Discontinue Issue Date
Last Purchase Order Date
Last Shipment Date
May 28, 2020
Mar. 31, 2022
Sep. 30, 2022
• Please refer to our Web site about replacement information.
I N D U C T O R S
Inductors for decoupling circuits
Wound ferrite
NLC series
RoHS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
NLC453232 type
FEATURES
Resin mold type wound inductor for decoupling circuits.
E-12 series, wide lineup compatible with K (±10%) tolerance allows for various usages.
Operating temperature range: –40 to +105°C (including self-temperature rise)
APPLICATION
Smart meters, AV equipment, xDSL, electronic devices for communications infrastructure such as mobile base stations, industrial equipment, other
PART NUMBER CONSTRUCTION
NLC
Series name
453232
T
L×W×H dimensions
4.5×3.2×3.2 mm
Packaging style
1R0
K
Inductance
(µH)
Inductance
tolerance
PF
Lead-free
compatible
CHARACTERISTICS SPECIFICATION TABLE
L
(µH)
1
1.2
1.5
1.8
2.2
2.7
3.3
3.9
4.7
5.6
6.8
8.2
Tolerance
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
Q
L, Q measuring
frequency
DC resistance
Rated current
Part No.
min.
10
10
10
10
10
10
10
10
10
10
10
10
(MHz)
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
7.96
(Ω )max.
0.11
0.12
0.15
0.16
0.18
0.2
0.22
0.24
0.27
0.3
0.35
0.4
(mA)max.
1050
1000
950
900
850
800
750
700
650
650
600
600
NLC453232T-1R0K-PF
NLC453232T-1R2K-PF
NLC453232T-1R5K-PF
NLC453232T-1R8K-PF
NLC453232T-2R2K-PF
NLC453232T-2R7K-PF
NLC453232T-3R3K-PF
NLC453232T-3R9K-PF
NLC453232T-4R7K-PF
NLC453232T-5R6K-PF
NLC453232T-6R8K-PF
NLC453232T-8R2K-PF
Measurement equipment
Manufacturer
Keysight Technologies
ADEX
Th
e
Measurement item
Product No.
L, Q
4294A
DC resistance
AX-114N
* Equivalent measurement equipment may be used.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/7)
20200604
inductor_commercial_decoupling_nlc453232_en.fm
I N D U C T O R S
NLC453232 type
Q
(µH)
10
12
15
18
22
27
33
39
47
56
68
82
100
120
150
180
220
270
330
L, Q measuring
frequency
DC resistance
(MHz)
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
2.52
0.796
0.796
0.796
0.796
0.796
0.796
0.796
(Ω )max.
0.5
0.6
0.7
0.8
0.9
1.2
1.4
1.6
1.9
2.2
2.6
3.5
4
4.5
6.5
7.5
9
11
13
Rated current
Part No.
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
L
Tolerance
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
min.
10
10
10
10
10
10
10
10
10
10
10
10
(mA)max.
550
500
450
400
370
330
300
280
260
240
220
200
180
160
140
120
120
100
90
NLC453232T-100K-PF
NLC453232T-120K-PF
NLC453232T-150K-PF
NLC453232T-180K-PF
NLC453232T-220K-PF
NLC453232T-270K-PF
NLC453232T-330K-PF
NLC453232T-390K-PF
NLC453232T-470K-PF
NLC453232T-560K-PF
NLC453232T-680K-PF
NLC453232T-820K-PF
NLC453232T-101K-PF
NLC453232T-121K-PF
NLC453232T-151K-PF
NLC453232T-181K-PF
NLC453232T-221K-PF
NLC453232T-271K-PF
NLC453232T-331K-PF
Manufacturer
ADEX
Th
e
Measurement item
Product No.
L, Q
4294A
DC resistance
AX-114N
(2/7)
20200604
I N D U C T O R S
NLC453232 type
L FREQUENCY CHARACTERISTICS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
10000
331K
1000
271K
221K
181K
151K
121K
101K
820K
680K
560K
100
470K
390K
Inductance(µH)
330K
270K
220K
180K
150K
120K
10
100K
8R2K
6R8K
5R6K
4R7K
3R9K
1
3R3K
2R7K
2R2K
1R8K
1R5K
0.1
0.01
0.1
1
1R2K
1R0K
10
100
Frequency(MHz)
Th
e
Product No.
Manufacturer
4294A
(3/7)
20200604
I N D U C T O R S
NLC453232 type
INDUCTANCE VS. DC BIAS CHARACTERISTICS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
1000
331K
271K
221K
181K
151K
121K
100
101K
820K
680K
560K
470K
390K
330K
270K
Inductance(µH)
220K
180K
150K
120K
10
100K
8R2K
6R8K
5R6K
4R7K
3R9K
3R3K
2R7K
2R2K
1R8K
1R5K
1R2K
1
1R0K
0.1
0.01
0.1
1
10
DC current(A)
Th
e
Product No.
Manufacturer
4285A+42841A+42842C
(4/7)
20200604
I N D U C T O R S
NLC453232 type
IMPEDANCE VS. FREQUENCY CHARACTERISTICS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
1000000
331K
100000
271K
221K
151K
121K
101K
560K
470K
330K
270K
220K
150K
181K
10000
820K
680K
390K
180K
1000
120K
100K
6R8K
5R6K
3R9K 3R3K
1R0K
1R2K
100
1R5K
1R8K
2R2K
2R7K
4R7K
10
1
0.1
0.1
8R2K
1
10
100
Frequency(MHz)
Th
e
Product No.
Manufacturer
4294A
(5/7)
20200604
I N D U C T O R S
NLC453232 type
SHAPE & DIMENSIONS
PACKAGING STYLE
REEL DIMENSIONS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
R0.2
(0.6)
0.5
(3.3)
(0.6)
3.2±0.2
ø60
C0.5
4.5±0.3
0.5
2.6±0.1
120
3.2±0.2
2.0±0.5
(1.0)
Dimensions in mm
ø13.0±0.5
13
ø21.0±0.8
17
ø180
Dimensions in mm
Sprocket
hole
B
2.8
2.00±0.05 4.00±0.10
1.5
3
1.5
Dimensions in mm
K
12.0±0.30
1.5 +0.1
–0
0.4
5.50±0.05
RECOMMENDED LAND PATTERN
1.75±0.1
TAPE DIMENSIONS
Cavity
A
8.00±0.10
Dimensions in mm
Type
NLC453232
Package quantity
Soldering
Natural
cooling
255°C
230°C
Th
e
Temperature
K
3.2
500 pcs/reel
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Peak
230°C
B
4.9
PACKAGE QUANTITY
RECOMMENDED REFLOW PROFILE
Preheating
A
3.6
Operating
Storage
Individual
temperature range
temperature range
weight
–40 to +105 °C
–40 to +105 °C
180 mg
Operating temperature range includes self-temperature rise.
The storage temperature range is for after the assembly.
180°C
10s max.
150°C
90 to 120s
40s
Time
(6/7)
20200604
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is within 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
Th
e
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(7/7)
20200604
很抱歉,暂时无法提供与“NLC453232T-121K-PF”相匹配的价格&库存,您可以联系我们找货
