Technical Data ELX1064
Effective June 2021
SMCJE
Automotive grade 1500 W Transient voltage suppressor
Applications
Product features
Automotive grade (AEC-Q101 qualified)
Low profile SMC package
Excellent clamping capability
High reliability application
1500 W peak pulse power capability at 10/1000
μs waveform
Typical IR less than 1 μA
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
Plastic package meets UL 94 V-0
flammability rating
Meets moisture sensitivity level (MSL) level 1
Terminal: tin plated, solderable per J-STD-002
UL 497B recognized.
File No. : E198449 Guide QVGQ2
Automotive chassis and safety systems
Advanced driver assistance systems (ADAS)
Communication and infotainment systems
Network systems and body electronics
Power Train controls
xEV and battery systems
Environmental compliance and general
specifications
AEC-Q101 qualified
Ordering part number
SMCJE 15 C A
Family name
VR voltage
(“-” indicates decimal point)
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
PIN configuration
H
SMCJE
Effective June 2021
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Symbol
Value
Unit
Storage operating junction temperature range
Parameter
TSTG/ TJ
-55 to +150
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
6.5
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
1500
W
Maximum instantaneous forward voltage at
100 A for unidirectional
VF
5
V
Peak forward surge current, 8.3 ms single
half sine wave1
IFSM
200
A
Typical thermal resistance junction to lead
R
JL
15
°C/W
Typical thermal resistance junction to ambient
R
JA
75
°C/W
1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only,
duty cycle = 4 per minute maximum
Mechanical parameters, pad layout- mm/inches
Millimeters
Inches
Part marking
Dimension Minimum
Maximum
Minimum
Maximum
A
5.75
6.25
0.226
0.246
B
6.90
7.40
0.272
0.291
C
2.75
3.25
0.108
0.128
D
0.95
1.52
0.037
0.060
E
7.70
8.20
0.303
0.323
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
2.15
2.62
0.085
0.103
J
2.40
0.094
K
4.20
0.165
L
3.30
0.130
Cathode band (uni-polar only)
Part marking:
xxxx = Date code
yyy- Refer to marking designator listed in Electrical
characteristics table
Packaging information - mm/inches
Drawing not to scale.
Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant)
2
www.eaton.com/electronics
Dimensions
Millimeters
Inches
A0
6.05 ± 0.3
0.238 ± 0.012
B0
8.31 ± 0.3
0.327 ± 0.012
C
330.0
13.0
D0
1.55 ± 0.1
0.061 ± 0.004
E
1.75 ± 0.2
0.069 ± 0.008
E1
13.3 ± 0.3
0.524 ± 0.012
F
7.50 ± 0.2
0.295 ± 0.008
P0
4.00 ± 0.2
0.157 ± 0.008
P1
8.00 ± 0.2
0.3145 ± 0.008
P2
2.00 ± 0.2
0.079 ± 0.008
W
16.0 ± 0.2
0.630 ± 0.008
W1
19.7 ± 2.0
0.776 ± 0.079
SMCJE
Effective June 2021
Electrical specifications (+25 °C)
Part number
VR
IR @ VR
VBR @ IT
IT
VC @ IPP
IPP
Uni-polar
Bi-polar
Marking
Uni
Bi
(V)
(µA)
min (V)
max (V)
(mA)
max (V)
