May. 2021 Ver.2.0
TDK Corporation
Multilayer Band Pass Filter
WiFi 5g C-band
DEA Series
P/N:
1.6x0.8mm [EIA 0603] TYPE
DEA166200BT-2356A3
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
May. 2021 Ver.2.0
TDK Corporation
DEA166200BT-2356A3
■ SHAPES AND DIMENSIONS
[Top View]
(1)
(2)
[Bottom View]
(3)
(3)
(2)
(1)
Dimensions (mm)
L
W
T
a
b
c
d
e
1.60 0.80 0.65 0.25 0.23 0.40 0.55 0.60
+/-0.15 +/-0.10
Max
+/-0.10 +/-0.10 +/-0.10 +/-0.15 +/-0.15
Terminal functions
Input / Output Port
(1)
GND
(2)
Output / Input Port
(3)
■ TERMINATION FINISH
Material
Ag
May. 2021 Ver.2.0
TDK Corporation
DEA166200BT-2356A3
■ ELECTRICAL CHARACTERISTICS
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
–40 to +90 °C
Return Loss@Input (dB)
Return Loss@Output (dB)
Attenuation (dB)
Frequency (MHz)
5150
5710
5925
6425
7125
5150
5710
5925
6425
7125
5150
5925
7125
5150
5925
7125
100
1166
1427
1695
2300
2400
2496
3300
4500
4800
7250
7600
9000
9600
10300
11850
to 5710
to 5925
to 6425
to 7125
to 7250
to 5710
to 5925
to 6425
to 7125
to 7250
to 5925
to 7125
to 7250
to 5925
to 7125
to 7250
to
960
to 1249
to 1610
to 2200
to 2370
to 2483
to 2690
to 4200
to 4600
to 4900
to 7800
to 8400
to 9200
to 9800
to 11850
to 14250
( Measurement )
TDK Spec
Min. Typ. Max.
1.31 1.60
1.27 1.60
1.27 1.60
1.15 1.60
1.15 1.60
1.90
1.90
1.90
1.90
2.10
6
10
6
10
8
12
6
9
6
9
8
12
40
55
40
50
40
47
40
43
40
43
40
43
40
42
38
44
12
3
1
3
30
51
30
41
30
43
24
28
Ta = +25+/-5°C
May. 2021 Ver.2.0
TDK Corporation
DEA166200BT-2356A3
■ MAXIMUM RATINGS
Parameter
Operating temperature (°C)
Storage temperature (°C)
Power Handling (W)
Human Body Model : HBM
Machine Model : MM
Charged Device Model : CDM
TDK Spec
Conditions
–40 to +90 °C
–40 to +90 °C
Frequency (MHz)
CW
1
5150 to 7250
@Each Port (V) +/-1000 100pF / 1500ohm
+/-150
200pF / 0ohm
@Each Port (V)
+/-500
Humidity : 60%RH max
@Each Port (V)
*1 : Refer to 3GPP TS 38.101-1 V15.2.0
May. 2021 Ver.2.0
TDK Corporation
DEA166200BT-2356A3
■ FREQUENCY CHARACTERISTICS
May. 2021 Ver.2.0
TDK Corporation
DEA166200BT-2356A3
May. 2021 Ver.2.0
TDK Corporation
DEA166200BT-2356A3
■ RECOMMENDED LAND PATTERN
Unit : [mm]
■ EVALUATION BOARD
Material & Layer
Copper Surface Pattern
FR-4
Inner GND
FR-4
Copper Bottom GND
Thickness
0.035 mm
0.10 mm
0.018 mm
0.30 mm
0.035 mm
unit : mm
* Line width should be designed to match 50 ohm characteristic impedance depending on
PCB material and thickness.
** The position of the throuh hole which have possibility of influence to the prerformance
are indicated by dimension line.
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
May. 2021 Ver.2.0
TDK Corporation
DEA166200BT-2356A3
■ RECOMMENDED REFLOW PROFILE
3oC/sec
or lower
Preheating
Temp.
T1
T2
Time
t1
150°C 200°C 60 to 120sec
6oC/sec
or lower
Soldering
Critical zone (T3 to T4)
Peak
Temp.
Time
Temp.
Time
T3
t2
T4
t3 *
217°C
60 to 120sec 240 to 260°C 30 sec Max
* t3 : Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Note:
Lead free solder is recommended.
Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry)
May. 2021 Ver.2.0
TDK Corporation
DEA166200BT-2356A3
■ PACKAGING STYLE
Reel Dimensions
Carrier Tape
Sprocket hole
K
Loading Direction
E
J
C
D
A
B
B
t
H
Dimensions (mm)
A
B
C
0.97 1.8 8.0
+/-0.05 +/-0.05
D
3.5
+/-0.2 +/-0.05
E
1.75
+/-0.1
F
4.0
G
G
2.0
+/-0.1 +/-0.05
F
H
4.0
J
1.5
K
0.8
t
0.25
+/-0.1
+0.1/-0
MAX
+/-0.05
STANDARD PACKAGE QUANTITY
( pieces/reel )
4,000
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DEA166200BT-2356A3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.90753
- 50+0.72112
- 150+0.64131
- 500+0.54162
