I N D U C T O R S
Inductors for power circuits
Wound ferrite
VLS-EX series
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
VLS6045EX type
FEATURES
Magnetic shield type wound inductor for power circuits.
High magnetic shield construction achieved by a ferrite magnetic material and compatible with high-density mounting.
Larger current and lower Rdc were achieved by optimizing the ferrite core figure.
Operating temperature range: –40 to +105°C (including self-temperature rise)
APPLICATION
TV, STB, gaming equipment, other AV equipment
PART NUMBER CONSTRUCTION
VLS
6045
EX
Series name
L×W×H dimensions
6.0×6.0×4.5 mm
Internal code
R47
N
Inductance
(µH)
Inductance
tolerance
CHARACTERISTICS SPECIFICATION TABLE
L
Measuring frequency
DC resistance
Rated current
Isat
(µH)
Tolerance
(kHz)
( )±30%
(A)max.
0.47
±30%
100
0.010
13.5
1.0
±30%
100
0.012
12.0
1.5
±30%
100
0.017
8.2
2.2
±30%
100
0.019
7.5
3.3
±30%
100
0.023
6.5
4.7
±20%
100
0.027
5.8
6.8
±20%
100
0.036
4.7
10
±20%
100
0.047
3.9
15
±20%
100
0.075
3.1
22
±20%
100
0.105
2.4
33
±20%
100
0.175
1.9
47
±20%
100
0.23
1.8
68
±20%
100
0.31
1.4
100
±20%
100
0.47
1.1
150
±20%
100
0.76
0.9
220
±20%
100
1.15
0.8
330
100
1.44
0.5
±20%
470
100
2.14
0.4
±20%
680
100
2.95
0.3
±20%
Rated current: smaller value of either Isat or Itemp.
Isat: When based on the inductance change rate (30% below the initial L value)
Itemp: When based on the temperature increase (temperature increase of 40°C by self heating)
Part No.
Itemp
(A)typ.
7.0
6.0
5.3
5.1
4.95
4.2
3.6
3.4
2.5
1.9
1.5
1.3
1.0
0.9
0.7
0.5
0.47
0.42
0.32
VLS6045EX-R47N
VLS6045EX-1R0N
VLS6045EX-1R5N
VLS6045EX-2R2N
VLS6045EX-3R3N
VLS6045EX-4R7M
VLS6045EX-6R8M
VLS6045EX-100M
VLS6045EX-150M
VLS6045EX-220M
VLS6045EX-330M
VLS6045EX-470M
VLS6045EX-680M
VLS6045EX-101M
VLS6045EX-151M
VLS6045EX-221M
VLS6045EX-331M
VLS6045EX-471M
VLS6045EX-681M
Measurement equipment
Measurement item
Product No.
L
4194A
DC resistance
VP-2941A
Rated current Isat
4284A+42841A+42842A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies, Inc. (formerly Hewlett-Packard)
Panasonic (formerly Matsushita Electric Industrial)
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/5)
20200805
inductor_commercial_power_vls6045ex_en.fm
I N D U C T O R S
VLS6045EX type
L FREQUENCY CHARACTERISTICS
681M
471M
331M
221M
151M
1000
101M
680M
470M
330M
220M
Inductance(µH)
150M
100M
6R8M
4R7M
3R3N
10
2R2N
1R5N
1R0N
R47N
0.1
0.01
0.1
1
Frequency(MHz)
10
100
Product No.
Manufacturer
4294A
(2/5)
20200805
I N D U C T O R S
VLS6045EX type
INDUCTANCE VS. DC BIAS CHARACTERISTICS
1000
681M
471M
331M
221M
100
151M
101M
680M
470M
Inductance(µH)
330M
220M
10
150M
100M
6R8M
4R7M
3R3N
2R2N
1R5N
1
1R0N
R47N
0.1
4
6
8
10
DC current(A)
12
14
16
18
Product No.
Manufacturer
4284A+42841A+42842A
(3/5)
20200805
I N D U C T O R S
VLS6045EX type
SHAPE & DIMENSIONS
PACKAGING STYLE
2.5±0.1
2.2
4.8±0.2
6.0±0.3
6.0±0.3
4.5max.
(2.6)
1.7±0.2
1.7±0.2
ø100
100
REEL DIMENSIONS
Dimensions in mm
ø13.2±0.5
13
ø330
Dimensions in mm
1.5 +0.1
–0
K
1.9
2.3
4.0±0.1
Sprocket
hole
12.0±0.3
2.0±0.1
B
5.1
0.4
5.5±0.05
RECOMMENDED LAND PATTERN
1.75±0.1
TAPE DIMENSIONS
Cavity
A
1.9
8.0±0.1
Dimensions in mm
Dimensions in mm
Type
VLS6045EX
A
6.3
B
6.3
K
4.7
PACKAGE QUANTITY
Package quantity
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
Peak
250°C
Temperature
220°C
220°C
1500 pcs/reel
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Operating
Storage
Individual
temperature range
temperature range
weight
–40 to 105 °C
–40 to 105 °C
0.6 g
Operating temperature range includes self-temperature rise.
The storage temperature range is for after the assembly.
180°C
5s
150°C
60 to 120s
40s
Time
(4/5)
20200805
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (temperature: 5 to 30°C, humidity: 0 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(5/5)
20200805
很抱歉,暂时无法提供与“VLS6045EX-3R0N”相匹配的价格&库存,您可以联系我们找货
