TFM201208ALD-R47MTCA 数据手册
SPEC. No. C519NAA00003
DATE June. 12. 2018
SPECIFICATION
To
Xiaomi
CUSTOMER’S PRODUCT NAME
TDK’S PRODUCT NAME
THIN FILM INDUCTOR
TFM201208ALD-TCA Series
RECEIPT CONFIRMATION
DATE:
TDK Corporation
Sales
Electronic Components Sales &
Marketing Group
APPROVED
Person in charge
YEAR
MONTH
DAY
Engineering
TDK Corporation
Magnetics Business Group
APPROVED
CHECKED
Person in charge
Scope
This specifications applies to THIN FILM INDUCTOR
TFM201208ALD-TCA Series to be delivered to Xiaomi.
Product identification
TFM
2012
(1)
(2)
08
(3)
ALD
(4)
R47
(5)
M
(6)
(1) Part Number
(2) Product dimensions (Length x Width)
(3) Product height
(4) Product identification number
T
(7)
CA
(8)
(5) Inductance value
(6) Inductance tolerance
(7) Packaging style designation
(8) Control mark
Mentioned item
1. Shapes and dimension and an equivalent circuit
2. Electrical characteristics
3. Storage temperature range
4. Operating temperature range
5. Structure and used material
6. Reliability test
7. Recommended footprint
8. Recommended reflow pattern
9. Packaging
10. Attention in case of using
11. Packaging form
Others
In case any matter other than stated in this specification should take place,
it shall be decided upon on a case by case basis.
Please return a copy of this specification document with your signature to us within 2 months
after this document is issued.
If a copy of this document with your signature is not received within the above mentioned period
after its issue date, the product specification will be deemed to have been accepted by you.
Change history
No.
DATE
DRAWN
MAGNETICS BUSINESS GROUP
TDK Corporation
CHANGE ITEM
DATE ISSUED
REF. No.
PAGE.
June. 12. 2018
C519NAA00003
1/7
0.8 Max
Side view
Bottom view
Terminal view
1.25 +/-0.2
2.0 +/-0.2
0.5 +/-0.3
Terminal electrode
Unit : mm
2-1. Electrical spec. (Tentative SPEC)
Part No.
TDK Item name
Rdc [mΩ]
Inductance
Isat [A]
Itemp [A]
[µH] @1MHz
Max
Typ
Max
Typ
Max
Typ
0.47 ±20%
28
26
4.5
5.0
4.1
4.3
Isat : Current flows and the initial value of inductance has fallen by 30%
Itemp : Current flows and the temperature has risen to 40°C
Rated Current: The less value which is Isat Max or Itemp Max.
Rated Voltage of these items: 20V Max.
2-2. Test Equipment
Inductance
Agilent 4294A Impedance analyzer or suitable. (OSC=0.5V / Frequency=1MHz)
Rdc
Digital Milliohm Meter
2-3. Measuring condition
Unless otherwise specified, measurement should be performed at 5 to 35°C and 35 to 85%RH.
However, for referee purpose at 25+/-5 °C and 40 to 70%RH.
2-4. MSL
MSL Level 1
TDK Corporation
REF. No.
PAGE.
C519NAA00003
2/7
3-1. Condition for storage before mounting.
Store this product under the condition of 5 to 40°C ,20 to 75%RH
and use within 6 months from the delivery date.
3-2. Condition for storage after mounting.
-40°C to +85°C
-40°C to +85°C
Self temperature rise : 40°C max. (Room temperature measure)
It’s less than 125 degrees, and please use product temperature
by ambient temperature + self temperature-rise.
5. Product structure and used material
Appearance
Magnetic
material
Marking
Terminal
Item
Magnetic material
Terminal
Marking
TDK Corporation
Material
Metal alloy
Base : Conductive resin
Plating : Ni-Sn
TiO2
REF. No.
PAGE.
