Mid-high Voltage Ceramic Capacitors
Disk type with lead
Low dissipation at high frequency
General use
CK45-RR series
Issue date:
April 2009
• All specifications are subject to change without notice.
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific
bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
(1/3)
Mid-high Voltage Ceramic Capacitors(Disk with Lead) Conformity to RoHS Directive
Low Dissipation at High Frequency CK45-RR Series
FEATURES
• High voltage ceramic capacitors series, low dissipation factor
and higher reliability has been achieved through the use of TDK
original dielectric and copper for electrode material due to nice
matching of the ceramic dielectrics material for low dissipation
factor, and copper for electrode.
• These RR type ceramic capacitors are mainly used as withstand
voltage protection for power transistors and diodes of switching
power sources, for controlling noise, and for absorbing highfrequency pulses such as from color TV horizontal output
circuits. The high density and high operating frequency of
switching power sources create high equipment temperatures.
• Low dissipation factor, and decreased self-heating temperature
in the high frequency, and high voltage application.
• These products shall conform to RoHS Directive due to lead(Pb)
free of lead wire and internal solder material.
PRODUCT IDENTIFICATION
CK 45 -R 3AD 102 K -N R
(1) (2) (3) (4) (5) (6) (7) (8)
(1) Type
(2) Shape
(3) Capacitance temperature characteristics
(4) Rated voltage
(5) Nominal capacitance
(6) Capacitance tolerance
(7) Lead type
(8) Low dissipation
CAPACITANCE TEMPERATURE CHARACTERISTICS
AND TOLERANCE
Temperature characteristics
R(+15, –30%)
Temperature
range
–25 to +125°C
Capacitance
tolerance
K(±10%)
CAPACITANCE AND DIMENSIONS
TEMPERATURE CHARACTERISTICS: R(+15, –30%)
RATED VOLTAGE Edc: 1kV
Part No.
CK45-R3AD101K-∗ R
CK45-R3AD151K-R
CK45-R3AD221K-R
CK45-R3AD331K-R
CK45-R3AD471K-R
CK45-R3AD681K-R
CK45-R3AD102K-R
CK45-R3AD152K-R
CK45-R3AD222K-R
CK45-R3AD332K-R
CK45-R3AD472K-R
Capacitance
(pF)
100
150
220
330
470
680
1,000
1,500
2,200
3,300
4,700
Dimensions (mm)
D max.
T max.
6
5
6
5
6
5
6.5
5
7
5
8
5
9
5
10
5
11.5
5
13.5
5
15.5
5
F
5±1.5
5±1.5
5±1.5
5±1.5
5±1.5
5±1.5
5±1.5
5±1.5
7.5±1.5
7.5±1.5
10±2
Taping
dimensions
V1
V1
V1
V1
V1
V1
V1
V1
V2
V2
Dimensions (mm)
D max.
T max.
6
5
6
5
7
5
7.5
5
8.5
5
9.5
5
11
5
12
5
14.5
5
17
5
19.5
5
F
5±1.5
5±1.5
5±1.5
5±1.5
5±1.5
5±1.5
5±1.5
7.5±1.5
7.5±1.5
10±2
10±2
Taping
dimensions
V1
V1
V1
V1
V1
V1
V1
V2
V3
: Lead shape symbol
• 1kV and 2kV are E6 series standard products.
RATED VOLTAGE Edc: 2kV
Part No.
CK45-R3DD101K-∗ R
CK45-R3DD151K-R
CK45-R3DD221K-R
CK45-R3DD331K-R
CK45-R3DD471K-R
CK45-R3DD681K-R
CK45-R3DD102K-R
CK45-R3DD152K-R
CK45-R3DD222K-R
CK45-R3DD332K-R
CK45-R3DD472K-R
Capacitance
(pF)
100
150
220
330
470
680
1,000
1,500
2,200
3,300
4,700
: Lead shape symbol
002-02 / 20090417 / e4937_rr.fm
(2/3)
RATED VOLTAGE Edc: 3kV
Capacitance
(pF)
100
150
220
330
470
680
1,000
1,500
2,200
Part No.
