PFC3125ER-451K03E-00 数据手册
January 2014
Choke Coils for PFC
Pin terminal type
PFC
PFC3514QM
PFC3318QM
PFC3519QM
PFC3819QM
PFC4124QM
PFC2723ER
PFC3125ER
PFC3525ER
series
(2/19)
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
○ The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH
or less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
○ Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
○ Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
○ Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
○ Use a wrist band to discharge static electricity in your body through the grounding wire.
○ Do not expose the products to magnets or magnetic fields.
○ Do not use for a purpose outside of the contents regulated in the delivery specifications.
○ The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/Aviation equipment
(8) Public information-processing equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(9) Military equipment
(3) Medical equipment
(10) Electric heating apparatus, burning equipment
(4) Power-generation control equipment
(11) Disaster prevention/crime prevention equipment
(5) Atomic energy-related equipment
(12) Safety equipment
(6) Seabed equipment
(13) Other applications that are not considered general-purpose
(7) Transportation control equipment
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
transformer_dk1_pfc_en
(3/19)
Choke Coils for PFC
PFC Series
Overview of the PFC Series
■ FEATURES
○ A low height(15.5 to 27mm in height) is achieved
○ Large current is achieved in a small shape
■ APPLICATION
AV equipment, digital consumer electronics
■ PART NUMBER CONSTRUCTION
PFC
3514QM
Series name
Core size
351
K
Inductance
code
Inductance
tolerance
350 35uH (35x100)
351 350uH (35x101)
352 3500uH(35x102)
J
K
L
M
07
E
Rated Peak
current code✽1
±5%
±10%
±15%
±20%
01
07
10
Control mark
Control mark
1A
7A
10A
■ OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Type
PFC3514QM
PFC3318QM
PFC3519QM
PFC3819QM
PFC4124QM
PFC2723ER
PFC3125ER
PFC3525ER
Operating
temperature✽2
Storage
temperature✽3
Package quantity
Individual weight✽4
(°C)
–30 to +120
–30 to +120
–30 to +120
–30 to +120
–30 to +120
–30 to +120
–30 to +120
–30 to +120
(°C)
–40 to +80
–40 to +80
–40 to +80
–40 to +80
–40 to +80
–40 to +80
–40 to +80
–40 to +80
(pieces/box)
175
140
140
100
90
150
120
120
(g)
40.0
27.6
50.3
60.5
91.9
34.1
49.7
57.3
✽1 The rounded-off value.
✽2 Operating temperature range includes self-temperature rise.
✽3 The Storage temperature range is for after the circuit board is mounted.
✽4 Typical weight.
○ RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://www.tdk.co.jp/rohs/
○ Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm.
· All specifications are subject to change without notice.
(4/19)
PFC QM series
PFC3514QM Type
■ SHAPE & DIMENSIONS
Dimensions in mm
Type
D
W
H
P1
P2
F
PFC3514QM
30.0max.
37.0max.
15.5max.
7.5
5.0
25.0
■ RECOMMENDED LAND PATTERN
5
5
5
6
5
7
8
3
2
7.5
1
7.5
12.5
25
4
5
■ CIRCUIT DIAGRAM
Dimensions in mm
(5/19)
PFC QM series
PFC3514QM Type
■ ELECTRICAL CHARACTERISTICS
□ CHARACTERISTICS
SPECIFICATION TABLE
Mount method
Part No.
Frequency
(kHz)min
PFC output
Inductance
Rated peek
Turn ratio
power
(µH)
current✽1
(Np/Npd)
(W)
(A)
PFC3514QM-351K04B-00
Through hole
65
100
350
3.7
10.0
PFC3514QM-281K05B-00
Through hole
65
125
280
4.6
9.8
PFC3514QM-231K06B-00
Through hole
65
150
230
5.5
9.6
○ Measurement equipment✽2
Measurement item
Inductance
DC bias characteristics
Product No.
4284A
4284A + 42841A
Manufacturer
Agilent Technologies
✽1 The rated peak current is determined by the triangular waveform current when the temperature increase is lass than 40℃ during continuous operation.