C519NAA00003
3/7
6.Reliability test
Item
Specifications
Solder ability
The terminal electrodes should be covered
by new solder over than 95%.
Inductance variation to be within ±10% of
the initial value.
There shall be no mechanical damages.
Soldering heat
resistance
Test conditions
Apply cream solder to the printed PC board.
Refer to clause 8 for Reflow profile.
Reflow of the following profile is performed fours.
Pre heat :
150~180°C
60~120sec.
Peak : 260°Cmax. 10sec.max.
230°C zone
30~50sec
Strength on PC
board bending
Reflow times 3
After the samples shall be soldered on PCB, the test shall be done.
Apply the load in direction of the arrow until the bending
reaches 2.0mm. (PCB thickness = 1.6mm)
R10
Unit : mm
2.0
45
45
High temperature
resistance with
load
the initial value.
Temperature
: 85±2°C
Applied bias
: Rated current
Testing time
: 500±12 hours
Humidity
resistance with
load
the initial value.
Temperature
: 60±2°C, Humidity : 90~95%RH
Applied bias
: Rated current : 1hr. on / 3hr. off
Testing time
: 500±12 hours
Thermal shock
the initial value.
Temperature
: -40±2°C / +85±2°C
Stable time
: 30min for each temperature.
Test cycle
: 100 Cycle
Low temperature
storage
the initial value.
the initial value.
Temperature
: -40±2°C
Testing time
: 500±12 hours
Frequency
: 10~500Hz
Amplitude
: 1.5mm
Dimension and times : X, Y and Z directions for 2 hours each.
Share force
: 10 N
After the samples shall be soldered on PCB and attach to the
weight JIG, the test shall be done.
Weight
: 150g
Drop height
: 1.5m
Direction
: 6 directions / 1 cycle
n of drop cycles : 15 cycles
Vibration
Share force
Drop
There shall be no remove to PC board.
Mounting Condition :
PCB Thickness : 1.6mm
Reflow Profile, Land Pattern and Screen thickness
: Refer to the 7.Recommended footprint and 8. Recommended reflow pattern on P5
Solder : Sn-3Ag-0.5Cu (M705)
TDK Corporation
REF. No.
PAGE.
C519NAA00003
4/7
B
Unit : mm
A
Mark
A
B
C
TDK Reference
0.6
1.2
1.2
Possible to replace
0.8
0.5
1.3
C
A
Screen thickness : 0.08 mm
8.Recommended reflow pattern (Please use this product by reflow soldering)
8-1. Profile for Pb-free solder
Peak 245°C
230°C
180°C
30~50sec.
150°C
60 ~ 120sec.
9.Packaging
The packaging must be done not to receive any damage transporting and storing.
The following matters are mentioned on bar code label.
1) Your product part number
2) Our product identification
3) Shipment number*
4) Quantity
5) Shipment day
*Shipment number[e.g.]
OO OO O OOOOO OO
(1) (2) (3)
(4)
(5)
(1)Our control number
(2)Last digit of A.D
(3)Shipment month (A ~ H : Jan. ~ Aug. , J ~ M : Sep. ~ Dec.)
(4)Sequence number
(5)Control mark
10.Attention in case of using
1) In case of using this product, please avoid following matters.
Splashing water or salt water
Dew condenses
Toxic gas (Hydrogen sulfide, Sulfurous acid, Chlorine, Ammonia, etc.)
Vibrations or shocks which exceed the specified condition
2) Please be careful for the stress to this product by board flexure or something after the mounting.
3) This product is only for reflow soldering. (is not available for flow soldering)
4) Please do enough packaging test in case of using.
TDK Corporation
REF. No.
PAGE.
C519NAA00003
5/7
11.Packaging form
11-1.Tape dimensions
Sprocket hole
Cavity
D
E
K
B
Career tape material : Polystyrene
W
F
A
Cover tape material : Polystyrene
Q
t
P
G
H
Unit:mm
Mark
A
B
D
E
F
G
H
Dim.
