IAF12020A007V-006-R
IAF12020A007V-006-R
    TDK(东电化)
    IAF12020A007V-006-R - iAF Series – Non-isolated SMT Power Module - TDK Electronics
IAF12020A007V-006-R 数据手册
Advance Data Sheet: iAF Series – Non-isolated SMT Power Module iAF Series DC/DC Power Modules 4.5-14V Input, 20A Output Surface Mount Power Module iAF power modules perform local voltage conversion from any bus voltage in the 5V to 12V range. The iAF12020A007V utilizes a low component count that results in both a low cost structure and a high level of performance. The open-frame, compact, surface mountable design features a low profile and weight as well as additional edge plated pads that allow for extremely flexible and robust manufacturing processes. Features • Size – 33mm x 13.46 mm x 7.75 mm (1.3 in. x 0.53 in. x 0.305 in.) • DOSA Compatible Footprint • Edge plated castellations for forming inspectable solder joints • Surface mountable • Maximum weight 5.5g (0.194 oz) • Up to 110W of output power in high ambient temperature, low airflow environments with no power derating • Positive logic on/off • Flexible Output Voltage Sequencing • Starts with pre-biased output • Output voltage adjustment – industry standard • Outstanding transient response without the need for external loop tuning components • Constant switching frequency • Remote Sense • Power Good • Full, auto-recovery protection: o Input under voltage o Short circuit o Thermal limit • ISO Certified manufacturing facilities • Patent pending Optional Features • Negative logic on/off • No output voltage sequencing • Solder bumping for enhanced solderability on the EPC footprint ©2011 TDK Innoveta Inc. iAF12_Full_Datasheet_08152011.doc 8/16/2011 (877) 498-0099 1/18 Advance Data Sheet: iAF Series – Non-isolated SMT Power Module Ordering information: Product Identifier Package Size Platform Input Voltage Output Current/ Power Units Main Output Voltage # of Outputs Safety Class Feature Set RoHS Indicator i TDK Innoveta A 33mm x 13.5mm F iAF 12 4.5V to 14V 020 20 A Amps 007 0.70V to 5.5V V Single - 0 06 See option table - R R=RoHS 6 Compliant Option Table: Feature Set 00 01 02 03 04 05 06 07 X X X X X X X X x x x x Positive Logic On/Off X X Negative Logic On/Off Sequence X X LGA Solder Bumping* EPC Solder Bumping* x x x x Product Label Marking -000 -001 -002 -003 -004 -005 -006 -007 * LGA solder bumping option is recommended for customers using the DOSA standard land grid array footprint and EPC soldering bumping is recommended for customers using the inspectable edge plated castellation pads Product Offering: Code iAF12020A007V Input Voltage 4.5V-14V Output Voltage 0.70V-5.5V Output Current 20A Maximum Output Power 110W Efficiency 95% 3320 Matrix Drive, Suite 100 Richardson, TX 75802 Phone (877) 498-0099 Toll Free (469) 916-4747 Fax (877) 498-0143 Toll Free (214) 239-3101 support@tdkinnoveta.com http://www.tdkinnoveta.com/ ©2011 TDK Innoveta Inc. iAF12_Full_Datasheet_08152011.doc 8/16/2011 (877) 498-0099 2/18 Advance Data Sheet: iAF Series – Non-isolated SMT Power Module Mechanical Specification: Dimensions are in mm [in]. Unless otherwise specified tolerances are: x.x ± 0.5 [0.02], x.xx ± 0.25 [0.010] See ordering information for solder bumping options ©2011 TDK Innoveta Inc. iAF12_Full_Datasheet_08152011.doc 8/16/2011 (877) 498-0099 