InvenSense Firefly Developer’s Kit and
SensorStudio
To enable rapid prototyping and development of IoT applications we have created the FireFly
Development Kit. The Kit is composed of 3 critical components. The first being ICM-30630 with
integrated sensor framework software, the second is our new development tool, SensorStudio, and lastly
the Arduino Zero board.
A 3rd party sensor shield comes with the kit so you can leverage compass, pressure, and proximity
sensors. The sensor software that runs wholly on the ICM-30630 supports these additional sensors, this
software solution is also MCU agnostic. The on board cortex M0 is an open platform that acts as a sensor
hub and houses the sensor framework software. The remaining memory space is available for developers
to implement their own logic.
SensorStudio is our new development tool used to ease the development and programming of the FireFly
platform. The simple GUI uses sensors blocks that can be arranged in elegant flow charts for developers
to run and validate their program, this makes for rapid prototyping application development. InvenSense
supplies our standard sensor block functions derived from our sensor framework software. Developers
can also create their own custom sensor functions and verify their functionality in SensorStudio.
SensorStudio lets you visually assemble elements in a logical way and access all the necessary
visualizations that fully support the sensor fusion design cycle needs. SensorStudio lets you program and
add your own sensors to the Sensor Framework via a documented set of APIs to control I2C, GPIO, tasks
and timers, in a way the complexity of real-time OS is not visible. SensorStudio brings a unique level of
simplification and integration the IoT market needs to build Smart applications faster.
This is also our first ever development kit that is plug in compatible with Arduino. Arduino has a massive
following and is a popular choice for developers due to the open nature of their software and hardware.
The Arduino Zero contains an ARM Cortex M0+ MCU from Atmel. Once the ICM-30630 memory is fully
used, the cortex M0+ provides plenty of additional horsepower and memory space for application
development. Another benefit is the added connectivity the Zero board has with a plethora of additional
shield from Arduino.”
很抱歉,暂时无法提供与“STUDIO-30630-EVB”相匹配的价格&库存,您可以联系我们找货
