DATA SHEET
TRANSIENT VOLTAGE SUPPRESSORS
AC/DC POWER SUPPLY
SMDJ-AT
series
Product specification– June 30, 2023 V.4
RoHS compliant & Halogen free
Circuit Protection
Product Specification
Transient Voltage Suppressors
2
9
SMDJ-AT
Transient Voltage Suppressors (TVS) Data Sheet
Features
■ For surface mounted applications in order to optimize board space
■ Low profile package
■ Built-in strain relief
■ Glass passivated junction
■ Low inductance
■ Excellent clamping capability
■ 3000W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01%
■ Fast response time
■ Typical IR less than 2μA above 10V
■ High Temperature soldering: 260℃/10 seconds at terminals
■ Plastic package has underwriters laboratory flammability 94V-0
■ Meets MSL level 1, per J-STD-020
■ Safety certification: UL
■ AEC-Q101 qualified
■ IEC61000-4-2 ESD 30KV Air, 30KV contact compliance
Mechanical Data
■ Case: JEDEC DO-214AB. Molded plastic over glass passivated junction
■ Terminal: Tin plated, solderable per MIL-STD-750, Method 2026
■ Polarity: Color band denotes cathode except bi-directional models
■ Standard Packaging: 16mm tape (EIA STD RS-481)
■ Weight: 0.26g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 3000
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
6.5
Watts
IFSM
300
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
15
℃/W
Typical thermal resistance junction to ambient
RθJA
75
℃/W
Steady state power dissipation at TA=50℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above T A=25℃ per Fig.2.
2. Mounted on 8.0mm×8.0mm copper pads to each terminal.
www.ya geo.com
Jun. 30, 2023 V.4
Circuit Protection
3
9
SMDJ-AT
3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Dimensions (SMC/DO-214AB)
Product:
Millimeters
Inches
Symbol
Cathode Band
Min.
Max.
Min.
Max.
L
6.60
7.11
0.260
0.280
D
5.59
6.22
0.220
0.245
D1
2.90
3.20
0.114
0.126
T
7.75
8.13
0.305
0.320
T1
0.76
1.52
0.030
0.060
d
0.203
0.008
H
2.20
2.80
0.087
0.110
H1
2.06
2.62
0.079
0.103
D1 D
L
H1 H
d
T1
T
3.20mm
Pad:
1.75mm
4.69mm
1.75mm
Electrical Characteristics (TA=25℃)
Part Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMDJ5.0A-AT
SMDJ5.0CA-AT
RDE
DDE
5.0
6.40~7.00
10
9.2
326.1
800
SMDJ6.0A-AT
SMDJ6.0CA-AT
RDG
DDG
6.0
6.67~7.37
10
10.3
291.3
800
SMDJ6.5A-AT
SMDJ6.5CA-AT
RDK
DDK
6.5
7.22~7.98
10
11.2
267.9
500
SMDJ7.0A-AT
SMDJ7.0CA-AT
PDM
DDM
7.0
7.78~8.60
10
12.0
250.0
200
SMDJ7.5A-AT
SMDJ7.5CA-AT
PDP
DDP
7.5
8.33~9.21
1
12.9
232.6
100
SMDJ8.0A-AT
SMDJ8.0CA-AT
PDR
DDR
8.0
8.89~9.83
1
13.6
220.6
50
SMDJ8.5A-AT
SMDJ8.5CA-AT
PDT
DDT
8.5
9.44~10.40
1
14.4
208.3
SMDJ9.0A-AT
SMDJ9.0CA-AT
PDV
DDV
9.0
10.00~11.10
1
15.4
194.8
10
SMDJ10A-AT
SMDJ10CA-AT
PDX
DDX
10.0
11.10~12.30
1
17.0
176.5
5
SMDJ11A-AT
SMDJ11CA-AT
PDZ
DDZ
11.0
12.20~13.50
1
18.2
164.8
2
SMDJ12A-AT
SMDJ12CA-AT
PEE
DEE
12.0
13.30~14.70
1
19.9
150.8
2
SMDJ13A-AT
SMDJ13CA-AT
PEG
DEG
13.0
14.40~15.90
1
21.5
139.5
2
SMDJ14A-AT
SMDJ14CA-AT
PEK
DEK
14.0
15.60~17.20
1
23.2
129.3
2
SMDJ15A-AT
SMDJ15CA-AT
PEM
DEM
15.0
16.70~18.50
1
24.4
123.0
2
SMDJ16A-AT
SMDJ16CA-AT
PEP
DEP
16.0
17.80~19.70
1
26.0
115.4
2
SMDJ17A-AT
SMDJ17CA-AT
PER
DER
17.0
18.90~20.90
1
27.6
108.7
2
www.ya geo.com
Jun. 30, 2023 V.4
Circuit Protection
SMDJ18A-AT
SMDJ18CA-AT
PET
DET
4
9
SMDJ-AT
18.0
20.00~22.10
1
29.2