✽2 Equivalent measurement equipment may be used.
□ INDUCTANCE
CHANGE vs. DC BIAS CHARACTERISTICS GRAPH
DC current(A)
(6/19)
PFC QM series
PFC3318QM Type
Dimensions in mm
Type
D
W
H
P1
P2
F
PFC3318QM
28.0max.
35.0max.
20.0max.
7.5
5.0
22.5
5
3
5
6
5
7
2
7.5
8
1
7.5
22.5
4
5
11.25
5
■ CIRCUIT DIAGRAM
Dimensions in mm
(7/19)
PFC QM series
PFC3318QM Type
□ CHARACTERISTICS
SPECIFICATION TABLE
Mount method
Part No.
Frequency
(kHz)min
PFC output
Inductance
Rated peek
Turn ratio
power
(µH)
current✽1
(Np/Npd)
(W)
(A)
PFC3318QM-601K03B-00 Through hole
50
75
600
2.8
9.0
PFC3318QM-601K03E-00 Through hole
50
75
600
2.8
9.6
PFC3318QM-451K04B-00 Through hole
50
100
450
3.7
9.0
Measurement item
Inductance
Product No.
4284A
4284A + 42841A
Manufacturer
□ INDUCTANCE
DC current(A)
(8/19)
PFC QM series
PFC3519QM Type
Dimensions in mm
Type
D
W
H
P1
P2
F
PFC3519QM
30.0max.
37.0max.
20.0max.
7.5
5.0
25.0
5
5
5
6
5
7
8
3
2
7.5
1
7.5
12.5
25
4
5
■ CIRCUIT DIAGRAM
Dimensions in mm
(9/19)
PFC QM series
PFC3519QM Type
□ CHARACTERISTICS
SPECIFICATION TABLE
Mount method
Part No.
Frequency
(kHz)min
PFC output
Inductance
Rated peek
Turn ratio
power
(µH)
current✽1
(Np/Npd)
(W)
(A)
PFC3519QM-451K04E-00 Through hole
50
100
450
3.7
10
PFC3519QM-301K06B-00 Through hole
50
150
300
5.5
9.8
PFC3519QM-231K07B-00 Through hole
50
200
230
7.4
9.6
Measurement item
Inductance
Product No.
4284A
4284A + 42841A
Manufacturer
□ INDUCTANCE
DC current(A)
(10/19)
PFC QM series
PFC3819QM Type
Dimensions in mm
Type
D
W
H
P1
P2
F
PFC3819QM
33.5max.
40.0max.
20.0max.
7.5
5.0
28.0
5
5
5
6
5
7
8
14
28
4
5
■ CIRCUIT DIAGRAM
3
2
7.5
1
7.5
Dimensions in mm
(11/19)
PFC QM series
PFC3819QM Type
□ CHARACTERISTICS
SPECIFICATION TABLE
Mount method
Part No.
Frequency
(kHz)min
PFC output
Inductance
Rated peek
Turn ratio
power
(µH)
current✽1
(Np/Npd)
(W)
(A)
PFC3819QM-301K06E-00 Through hole
50
150
300
5.5
9.8
PFC3819QM-231K07D-00 Through hole
50
200
230
7.4
9.6
PFC3819QM-181K09B-00 Through hole
50
250
180
8.8
9.5
PFC3819QM-151K11B-00 Through hole
50
300
150
11.1
9.8
Measurement item
Inductance
Product No.
4284A
4284A + 42841A
Manufacturer
□ INDUCTANCE
DC current(A)
(12/19)
PFC QM series
PFC4124QM Type
Dimensions in mm
Type
D
W
H
P1
P2
F
PFC4124QM
38.0max.
43.0max.
25.0max.
7.5
5.0
32.0
5
5
5
6
5
7
8
16
32
4
5
■ CIRCUIT DIAGRAM
3
2
7.5
1
7.5
Dimensions in mm
(13/19)
PFC QM series
PFC4124QM Type
□ CHARACTERISTICS
SPECIFICATION TABLE
Mount method
Part No.