1.55+/-0.10
2.35+/-0.10
1.50+0.10/0
1.75+/-0.10
3.50+/-0.05
2.00+/-0.05
4.00+/-0.10
Mark
K
P
Q
t
W
Dim.
1.10+/-0.05
4.00+/-0.10
1.00 min
0.25+/-0.05
8.00+/-0.20
11-2.Reel dimensions
Unit:mm
W2
Label
R
B
D
Mark
A
B
C
D
Dim.
180.0+/-2.0
60.0min.
13.0+/-0.2
21.0+/-0.8
Mark
E
W1
W2
R
Dim.
2.0+/-0.5
8.4+2.0/0
14.4max.
1.0
Shaded portion is hole
C
E
* Reel material : Polystyrene
Label
A
W1
11-3. Shape of packing
160mm MIN.
Empty compartment
Taping
300mm MIN.
200mm MIN
Packing quantity: 3,000 pcs./ reel
11-4.Cover tape peel strength
The force for tearing off cover tape is 0.1~0.7(N) in the arrow direction at the following conditions.
165~180°
Top cover tape
Carrier tape
TDK Corporation
REF. No.
PAGE.
C519NAA00003
6/7
INSTRUCTIONS IN USING THIS PRODUCT
Please read the instructions here before you use this product.
INSTRUCTIONS ON SAFETY
When use the products, be careful to mention below for safety using.
CAUTION!
STORAGE
* Store this product under the conditions which are defined in the catalogue or the instruction book.
Confirm the soldering property before using if you have stored the product over the conditions
* Don’t store this product under the influence of the poisonous gases(such as hydrogen sulfide ,
sulfurous acid , chlorine and ammonia gas).
* Avoid the direct rays of the sun and dew condensation.
USING CONDITIONS
* Use this product under the conditions which are defined in the catalogue or the instruction book.
Temperature range and soldering property are especially to be noticed.
* This product is designed for public welfare. If you are to use itfor other purposes and if it is
beyond the conditions in the instruction book , you should make a good examination beforehand.
* Don’t use this product in the place.
∙Exposed to water or seawater.
∙With dew condensation.
∙Under the influence of the poisonous gases (such as hydrogen sulfide ,Sulfurous acid , chlorine and
ammonia gas).
∙With vibrations and impulses which are not defined in the instruction book.
* When soldering is modified after it is located on a base plate , you
should confirm the conditions which are defined in the catalogue or the instruction book.
If it is heated excessively , the product may have troubles such as short circuit , rough contact ,
lowering of a property and shortening of its tenure.
* Do the good washing after soldering and make sure there are no flukes left.
* Dry up after washing
* Don’t use the product if it is mechanically impacted by dropping and so on.
* Pay attention to stresses to the product by flections after it is located on a base plate.
APPLICATION
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment, computer
equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal
operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below,
whose performance and/or quality require a more stringent level of safety or reliability, or whose failure,
malfunction or trouble could cause serious damage to society, person or property. Please understand
that we are not responsible for any damage or liability caused by use of the products in any of the applications
below or for any other use exceeding the range or conditions set forth in this specification sheet.
1) Aerospace/Aviation equipment
6) Transportation control equipment
2) Medical equipment which directly endanger human life 7) Military equipment
3) Power-generation control equipment
8) Power-generation control equipment
4) Atomic energy-related equipment
9) Other applications that are not considered
5) Seabed equipment
general-purpose applications
If you intend to use the products in the following applications, please contact our sales office.
Transportation equipment (cars, electric trains, ships, etc.) , Public information-processing equipment,
Electric heating apparatus / burning equipment , Disaster prevention/crime prevention equipment
When using this product in general-purpose applications, you are kindly requested to take into consideration
securing protection circuit/equipment or providing backup circuits, etc., to ensure higher safety.
TDK Corporation
