R F
C o m p o n e n t s
June 2015
Multilayer Low Pass Filter
For 4900–5950MHz
DEA165850LT-1197B2
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
RF Components
Conformity to RoHS Directive
For 4900–5950MHz
DEA165850LT-1197B2
SHAPES AND DIMENSIONS
[Top view]
1.60±0.15
0.80±0.10
(3)
(4)
[Bottom view]
0.50±0.10
Marking
0.15min.
(1)
0.80±0.10
(2)
Terminal functions
1 IN
2 GND
3 OUT
4 GND
0.20±0.10
0.20min.
Dimensions in mm
RECOMMENDED LAND PATTERN
EVALUATION BOARD
0.60
4-ø0.30 Through-hole
0.40
0.80
0.50
0.80
1.40
0.50
0.60
0.50
2.20
Dimensions in mm
0.30
Land
0.50
Solder resist
Dimensions in mm
Line width should be designed to match 50Ω
characteristic impedance, depending on PCB
material and thickness.
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150601 / rf_lpf_dea165850lt-1197b2_zh.fm
RF Components
DEA165850LT-1197B2
ELECTRICAL CHARACTERISTICS
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Power Handling (W)
Characteristic Impedance (:)
Frequency Range
(MHz)
Min.
Typ.
Max.
4900 to 5950
4900 to 5950
9800
11900
4900 to 5950
12
0.43
18.6
37.8
36.2
50 (Nominal)
0.7
1
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
˄°C˅
–40 to +85
Storage temperature
˄°C˅
–40 to +85
RF Components
DEA165850LT-1197B2
FREQUENCY CHARACTERISTICS
INSERTION LOSS
ATTENUATION
5
10
15
1.0
Attenuation(dB)
Insertion Loss (dB)
0.5
1.5
2.0
30
35
40
2.5
45
3.0
4000
6000
8000
10000
Frequency (MHz)
12000
14000
8000
10000
Frequency (MHz)
12000
14000
50
4000
6000
8000
10000
Frequency (MHz)
12000
14000
RETURN LOSS
–50
–40
–30
Return Loss(dB)
–20
–10
40
50
4000
6000
RF Components
DEA165850LT-1197B2
RECOMMENDED REFLOW PROFILE
Soaking
Working
Soldering
Peak
T: Temperature
T4
T5
T3
T2
T4
T3
t3
T1
t1
t2
t: Time
Soaking
Temp.
T1
150°C
T2
180°C
Time
t1
60 to 120s
Working
Temp.
T3
230°C
Time
t2
more than 30s
Soldering Peak
Temp.
T4
247 to 253°C
Time
t3
within 10s
Temp.
T5
260°C max.
RF Components
ቂ᎙ሃჵ
ቂׁٛ൰ˈขႚࢆࣙࢭتࡒཱུכ༚ȃ
ภ᎙ሃჵ
ቂׁٛ൰ˈข᎙ሃภჵȃ
᎙ ሃ
ׁٛ൰಼፩ኵܿٛ൰ፑቂᎳቂဉሃሆຢቂᇜֈݢᏊົֻ ˄AV ົֻˈᄪົֻˈয়ݢٛ൰ˈቨົֻˈིົֻˈࢋ
เົֻˈ֑࢞ົֻˈˈֻົكᇖධเ˅ˈ෩ࡘᇜֈݢᏊົֻᇋ٢ܿغᏮञቂߴߟቂȃ
ޭᅍᇋࡴޡภᄹञ૰૦ᄹܿˈডጚົֻܿࢽጊˈႜވᏮˈከᎡட૰ঐࢍเܿໍಛˈເ࿒ঽاٛ݃ዉڈཿࣷˈᇵঽ૰ٛໍಧܐ
຺ঐሯჳܿᇵቂဉ ˄ᇵ ‘ څ࿅ށቂဉ ’˅፩ܿቂᄹˈᄹߙংˈ൰፣ˈׁ࢞ཌྷቧ֦ጽȃ
ٛ൰־ׁٛ൰಼ܿ߭ၐȂፇိˈডጚ࿅ށቂဉ፩ቂˈׁ࢞ཌྷޭྋዉܿڈཿࣷञᄪᄹܞڏใटውใȃ
(1) ऎ࿙ऎૼົֻ
(2) ਦከ༕ົֻ ˄පވݢˈٴট˅݃ؑۉˈٴ
(3) ᇞனົֻ
(4) ߙ૿ݢ፟ົֻ
(5) ኊᏊኑყ࣋ົֻ
(6) ֻࣴົݒ
(7) ਦ૿፟ົֻ
(8) ࢞ࢥᄪႩֻົ୲ۃ
(9) ૅົֻ
(10) ݢৠົֻȂัຨົֻ
(11) ߷ኳ / ኁ߷߯Ꮶົֻ
(12) ภົֻ
(13) ඝྊ־༄ၓ٢ࣙቂဉܿቂဉ
ၓமࢮภݓቂٛ൰ˈޭቂׁٛ൰಼፩ྈኵٛ൰ܿົֻᄵົˈขฬ֦࠲ठࡘົֻܿቂቂဉঽᎫྙ֦ܿ॓ই௸ञᎧ
ˈົֻቂই௸݃ȃ
很抱歉,暂时无法提供与“DEA165850LT-1197B2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.39149
- 100+0.36539
- 300+0.33929
- 500+0.31320
- 2000+0.30015
- 5000+0.29232
