The products in this catalog are not recommended for new design
R F
C o m p o n e n t s
June 2015
Multilayer Band Pass Filter
For 2400-2500MHz
DEA162450BT-2174A1
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
RF Components
Conformity to RoHS Directive
For 2400-2500MHz
DEA162450BT-2174A1
SHAPES AND DIMENSIONS
[Top view]
0.50max.
0.80±0.10
1.60±0.15
Marking
[Bottom view]
0.60±0.10
0.50±0.10
(1)
0.20±0.10
(2)
Terminal functions
1 IN
2 GND
3 OUT
(3)
0.25±0.10
Dimensions in mm
0.21
0.70
0.50
0.245
RECOMMENDED LAND PATTERN
0.25
0.25
Dimensions in mm
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150601 / rf_bpf_dea162450bt-2174a1_en.fm
RF Components
DEA162450BT-2174A1
ELECTRICAL CHARACTERISTICS
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Frequency Range
(MHz)
Min.
Typ.
Max.
2400 to 2500
2400 to 2500
880 to 915
1710
1850 to 1910
1920 to 1990
2110 to 2170
4800 to 5000
7200 to 7500
10
38
35
25
25
30
1.75
14.7
43.1
43.5
30.9
27.2
23.7
37.6
35.4
50 (Nominal)
2.3
Characteristic Impedance (:)
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
RF Components
DEA162450BT-2174A1
FREQUENCY CHARACTERISTICS
INSERTION LOSS
ATTENUATION
10
1
15
Attenuation(dB)
Insertion Loss (dB)
3
25
30
35
40
45
4
50
55
5
2000
2100
2200
2300
2400 2500 2600
Frequency (MHz)
2700
2800
2900
3000
60
500
1500
2500
3500
4500
5500
6500
Frequency (MHz)
7500
8500
9500
RETURN LOSS
Return Loss(dB)
10
15
30
35
40
2000
2100
2200
2300
2400 2500 2600
Frequency (MHz)
2700
2800
2900
3000
RF Components
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DEA162450BT-2174A1”相匹配的价格&库存,您可以联系我们找货
