R F
C o m p o n e n t s
June 2015
Multilayer Band Pass Filter
For 2500-2700MHz
DEA162600BT-1258C2
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
Caution
The products in this catalog will be or have been
stopped production
Discontinue Issue Date
Jun. 3, 2022
Last Purchase Order Date
Mar. 31, 2023
Last Shipment Date
Mar. 31, 2024
Please refer to our Web site about replacement information.
RF Components
Conformity to RoHS Directive
For 2500-2700MHz
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
DEA162600BT-1258C2
SHAPES AND DIMENSIONS
0.60±0.10
1.60±0.10
(4)
(3)
(2)
[Bottom view]
Marking
0.25±0.15
(1)
0.30±0.15
Terminal functions
1 IN
2 GND
3 OUT
4 GND
0.20±0.15
0.70±0.15
0.20±0.15
0.80±0.10
[Top view]
0.45±0.15
Dimensions in mm
RECOMMENDED LAND PATTERN
0.80
0.20
0.05
0.30
0.50
0.50
Th
e
Dimensions in mm
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150601 / rf_bpf_dea162600bt-1258c2_en.fm
RF Components
DEA162600BT-1258C2
ELECTRICAL CHARACTERISTICS
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Frequency Range
(MHz)
Min.
Typ.
Max.
2500 to 2700
2500 to 2700
806 to 825
825 to 849
880 to 915
1710 to 1785
1850 to 1910
1920 to 1980
3300 to 3900
4900 to 5900
9
25
25
25
25
25
15
5
15
1.6
15.5
39.0
38.9
38.3
46.6
33.6
28.2
12.5
27.7
50 (Nominal)
2.2
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Item
Characteristic Impedance (:)
・Ta: +25±5°C
TEMPERATURE RANGE
Storage temperature
(°C)
–40 to +85
Th
e
Operating temperature
(°C)
–40 to +85
RF Components
DEA162600BT-1258C2
FREQUENCY CHARACTERISTICS
ATTENUATION
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
INSERTION LOSS
5
10
15
Attenuation(dB)
Insertion Loss (dB)
10
30
25
30
35
40
45
50
35
55
40
2000
2200
2400
2600
2800
Frequency (MHz)
3000
3200
3400
2400
2600
2800
Frequency (MHz)
3000
3200
3400
60
500
1500
2500
3500
4500
5500
Frequency (MHz)
6500
7500
8500
RETURN LOSS
–10
–5
Return Loss(dB)
5
10
15
30
35
2200
Th
e
40
2000
RF Components
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T1
t1
T3
t3
t2
t: Time
Preheating
Temp.
T1
150°C
t3
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
Th
e
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
Th
e
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DEA162600BT-1258C2”相匹配的价格&库存,您可以联系我们找货