102.7
2
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Part Number
Device
Marking
Code
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMDJ20A-AT
SMDJ20CA-AT
PEV
DEV
20.0
22.20~24.50
1
32.4
92.6
2
SMDJ22A-AT
SMDJ22CA-AT
PEX
DEX
22.0
24.40~26.90
1
35.5
84.5
2
SMDJ24A-AT
SMDJ24CA-AT
PEZ
DEZ
24.0
26.70~29.50
1
38.9
77.1
2
SMDJ26A-AT
SMDJ26CA-AT
PFE
DFE
26.0
28.90~31.90
1
42.1
71.3
2
SMDJ28A-AT
SMDJ28CA-AT
PFG
DFG
28.0
31.10~34.40
1
45.4
66.1
2
SMDJ30A-AT
SMDJ30CA-AT
PFK
DFK
30.0
33.30~36.80
1
48.4
62.0
2
SMDJ33A-AT
SMDJ33CA-AT
PFM
DFM
33.0
36.70~40.60
1
53.3
56.3
2
SMDJ36A-AT
SMDJ36CA-AT
PFP
DFP
36.0
40.00~44.20
1
58.1
51.6
2
SMDJ40A-AT
SMDJ40CA-AT
PFR
DFR
40.0
44.40~49.10
1
64.5
46.5
2
SMDJ43A-AT
SMDJ43CA-AT
PFT
DFT
43.0
47.80~52.80
1
69.4
43.2
2
SMDJ45A-AT
SMDJ45CA-AT
PFV
DFV
45.0
50.00~55.30
1
72.7
41.3
2
SMDJ48A-AT
SMDJ48CA-AT
PFX
DFX
48.0
53.30~58.90
1
77.4
38.8
2
SMDJ51A-AT
SMDJ51CA-AT
PFZ
DFZ
51.0
56.70~62.70
1
82.4
36.4
2
SMDJ54A-AT
SMDJ54CA-AT
PGE
DGE
54.0
60.00~66.30
1
87.1
34.4
2
SMDJ58A-AT
SMDJ58CA-AT
PGG
DGG
58.0
64.40~71.20
1
93.6
32.1
2
SMDJ60A-AT
SMDJ60CA-AT
PGK
DGK
60.0
66.70~73.70
1
96.8
31.0
2
SMDJ64A-AT
SMDJ64CA-AT
PGM
DGM
64.0
71.10~78.60
1
103.0
29.1
2
SMDJ70A-AT
SMDJ70CA-AT
PGP
DGP
70.0
77.80~86.00
1
113.0
26.5
2
SMDJ75A-AT
SMDJ75CA-AT
PGR
DGR
75.0
83.30~92.10
1
121.0
24.8
2
SMDJ78A-AT
SMDJ78CA-AT
PGT
DGT
78.0
86.70~95.80
1
126.0
23.8
2
SMDJ85A-AT
SMDJ85CA-AT
PGV
DGV
85.0
94.40~104.00
1
137.0
21.9
2
SMDJ90A-AT
SMDJ90CA-AT
PGX
DGX
90.0
100.00~111.00
1
146.0
20.5
2
SMDJ100A-AT
SMDJ100CA-AT
PGZ
DGZ
100.0
111.00~123.00
1
162.0
18.5
2
SMDJ110A-AT
SMDJ110CA-AT
PHE
DHE
110.0
122.00~135.00
1
177.0
16.9
2
SMDJ120A-AT
SMDJ120CA-AT
PHG
DHG
120.0
133.00~147.00
1
193.0
15.5
2
SMDJ130A-AT
SMDJ130CA-AT
PHK
DHK
130.0
144.00~159.00
1
209.0
14.4
2
SMDJ150A-AT
SMDJ150CA-AT
PHM
DHM
150.0
167.00~185.00
1
243.0
12.3
2
SMDJ160A-AT
SMDJ160CA-AT
PHP
DHP
160.0
178.00~197.00
1
259.0
11.6
2
SMDJ170A-AT
SMDJ170CA-AT
PHR
DHR
170.0
189.00~209.00
1
275.0
10.9
2
SMDJ180A-AT
SMDJ180CA-AT
HHT
IHT
180.0
201.00~222.00
1
292.0
10.3
2
SMDJ190A-AT
SMDJ190CA-AT
HHV
IHV
190.0
211.00~233.00
1
308.0
9.7
2
SMDJ200A-AT
SMDJ200CA-AT
HHX
IHX
200.0
224.00~247.00
1
324.0
9.3
2
SMDJ210A-AT
SMDJ210CA-AT
HHZ
IHZ
210.0
237.00~263.00
1
340.0
8.8
2
SMDJ220A-AT
SMDJ220CA-AT
HIE
IIE
220.0
246.00~272.00
1
356.0
8.4
2
www.ya geo.com
Jun. 30, 2023 V.4
Circuit Protection
5
9
SMDJ-AT
Ratings and Characteristic Curves (T A=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
100
10
1
0.31×0.31″(8.0×8.0mm)
Copper Pad Area
0.1
0.1
1
100
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
1000
100
10
80
60
40
td-Pulse Width (µs)
125
150
175
100000
Uni-directional
10000
Cj (pF)
IPPM - Peak Pulse Current, %IRSM
100
Peak Value IPPM
100
Half Value IPPM (IPPM/2)
1000
Bi-directional
100
50
10/1000µs Waveform
as defined by R.E.A
10
td
1.0
2.0
3.0
4.0
Measured at
1MHz, 100mV, 0V bias
1
t-Time (ms)
Figure 5. Steady State Power Dissipation Derating
Curve
7
6
5
4
3
2
1
50
75
100
125
TA-Ambient Temperature (℃)
150
175
10
100
VRWM-Reverse Stand-Off Voltage (V)
1000
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
IFSM - Peak Forward Surve Current (A)
PM(AV), Steady State Power Dissipation (W)
75
Figure 4. Typical Junction Capacitance