Frequency
(kHz)min
PFC output
Inductance
Rated peek
Turn ratio
power
(µH)
current✽1
(Np/Npd)
(W)
(A)
PFC4124QM-181K09D-00 Through hole
50
250
180
8.8
9.5
PFC4124QM-151K11D-00 Through hole
50
300
150
11.1
9.8
Measurement item
Inductance
Product No.
4284A
4284A + 42841A
Manufacturer
□ INDUCTANCE
DC current(A)
(14/19)
PFC ER series
PFC2723ER Type
Dimensions in mm
Type
D
W
H
P1
P2
F
PFC2723ER
25.0max.
28.0max.
25.0max.
20.0
10.0
20.0
10
10
4
5
2
1
■ CIRCUIT DIAGRAM
Dimensions in mm
(15/19)
PFC ER series
PFC2723ER Type
□ CHARACTERISTICS
SPECIFICATION TABLE
Mount method
Part No.
Frequency
(kHz)min
PFC output
Inductance
Rated peek
Turn ratio
power
(µH)
current✽1
(Np/Npd)
(W)
(A)
PFC2723ER-601K02B-00 Through hole
50
75
600
2.4
9.8
PFC2723ER-421K03B-00 Through hole
50
100
420
3.4
10.8
Measurement item
Inductance
Product No.
4284A
4284A + 42841A
Manufacturer
□ INDUCTANCE
DC current(A)
(16/19)
PFC ER series
PFC3125ER Type
Dimensions in mm
Type
D
W
H
P1
P2
P3
P4
F
PFC3125ER
26.0max. 33.0max. 27.0max. 9.5
3.5
16.5
6.5
21.0
9.5
16.5
3.5
13
7
8
5
4
6.5
3
6.5
6.5
2
1
10.5
21
6
■ CIRCUIT DIAGRAM
6.5
Dimensions in mm
(17/19)
PFC ER series
PFC3125ER Type
□ CHARACTERISTICS
SPECIFICATION TABLE
Mount method
Part No.
Frequency
(kHz)min
PFC output
Inductance
Rated peek
Turn ratio
power
(µH)
current✽1
(Np/Npd)
(W)
(A)
PFC3125ER-451K03E-00 Through hole
50
100
450
2.7
10.0
PFC3125ER-301K05B-00 Through hole
50
150
300
4.9
10.4
PFC3125ER-231K06B-00 Through hole
50
200
230
6.4
9.0
Measurement item
Inductance
Product No.
4284A
4284A + 42841A
Manufacturer
□ INDUCTANCE
DC current(A)
(18/19)
PFC ER series
PFC3525ER Type
Dimensions in mm
Type
D
W
H
P1
P2
P3
P4
F
PFC3525ER
27.5max. 37.0max. 27.0max. 9.5
3.5
16.5
6.5
22.0
9.5
16.5
3.5
13
7
8
5
4
6.5
3
6.5
6.5
2
1
6.5
11
22
6
■ CIRCUIT DIAGRAM
Dimensions in mm
(19/19)
PFC ER series
PFC3525ER Type
□ CHARACTERISTICS
SPECIFICATION TABLE
Mount method
Part No.
Frequency
(kHz)min
PFC output
Inductance
Rated peek
Turn ratio
power
(µH)
current✽1
(Np/Npd)
(W)
(A)
PFC3525ER-301K04E-00 Through hole
50
150
300
4.1
10.4
PFC3525ER-231K06E-00 Through hole
50
200
225
5.6
10.0
PFC3525ER-181K09B-00 Through hole
50
250
180
9.5
10.5
Measurement item
Inductance
Product No.
4284A
4284A + 42841A
Manufacturer
□ INDUCTANCE
DC current(A)
PFC3125ER-451K03E-00 价格&库存
很抱歉,暂时无法提供与“PFC3125ER-451K03E-00”相匹配的价格&库存,您可以联系我们找货