(A)
SMCJE15AH
SMCJE15CAH
GEM
BEM
15
1
16.7
18.5
1
24.4
61.5
SMCJE16AH
SMCJE16CAH
GEP
BEP
16
1
17.8
19.7
1
26
57.7
SMCJE17AH
SMCJE17CAH
GER
BER
17
1
18.9
20.9
1
27.6
54.4
SMCJE18AH
SMCJE18CAH
GET
BET
18
1
1
29.2
51.4
SMCJE20AH
SMCJE20CAH
GEV
BEV
22.2
24.5
1
32.4
46.3
SMCJE22AH
SMCJE22CAH
GEX
BEX
22
1
24.4
26.9
1
35.5
42.3
SMCJE24AH
SMCJE24CAH
GEZ
BEZ
24
1
26.7
29.5
1
38.9
38.6
SMCJE26AH
SMCJE26CAH
GFE
BFE
26
1
28.9
31.9
1
42.1
35.6
SMCJE28AH
SMCJE28CAH
GFG
BFG
28
1
31.1
34.4
1
45.4
33.1
SMCJE30AH
SMCJE30CAH
GFK
BFK
30
1
33.3
36.8
1
48.4
31
SMCJE33AH
SMCJE33CAH
GFM
BFM
33
1
36.7
40.6
1
53.3
28.2
SMCJE36AH
SMCJE36CAH
GFP
BFP
36
1
40
44.2
1
58.1
25.8
SMCJE40AH
SMCJE40CAH
GFR
BFR
40
1
44.4
49.1
1
64.5
23.3
SMCJE43AH
SMCJE43CAH
GFT
BFT
43
1
47.8
52.8
1
69.4
21.6
SMCJE45AH
SMCJE45CAH
GFV
BFV
45
1
50
55.3
1
72.7
20.6
SMCJE48AH
SMCJE48CAH
GFX
BFX
48
1
53.3
58.9
1
77.4
19.4
SMCJE51AH
SMCJE51CAH
GFZ
BFZ
51
1
56.7
62.7
1
82.4
18.2
SMCJE54AH
SMCJE54CAH
GGE
BGE
54
1
60
66.3
1
87.1
17.2
SMCJE58AH
SMCJE58CAH
GGG
BGG
58
1
64.4
71.2
1
93.6
16.1
SMCJE60AH
SMCJE60CAH
GGK
BGK
60
1
66.7
73.7
1
96.8
15.5
SMCJE64AH
SMCJE64CAH
GGM
BGM
64
1
71.1
78.6
1
103
14.6
SMCJE70AH
SMCJE70CAH
GGP
BGP
70
1
77.8
86
1
113
13.3
SMCJE75AH
SMCJE75CAH
GGR
BGR
75
1
83.3
92.1
1
121
12.4
SMCJE78AH
SMCJE78CAH
GGT
BGT
78
1
86.7
95.8
1
126
11.9
SMCJE85AH
SMCJE85CAH
GGV
BGV
85
1
94.4
104
1
137
11
SMCJE90AH
SMCJE90CAH
GGX
BGX
90
1
100
111
1
146
10.3
SMCJE100AH
SMCJE100CAH
GGZ
BGZ
100
1
111
123
1
162
9.3
SMCJE110AH
SMCJE110CAH
GHE
BHE
110
1
122
135
1
177
8.5
SMCJE120AH
SMCJE120CAH
GHG
BHG
120
1
133
147
1
193
7.8
SMCJE130AH
SMCJE130CAH
GHK
BHK
130
1
144
159
1
209
7.2
SMCJE150AH
SMCJE150CAH
GHM
BHM
150
1
167
185
1
243
6.2
SMCJE160AH
SMCJE160CAH
GHP
BHP
160
1
178
197
1
259
5.8
SMCJE170AH
SMCJE170CAH
GHR
BHR
170
1
189
209
1
275
5.5
SMCJE180AH
SMCJE180CAH
GHT
BHT
180
1
201
222
1
292
5.2
SMCJE190AH
SMCJE190CAH
GHU
BHU
190
1
211
234
1
307
4.9
SMCJE200AH
SMCJE200CAH
GHV
BHV
200
1
224
247
1
324
4.7
SMCJE210AH
SMCJE210CAH
GHW
BHW
210
1
233
258
1
337
4.5
SMCJE220AH
SMCJE220CAH
GHX
BHX
220
1
246
272
1
356
4.2
SMCJE250AH
SMCJE250CAH
GJG
BJG
250
1
279
309
1
405
3.7
SMCJE300AH
SMCJE300CAH
GJK
BJK
300
1
335
371
1
486
3.1
SMCJE350AH
SMCJE350CAH
GJM
BJM
350
1
391
432
1
567
2.7
SMCJE400AH
SMCJE400CAH
GJP
BJP
400
1
447
494
1
648
2.3
SMCJE440AH
SMCJE440CAH
GJR
BJR
440
1
492
543
1
713
2.1
3
SMCJE
Effective June 2021
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
IT: Test current
VF: Forward voltage drop for Uni-directional
Pulse waveform
IPPM (% IRSM)
PPP derating in percentage (%)
Pulse derating curve
t (ms)
TJ (°C)
Peak pulse power dissipation curve
100
1500W at 10/1000 µs
PPP (KW)
10
1.0
0.1
0.001
0.01
0.1
td - Pulse width (ms)
4
1.0
10
SMCJE
Effective June 2021
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“SMCJE30AH”相匹配的价格&库存,您可以联系我们找货