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
tr=10µs
50
Figure 3. Pulse Waveform
150
25
350
300
250
200
150
100
50
10
Number of Cycles at 60Hz
100
www.ya geo.com
Jun. 30, 2023 V.4
Circuit Protection
6
9
SMDJ-AT
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
20-40 seconds
6℃/second max.
8 minutes max.
www.ya geo.com
Jun. 30, 2023 V.4
Circuit Protection
7
9
SMDJ-AT
Marking Code
Cathode Band
YXXX
YXXX
RDE
Logo
DDE
Intermal Control Code
Marking Code
Logo
Marking Code
Part Number Code
SMDJ XXX C A
AT / XXXX
Package code
TR7: 7 inch reel package
TR13: 13 inch reel package
Internal Control Code
5% VBR Voltage Tolerance
Bidirectional
VRWM Voltage
Series Code
Ordering Code for Different Package
7 inch reel package: Add suffix “ /TR7 ” at the end of the part number, such as SMDJXXXCA-AT/TR7
13 inch reel package: Add suffix “ /TR13 ” at the end of the part number, such as SMDJXXXCA-AT/TR13
www.ya geo.com
Jun. 30, 2023 V.4
Circuit Protection
8
9
SMDJ-AT
Packaging
Tape
P0
P1
P2
D0
B
Symbol
Dimension (mm)
W
16.00±0.20
P0
4.00±0.10
P1
8.00±0.10
P2
2.00±0.10
D0
Φ1.5±0.10
D1
Φ1.5±0.10
E
1.75±0.10
K0
F
7.50±0.10
SECTION B-B
A0
6.27±0.10
B0
8.30±0.10
K0
3.15±0.15
T
0.30±0.05
D2
Φ178.0±2.0
D3
Φ50.0Min.
D4
Φ13.0±0.5
W1
20.0±2.0
T
E
F
W
B0
D1
A
A
B
A0
SECTION A-A
7” Reel
D4
D3
D2
W1
Quantity: 500PCS
13” Reel
D5
Φ330.0±2.0
D6
Φ13.5±0.5
H
2.5±1.0
W2
20.0±2.0
Quantity: 3000PCS
www.ya geo.com
Jun. 30, 2023 V.4
Circuit Protection Components
LEGAL DISCLAIMER
YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any
errors, inaccuracies or incompleteness contained in any product related information, including but not limited
to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or
improvements to product related information at any time and without notice.
YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any
particular purpose or the continuing production of any of its products. To the maximum exten t permitted by
law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii)
any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all
implied warranties, including warranties of fitness for a particular purpose, non -infringement and
merchantability.
YAGEO products are designed for general purpose applications under normal operation and usage conditions.
Please contact YAGEO for the applications listed below which require especially high reliability for the
prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace
equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster
prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly
public information network equipment, data-processing equipment , Medical devices, Military equipment, Power
generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and
Undersea equipment, or for any other application or use in which the failure of YAGEO products could result
in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates
do not recommend the use of commercial or automotive grade products for high reliability
applications or manned space flight.
Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights
for revising this content without further notification, as long as products are unchanged. Any product change
will be announced by PCN.
www.yageo.com
