TMS322512ALM-R22MTAA 数据手册
I N D U C T O R S
Inductors for power circuits
Thin-film metal magnetic material
TMS-ALM series
TMS322512ALM type
■ FEATURES
◯ By using metal magnetic material with high Saturation magnetic flux density the excellent DC bias characteristics needed for
inductors for power circuits can be achieved.
◯ With the same product shape and terminal structure as general chip parts it has excellent mounting stability characteristics and can
also be mounted to general-purpose land patterns.
◯ By using a closed magnetic circuit structure leakage flux is minimized.
■ APPLICATION
◯ Industrial equipment, HDD, SSD, DVC, DSC, smart phones, mobile display panels, portable game devices, compact power supply
modules, other
■ PART NUMBER CONSTRUCTION
TMS
322512
ALM
Series name
L×W×H dimensions
3.2×2.5×1.2 mm
Characteristic
type
1R0
M
T
AA
Inductance
(µH)
Inductance
tolerance
Packaging
style
Internal
code
■ CHARACTERISTICS SPECIFICATION TABLE
L
LMeasuring
frequency
DC resistance
Rated current*
(μH) Tolerance
(MHz)
(mΩ)max.
(mΩ)typ.
Isat
(A)max.
Itemp
(A)typ. (A)max.
(A)typ. (V)max.
0.10
0.15
0.22
0.33
0.47
0.68
1.0
1.5
2.2
3.3
4.7
6.8
10
1
1
1
1
1
1
1
1
1
1
1
1
1
8
9
11
15
21
30
37
57
77
113
151
260
360
3
5
6
10
16
23
30
46
64
97
127
220
305
14
12
10
8.6
6.9
5.5
4.6
4.0
3.3
2.5
2.2
1.8
1.6
16
14
12
9.5
7.6
6.1
5.1
4.5
3.6
2.8
2.5
2.1
1.8
13
11
9.5
7.3
6.1
5.0
4.4
3.5
3.0
2.5
2.1
1.6
1.4
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
Rated voltage
8.0
8.0
7.0
6.0
5.3
4.4
4.0
3.2
2.7
2.3
1.9
1.4
1.2
Part No.
TMS322512ALM-R10MTAA
TMS322512ALM-R15MTAA
TMS322512ALM-R33MTAA
TMS322512ALM-R47MTAA
TMS322512ALM-R68MTAA
TMS322512ALM-1R0MTAA
TMS322512ALM-1R5MTAA
TMS322512ALM-2R2MTAA
TMS322512ALM-3R3MTAA
TMS322512ALM-4R7MTAA
TMS322512ALM-6R8MTAA
TMS322512ALM-100MTAA
* Rated current: smaller value of either Isat or Itemp.
Isat: When based on the inductance change rate (30% below the initial L value)
Itemp: When based on the temperature increase (temperature increase of 40°C by self heating)
Measurement equipment
Measurement item
Product No.
L
4294A
DC resistance
Digital Milliohm Meter
Rated current Isat
4285A+42841A+42842C
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20230410
inductor_commercial_power_tms322512alm_en.xml
I N D U C T O R S
TMS322512ALM type
■ L FREQUENCY CHARACTERISTICS
100
6R8
10
3R3
4R7
2R2
Inductance(µH)
1R5
1R0
1
R68
R47
R33
R22
R15
0.1
R10
0.01
0.1
1
10
100
Frequency(MHz)
Product No.
Manufacturer
4294A
■ INDUCTANCE VS. DC BIAS CHARACTERISTICS
100
10
Inductance(µH)
100
6R8
4R7
3R3
2R2
1
1R5
1R0
R68
R47
R33
R22
0.1
0.01
R15
R10
4
6
8
10
DC current(A)
12
14
16
18
Product No.
Manufacturer
4285A+42841A+42842C
(2/4)
20230410
I N D U C T O R S
TMS322512ALM type
■ SHAPE & DIMENSIONS
■ PACKAGING STYLE
□ REEL DIMENSIONS
3.20±0.20
1.20max.
ø60min.
2.50±0.20
1.0
0.60±0.30
2.0±0.5
8.4 +2.0
–0.0
ø13±0.2
14.4max.
ø21±0.8
0.60±0.30
ø180±2.0
Dimensions in mm
1.5 +0.1
–0
2.0±0.05
4.0±0.1
B
8.0±0.2
■ RECOMMENDED LAND PATTERN
4.0±0.1
A
Cavity
2.5
K
3.5±0.1
Sprocket
hole
1.75±0.1
□ TAPE DIMENSIONS
Dimensions in mm
0.8
2.0
0.8
Type
A
B
K
TMS322512ALM
2.8
3.5
1.4
160min.
Taping
200min.
300min.
Drawing direction
■ RECOMMENDED REFLOW PROFILE
□ PACKAGE QUANTITY
Package quantity
Preheating
Soldering
Natural
cooling
Peak
250 to 260°C
Temperature
230°C
230°C
2000 pcs/reel
■ TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Operating
temperature range *
Storage
temperature range **
Individual
weight
-40 to +125°C
-40 to +125°C
0.052g
* Operating temperature range includes self-temperature rise.
** The storage temperature range is for after the assembly.
180°C
10s max.
150°C
60 to 120s
30 to 50s
Time
(3/4)
20230410
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products
REMINDERS
○ The storage period is within 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 20 to 75% RH or less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
○ Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
○ Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
○ Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
○ When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the
overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
○ Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
○ Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
○ Use a wrist band to discharge static electricity in your body through the grounding wire.
○ Do not expose the products to magnets or magnetic fields.
○ Do not use for a purpose outside of the contents regulated in the delivery specifications.
○ The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
(4/4)
20230410
TMS322512ALM-R22MTAA 价格&库存
很抱歉,暂时无法提供与“TMS322512ALM-R22MTAA”相匹配的价格&库存,您可以联系我们找货
