R F
C o m p o n e n t s
April 2015
Multilayer Balun
For 2400–2500MHz
HHM1711D1
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
Caution
The products in this catalog will be or have been
stopped production
Discontinue Issue Date
Jun. 3, 2022
Last Purchase Order Date
Mar. 31, 2023
Last Shipment Date
Mar. 31, 2024
Please refer to our Web site about replacement information.
RF Components
Multilayer Balun
Conformity to RoHS Directive
For 2400–2500MHz
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
HHM1711D1
SHAPES AND DIMENSIONS
[Top view]
1.60±0.10
0.60±0.10
(5)
(4)
(1)
(2)
(3)
Marking
0.80±0.10
(6)
[Bottom view]
0.55±0.10
0.30±0.10
Terminal functions
1 Unbalanced port
2 GND or DC feed+ RF GND
3 Balanced port
4 Balanced port
5 GND
6 N.C.
0.25±0.10
0.10±0.10
Dimensions in mm
RECOMMENDED LAND PATTERN
0.50
0.50
0.30
Dimensions in mm
Th
e
0.25
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150419 / rf_balun_hhm1711d1_en.fm
RF Components
HHM1711D1
ELECTRICAL CHARACTERISTICS
Frequency Range
(MHz)
Min.
Typ.
Max.
10
170
–2.0
50 (Nominal)
100 (Nominal)
190
2.0
1.2
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Item
Unbalanced Port Characteristic Impedance (:)
Balanced Port Characteristic Impedance (:)
Return Loss at Unbalanced Port (dB)
Phase Balance (deg.)
Amplitude Balance (dB)
Insertion Loss (dB)
2400 to 2500
2400 to 2500
2400 to 2500
2400 to 2500
TEMPERATURE RANGE
Storage temperature
(°C)
–40 to +85
Th
e
Operating temperature
(°C)
–40 to +85
RF Components
HHM1711D1
FREQUENCY CHARACTERISTICS
0.5
1.0
Insertion Loss (dB)
1.5
2.0
2.5
3.0
3.5
4.0
4.5
5.0
2100
AMPLITUDE BALANCE
5
4
3
0.0
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
INSERTION LOSS
1
–1
–2
–3
–4
2200
2300
2400
2500
Frequency (MHz)
2600
2700
–5
2100
2800
RETURN LOSS
2200
2300
2400
2500
Frequency (MHz)
2600
2700
2800
2400
2500
Frequency (MHz)
2600
2700
2800
PHASE BALANCE
205
200
5
195
Return Loss (dB)
15
190
10
185
180
175
170
165
25
160
2200
2300
2400
2500
Frequency (MHz)
2600
2700
2800
2200
2300
Th
e
30
2100
155
2100
RF Components
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T1
t1
T3
t3
t2
t: Time
Preheating
Temp.
T1
150°C
t3
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
Th
e
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
Th
e
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“HHM-1711D1”相匹配的价格&库存,您可以联系我们找货
