ZJYS81R5-2P24T-G01
ZJYS81R5-2P24T-G01
    TDK(东电化)
    SMD
ZJYS81R5-2P24T-G01 数据手册
E M C C o m p o n e n t s December 2015 Common Mode Filters For automobile signal line ZJYS81 Series ZJYS81R5 Type Caution The products in this catalog will be or have been stopped production Discontinue Issue Date Nov.4, 2015 Last Purchase Order Date Sep.29, 2017 Last Shipment Date Mar.30, 2018 Please refer to our Web site about replacement information. (2/7) E M C C o m p o n e n t s REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. Th e (1) Aerospace/Aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 20151221 / cmf_automotive_signal_zjys81r5_en.fm (3/7) E M C C o m p o n e n t s Common Mode Filters Product compatible with RoHS directive AEC-Q200 For automobile signal line pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Overview of ZJYS81R5 Type FEATURES Optimal common mode filter for removing noise without straining the transmission signal and for transmitting high-quality signals. Optimal countermeasure for common mode noise induced during data transmission for digital signal processing such as in CAN-bus systems. SMD type structure makes it optimal for surface mounting. APPLICATION CAN-bus systems, etc, PART NUMBER CONSTRUCTION ZJYS81R5 - Series • Type name 2P L Number of lines Winding type 2P 2 lines L Non code 25 Split coil Bifilar coil Product internal code 25 T Packaging style T ø330mm reel - G01 Internal code G01 OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature range Operating Storage temperature temperature (°C) (°C) ZJYS81R5 –40 to +125 –40 to +125 The Storage temperature range is for after the circuit board is mounted. Package quantity Individual weight (pieces/reel) 1,500 (g) 0.4 Th e Type RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151221 / cmf_automotive_signal_zjys81r5_en.fm (4/7) E M C C o m p o n e n t s ZJYS81R5 Type RECOMMENDED REFLOW PROFILE Soldering Natural cooling pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Preheating Peak T: Temperature T4 T3 T2 T1 t1 T3 t3 t2 t: Time Time t1 60 to 120s Soldering Temp. Time T3 t2 230°C 10 to 30s Peak Temp. T4 245°C Time t3 5s Th e Preheating Temp. T1 T2 150°C 180°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151221 / cmf_automotive_signal_zjys81r5_en.fm (5/7) E M C C o m p o n e n t s ZJYS81R5 Type SHAPE & DIMENSIONS 4 6max. 1 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Marking: TDK Marking: Product internal code Marking: Production date code 2 3 0.25 5.0max. 7.1max. 9±0.5 0.6±0.2 1.3 2.54±0.25 Dimensions in mm Dimensions in mm CIRCUIT DIAGRAM 1 4 2 3 • No polarity Th e 6.7 9.9 1.8 2.54 RECOMMENDED LAND PATTERN Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151221 / cmf_automotive_signal_zjys81r5_en.fm (6/7) E M C C o m p o n e n t s ZJYS81R5 Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE DC resistance Rated current Insulation resistance Rated voltage Part No. [10MHz] (: ) min. 500 1000 600 1000 (: )max. 0.15 0.25 0.25 0.3 (A)max. 0.5 0.5 0.5 0.5 (M: )min. 100 100 100 100 (V)max. 80 80 80 80 ZJYS81R5-2P24T-G01 ZJYS81R5-2P50T-G01 ZJYS81R5-2PL25T-G01 ZJYS81R5-2PL51T-G01 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Common mode impedance (: ) typ. 1000 2000 1000 2000 ○ Measurement equipment Measurement item Product No. Common mode impedance 4991A DC resistance 4338A Insulation resistance 4339A * Equivalent measurement equipment may be used. Manufacturer Agilent Technologies Agilent Technologies Agilent Technologies IMPEDANCE VS. FREQUENCY CHARACTERISTICS 100000 PL51 Differential mode Impedance (Ω) 10000 PL25 Differential mode P50 Common mode PL51 Common mode PL25 Common mode 1000 P24 Common mode 100 P50 Differential mode P24 Differential mode Th e 10 1 10 100 1000 Frequency (MHz) ○ Measurement equipment Product No. Manufacturer 4991A Agilent Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151221 / cmf_automotive_signal_zjys81r5_en.fm (7/7) E M C C o m p o n e n t s ZJYS81R5 Type PACKAGING STYLE pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en REEL DIMENSIONS 2.0±0.5 E A W1 ø330±4/–2 16.4+2/–0 W2 N E 22.4max. ø100±1 2 typ. N Type ZJYS81R5 1.0 ø13.0±0.5 W1 ø21.0±0.8 W2 A Dimensions in mm TAPE DIMENSIONS t P0 B W F P2 E øD0 A K P1 Dimensions in mm Type ZJYS81R5 A 6.0±0.1 B 9.8±0.1 øD0 1.5+0.1/0 E 1.75±0.1 F 7.5±0.1 P0 4.0±0.1 P1 8.0±0.1 P2 2.0±0.1 W 16.0+0.3/–0.1 K 5.20±0.1 t 0.40±0.05 500 to 560 160min. Taping 240min. Th e Drawing direction Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20151221 / cmf_automotive_signal_zjys81r5_en.fm
ZJYS81R5-2P24T-G01 价格&库存
很抱歉,暂时无法提供与“ZJYS81R5-2P24T-G01”相匹配的价格&库存,您可以联系我们找货