CK45-R3FD101K-∗ R
CK45-R3FD151K-R
CK45-R3FD221K-R
CK45-R3FD331K-R
CK45-R3FD471K-R
CK45-R3FD681K-R
CK45-R3FD102K-R
CK45-R3FD152K-R
CK45-R3FD222K-R
Dimensions (mm)
D max.
T max.
6
6
7
6
7.5
6
8.5
6
9.5
6
10.5
6
12
6
14.5
6
16.5
6
F
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
10±2
Taping
dimensions
V2
V2
V2
V2
V2
V2
V2
V3
: Lead shape symbol
LIST OF STANDARD LEAD SHAPES
The lead type is indicated by the second-to-last character of the product name (15th character from the left) using its symbol (letter).
Example) TDK Product Name: CK45-R3AD102K-NR
N: Lead type (Vertical kink, Short)
Dimensions in mm
D
Taping
Symbol V
D
T
16+1.5
–0.5
5±1
25min.
Vertical kink
T
4max.
T
4max.
D
Short lead
Symbol N
4max.
Long lead
Symbol G
• We recommend using a vertical kink type.
• For bulk products, we recommend a short lead type with the symbol N.
(3/3)
TAPING DIMEMSIONS
VERTICAL KINK LEAD TYPE
D
P
T
P2
D
∆h
T
P2
∆h
H0
S
W0
W
L
W1
L
W0
W
P0
D0
ød
P1 F
D0
ød
t
t
P0
C
H0
H1
S
H0
W2
C
A
H0
H1
W1
P1 F
∆h
A
∆h
W2
P
V3
V1, V2
Item
Symbol
Dimensions(mm)
V1
V2
V3
Remarks
Body diameter
D
Depends on the specification of each product.
Body thickness
T
Lead-wire diameter
ød
0.6±0.05
0.6±0.05
0.6±0.05
Pitch of component
P
12.7±1.0
15.0±1.0
30.0±1.0
Including the slant of body
Feed hole pitch
P0
12.7±0.3
15.0±0.3
15.0±0.3
Excepting the tape splicing part
Feed hole center to lead
P1
3.85±0.7
3.75±0.7
3.75±0.7
Feed hole center to component
center
P2
6.35±1.3
7.5±1.3
7.5±1.3
Including the slanting body due to bending lead-wire
Lead-to lead distance
F
5+0.8, –0.2
7.5±0.8
7.5±0.8
Measuring point is bottom kink
Component alignment, F-R
∆h
0±2.0
0±2.0
0±2.0
Tape width
W
18.0+1.0, –0.5 18.0+1.0, –0.5 18.0+1.0, –0.5
Adhesive tape width
W0
11.5min.
11.5min.
11.5min.
Hole position
W1
9.0±0.5
9.0±0.5
9.0±0.5
Adhesive tape position
W2
3.0max.
3.0max.
3.0max.
Bottom of kink from tape center
H0
16.0+1.5, –0.5 16.0+1.5, –0.5 16.0+1.5, –0.5
Height of body from tape center
H1
46.0max.
46.0max.
46.0max.
1.0max.
1.0max.
1.0max.
Lead-wire protrusion
Feed hole diameter
D0
4.0±0.2
4.0±0.2
4.0±0.2
Total tape tickness
t
0.6±0.3
0.6±0.3
0.6±0.3
Length of snipped lead
L
11.0max.
11.0max.
11.0max.
Coating on lead
C
4.0max.
4.0max.
4.0max.
Height of kink
A
4.0max.
4.0max.
4.0max.
Spring action
S
2.0max.
2.0max.
2.0max.
Adhesive tape do not stick out the tape
Including adhesive tape
• For more information about products with other capacitance or other data, please contact us.
