R F
C o m p o n e n t s
June 2015
Multilayer Band Pass Filter
For 4900–5950MHz
DEA205425BT-2028A4
2.0x1.25mm [EIA 0805]*
* Dimensions Code JIS[EIA]
Caution
The products in this catalog will be or have been
stopped production
Discontinue Issue Date
Jun. 3, 2022
Last Purchase Order Date
Mar. 31, 2023
Last Shipment Date
Mar. 31, 2024
Please refer to our Web site about replacement information.
RF Components
Conformity to RoHS Directive
For 4900–5950MHz
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
DEA205425BT-2028A4
SHAPES AND DIMENSIONS
0.95±0.10
2.00±0.15
(4)
(1)
(3)
(2)
[Bottom view]
1.25±0.15
[Top view]
Marking
0.25±0.10
0.25±0.10
0.30±0.15
1.00±0.15
Terminal functions
1 IN
2 GND
3 OUT
4 GND
0.70±0.15
Dimensions in mm
RECOMMENDED LAND PATTERN
EVALUATION BOARD
0.60
Dimensions in mm
Th
e
1.50
0.45
0.40
1.10
0.70
Line width be designed to match 50Ω
characteristic impedance depending
on PCB material and thickness.
1.10
2.80
Solder resist
1.50
Land
0.67 0.70 0.50
0.14
0.98
0.45
0.50
0.95
0.60
Dimensions in mm
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150601 / rf_bpf_dea205425bt-2028a4_en.fm
RF Components
DEA205425BT-2028A4
ELECTRICAL CHARACTERISTICS
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Frequency Range
(MHz)
Min.
Typ.
Max.
4900 to 5950
4900 to 5950
4900 to 5950
1280 to 3300
3300 to 4000
4375 to 4465
7300 to 8930
9800 to 11900
9
40
25
7
14
25
1.6
1.9
11
50
33
12
18
38
50 (Nominal)
2.0
2.3 (–40 to +85°C)
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Item
Characteristic Impedance (:)
・Ta: +25±5°C
TEMPERATURE RANGE
Storage temperature
(°C)
–40 to +85
Th
e
Operating temperature
(°C)
–40 to +85
RF Components
DEA205425BT-2028A4
FREQUENCY CHARACTERISTICS
ATTENUATION
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
INSERTION LOSS
0.5
10
1.0
Attenuation(dB)
Insertion Loss(dB)
2.0
2.5
3.0
30
40
50
3.5
4.0
4500
4750
5000
5250
5500
5750
Frequency (MHz)
6000
6250
6500
60
1000 2000 3000 4000 5000 6000 7000 8000 9000 10000 11000 12000 13000 14000 15000 16000
Frequency (MHz)
RETURN LOSS
Return Loss(dB)
40
50
Th
e
60
Frequency (MHz)
RF Components
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T1
t1
T3
t3
t2
t: Time
Preheating
Temp.
T1
150°C
t3
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
Th
e
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
Th
e
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DEA205425BT-2028A4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.17494
- 10+0.95548
- 30+0.86141
- 100+0.74402
- 500+0.69174
- 1000+0.66042