3/18 Advance Data Sheet: iAF Series – Non-isolated SMT Power Module Pin Locations: (bottom view) DOSA PADS EPC PADS Pin Assignment: PIN 1 2 3 4 5 FUNCTION ON/OFF VIN SEQ GND VOUT PIN 6 7 8 9 10 FUNCTION TRIM SENSE + SENSE RES PW GOOD SYNC RES ©2011 TDK Innoveta Inc. iAF12_Full_Datasheet_08152011.doc 8/16/2011 (877) 498-0099 4/18 Advance Data Sheet: iAF Series – Non-isolated SMT Power Module Recommended Footprint (top view): DOSA PADS EPC PADS ©2011 TDK Innoveta Inc. iAF12_Full_Datasheet_08152011.doc 8/16/2011 (877) 498-0099 5/18 Advance Data Sheet: iAF Series – Non-isolated SMT Power Module Absolute Maximum Ratings: Stress in excess of Absolute Maximum Ratings may cause permanent damage to the device. Characteristic Continuous Input Voltage Storage Temperature Operating Temperature Range (Tc) Min -0.25 -55 -40 Max 15 125 115* Unit Vdc ˚C ˚C Notes & Conditions Measured at the location specified in the thermal measurement figure; maximum temperature varies with output current – see curve in the thermal performance section of the data sheet. * Engineering estimate Input Characteristics: Unless otherwise specified, specifications apply over all rated Input Voltage, Resistive Load, and Temperature conditions. Characteristic Operating Input Voltage Maximum Input Current Startup Delay Time from application of input voltage Startup Delay Time from on/off Output Voltage Rise Time Input Reflected Ripple Input Ripple Rejection Turn on input voltage Turn off input voltage *Engineering Estimate Min 4.5 ----------------- Typ ----5 5 4 15 45* 4.2 3.5 Max 14 20 --------------- Unit Vdc A mS mS mS mApp dB V V Notes & Conditions Vin=4.5 to Vin,max; Io=Io,max Vo=0 to 0.1*Vo,set; on/off=on, Io=Io,max, Tc=25˚C Vo=0 to 0.1*Vo,set; Vin=Vi,nom, Io=Io,max,Tc=25˚C Io=Io,max,Tc=25˚C, Vo=0.1 to 0.9*Vo,set See input/output ripple measurement figure; BW=20 MHz @ 120 Hz Caution: The power modules are not internally fused. An external input line normal blow fuse with a maximum value of 20A is required, see the Safety Considerations section of the data sheet. ©2011 TDK Innoveta Inc. iAF12_Full_Datasheet_08152011.doc 8/16/2011 (877) 498-0099 6/18 Advance Data Sheet: iAF Series – Non-isolated SMT Power Module Electrical Data: Characteristic Output Voltage Initial Setpoint Output Voltage Tolerance Efficiency Vo = 1.2V Vo = 1.5V Vo = 1.8V Vo = 3.3V Vo = 5.0V Min -2 -3 --------------0 ------- Typ 82 85 87 91.5 93.5 3 7 --42 1 10 Max +2 +3 --------------20 ------- Unit % % % % % % % mV mV A A A mVpp Notes & Conditions Vo=3.3Vsetting, Vin=Vin,nom; Io=Io,max; Tc = 25˚C Over all rated input voltage, load, and temperature conditions to end of life Vin=12V; Io=Io,max; Tc=25˚C Line Regulation Load Regulation Output Current Output Current Limiting Threshold Short Circuit Current Output Ripple and Noise Voltage Vin=Vin,min to Vin,max Io=Io,min to Io,max Vo = 0.9*Vo,nom, Tc
IAF12020A007V-006-R
在PDF文档中,物料型号为:MAX31855KASA+,器件简介包括:MAX31855KASA+是一款冷结温度传感器到数字输出转换器,具有高精度和快速响应的特点,支持-40°C至+85°C的温度测量范围,并且具有SPI接口。
引脚分配为:1-VCC,2-GND,3-SCK,4-CS,5-SO,6-THERM+,7-THERM-。
参数特性包括:测量精度±1°C,响应时间小于100毫秒,供电电压2.0V至3.6V,工作电流小于2毫安。
功能详解为:MAX31855KASA+能够将热电偶信号转换为数字信号,并通过SPI接口输出。
应用信息为:适用于需要高精度温度测量的工业控制、医疗设备和环境监测等领域。
封装信息为:采用K型热电偶,TO-220AB封装形式。
IAF12020A007V-006-R 价格&库存
很抱歉,暂时无法提供与“IAF12020A007V-006-R”相匹配的价格&库存,您可以联系我们找货
