Rated Voltage Edc: 1kV Capacitance (pF) 470 1,000 2,200 4,700 10,000 Dimensions (mm) Capacitance F tolerance D max. T max. (Applied to bulk) +80, –20% 5.5 5.0 5.0±1.5 +80, –20% 5.5 5.0 5.0±1.5 +80, –20% 6.5 5.0 5.0±1.5 +80, –20% 8.5 5.0 5.0±1.5 +80, –20% 11.5 5.0 7.5±1.5 F (Applied to taping) 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 7.5±0.8 d Taping Part No. dimensions 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 V1 V1 V1 V1 V2 CK45-E3AD471ZY□NA CK45-E3AD102ZY□NA CK45-E3AD222ZY□NA CK45-E3AD472ZY□NA CK45-E3AD103ZY□NA * The part numbers are TDK’s standard specification products. The " □ " of the Part Number contains the lead type, G, N or V. Please refer to the details of each shape is shown below. Please refer to P-11 about the taping dimemsions. LIST OF STANDARD LEAD SHAPES Dimemsions in mm Symbol V Taping T F d 5±1 25min. Vertical kink F T 4max. D 4max. D T 4max. D Symbol N Bulk/Short lead 16+1.5 –0.5 Symbol G Bulk/Long lead d F d • TDK’s standard product is vertical kink. • TDK’s recommendation is short lead type with the symbol N for bulk products. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45_en.fm (9/11) C A P A C I T O R S CK45 Type CAPACITANCE AND DIMENSIONS Temperature Characteristics: E (+20, –55%) Rated Voltage Edc: 2kV Capacitance (pF) 470 1,000 2,200 4,700 10,000 Dimensions (mm) Capacitance F tolerance D max. T max. (Applied to bulk) +80, –20% 5.5 5.0 5.0±1.5 +80, –20% 6.0 5.0 5.0±1.5 +80, –20% 8.0 5.0 5.0±1.5 +80, –20% 10.5 5.0 5.0±1.5 +80, –20% 14.5 5.0 7.5±1.5 F (Applied to taping) 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 7.5±0.8 d Taping Part No. dimensions 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 V1 V1 V1 V1 V3 CK45-E3DD471ZY□NA CK45-E3DD102ZY□NA CK45-E3DD222ZY□NA CK45-E3DD472ZY□NA CK45-E3DD103ZY□NA * The part numbers are TDK’s standard specification products. The " □ " of the Part Number contains the lead type, G, N or V. Please refer to the details of each shape is shown below. Please refer to P-11 about the taping dimemsions. LIST OF STANDARD LEAD SHAPES Dimemsions in mm Symbol V Taping T F d 5±1 25min. Vertical kink F T 4max. D 4max. D T 4max. D Symbol N Bulk/Short lead 16+1.5 –0.5 Symbol G Bulk/Long lead d F d • TDK’s standard product is vertical kink. • TDK’s recommendation is short lead type with the symbol N for bulk products. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45_en.fm (10/11) C A P A C I T O R S CK45 Type CAPACITANCE AND DIMENSIONS Temperature Characteristics: E (+20, –55%) Rated Voltage Edc: 3kV Capacitance (pF) 470 1,000 2,200 4,700 Dimensions (mm) Capacitance F tolerance D max. T max. (Applied to bulk) +80, –20% 6.0 6.0 7.5±1.5 +80, –20% 7.5 6.0 7.5±1.5 +80, –20% 9.5 6.0 7.5±1.5 +80, –20% 12.5 6.0 7.5±1.5 F (Applied to taping) 7.5±0.8 7.5±0.8 7.5±0.8 7.5±0.8 d Taping Part No. dimensions 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 V2 V2 V2 V2 CK45-E3FD471ZY□NA CK45-E3FD102ZY□NA CK45-E3FD222ZY□NA CK45-E3FD472ZY□NA * The part numbers are TDK’s standard specification products. The " □ " of the Part Number contains the lead type, G, N or V. Please refer to the details of each shape is shown below. Please refer to P-11 about the taping dimemsions. LIST OF STANDARD LEAD SHAPES Dimemsions in mm Symbol V Taping T F d 5±1 25min. Vertical kink F T 4max. D 4max. D T 4max. D Symbol N Bulk/Short lead 16+1.5 –0.5 Symbol G Bulk/Long lead d F d • TDK’s standard product is vertical kink. • TDK’s recommendation is short lead type with the symbol N for bulk products. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45_en.fm (11/11) C A P A C I T O R S CK45 Type TAPING DIMEMSIONS D T P2 P D Δh T P2 C H0 S W0 W W0 W D0 P0 ød P1 F D0 ød t t P0 Δh L L W1 H0 H1 S H0 C W2 H0 H1 W1 P1 F Δh A A Δh W2 P V1, V2 Item V3 Symbol Dimensions(mm) V1 V2 V3 Remarks Body diameter D Depends on the specification of each product. Body thickness T Depends on the specification of each product. Lead-wire diameter ød 0.6±0.05 0.6±0.05 Pitch of component P 12.7±1.0 15.0±1.0 30.0±1.0 Including the slant of body Feed hole pitch P0 12.7±0.3 15.0±0.3 15.0±0.3 Excepting the tape splicing part Feed hole center to lead P1 3.85±0.7 3.75±0.7 3.75±0.7 Feed hole center to component center P2 6.35±1.3 7.5±1.3 7.5±1.3 Lead-to lead distance F 5+0.8, –0.2 7.5±0.8 7.5±0.8 Measuring point is bottom kink Component alignment 'h 0±2.0 0±2.0 0±2.0 Including the slanting body due to bending lead-wire Tape width W 18.0+1.0, –0.5 18.0+1.0, –0.5 18.0+1.0, –0.5 Adhesive tape width W0 10.0min. 10.0min. 10.0min. Hole position W1 9.0±0.5 9.0±0.5 9.0±0.5 Adhesive tape position W2 4.0max. 4.0max. 4.0max. Bottom of kink from tape center H0 16.0+1.5, –0.5 16.0+1.5, –0.5 16.0+1.5, –0.5 Height of body from tape center H1 46.0max. 46.0max. 46.0max. 1.0max. 1.0max. 1.0max. Lead-wire protrusion 0.6±0.05 Feed hole diameter D0 4.0±0.2 4.0±0.2 4.0±0.2 Total tape thickness t 0.6±0.3 0.6±0.3 0.6±0.3 Length of snipped lead L 11.0max. 11.0max. 11.0max. Coating on lead C 4.0max. 4.0max. 4.0max. Height of kink A 4.0max. 4.0max. 4.0max. Spring action S 2.0max. 2.0max. 2.0max. Adhesive tape do not stick out the tape Including adhesive tape Measuring point is bottom kink 320max. AMMO PACK INNER BOX SIZE x. ma 340max. 60 Dimensions in mm • For more information about products with other capacitance or other data, please contact us. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45_en.fm
CK45-B3AD681KYNNA 价格&库存
很抱歉,暂时无法提供与“CK45-B3AD681KYNNA”相匹配的价格&库存,您可以联系我们找货
CK45-B3AD681KYNNA
    • 1+0.45530
    • 100+0.26820
    • 500+0.18180
    • 1000+0.13560
    库存:100
    CK45-B3AD681KYNNA
      • 1+0.36946
      • 100+0.22300
      • 500+0.22084
      • 1000+0.18327
      库存:50
