(1/2)
Multilayer Chip Band Pass Filters
For WiMAX
Conformity to RoHS Directive
DEA Series DEA202495BT-1242B2
SHAPES AND DIMENSIONS
1
4
0.25±0.1
0.25±0.1
3
1.25±0.15
0.95±0.1
0.3±0.15
2.0±0.15
2
1.25±0.15
Terminal functions
1 IN
2 GND
3 OUT
4 GND
Dimensions in mm
RECOMMENDED PC BOARD PATTERNS
ø0.15 Through-hole
0.42
0.35
0.7
0.6
1.1
Line width be designed to mach 50Ω
characteristic impedance depending
on PCB material and thickness
Dimensions in mm
ELECTRICAL CHARACTERISTICS
Item
Insertion loss
Return loss
Attenuation
Temperature range
[2300 to 2690MHz]
[2300 to 2690MHz]
[100 to 1800MHz]
[3400 to 11700MHz]
Operating
Storage
(dB)
(dB)
(dB)
(dB)
(°C)
(°C)
Minimum value
10
14
14
–40
–40
Typical value
Maximum value
1.8
+85
+85
• Ta:+25°C
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and
specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
• All specifications are subject to change without notice.
001-02 / 20080113 / e721_dea202495bt_1242.fm
(2/2)
FREQUENCY CHARACTERISTICS
INSERTION LOSS
ATTENUATION
1: 2300MHz
–1.24dB
2: 2400MHz
–1.085dB
3: 2500MHz
–1.125dB
4: 2690MHz
–1.26dB
Insertion loss(dB)
–1
–2
–3
1: 1800MHz
–18.722dB
2: 3400MHz
–37.125dB
3: 11700MHz
–38.095dB
–10
Attenuation(dB)
–20
–30
–40
–50
–4
–60
–5
2000 2100 2200 2300 2400 2500 2600 2700 2800 2900 3000
Frequency (GHz)
–70
1000
3000
5000
7000
Frequency (GHz)
9000
11000
RETURN LOSS
1: 2300MHz
–17.86dB
2: 2400MHz
–21.619dB
3: 2500MHz
–16.841dB
4: 2690MHz
–20.572dB
Return loss(dB)
–10
–20
–30
–40
–50
–60
1000
2000
3000
4000
Frequency (MHz)
5000
6000
很抱歉,暂时无法提供与“DEA202495BT-1242B2”相匹配的价格&库存,您可以联系我们找货
