Technical Data 11217
Effective March 2021
Supersedes November 2020
SMDJE
3000 W Transient voltage suppressor
Applications
Product features
Low profile SMC package
Excellent clamping capability
3000 W peak pulse power capability at
10/1000 μs waveform
Typical IR less than 1 μA above 14 V
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
High temperature reflow soldering:
+260 °C /40 s at terminal
Plastic package meets UL 94 V-0 flammability
rating
Meets moisture sensitivity level (MSL) level 1
Terminal: Solder plated leads,
solderable per J-STD-002
For surface mounted applications in order to
optimize board space
UL 497B recognized.
File No. : E198449 Guide QVGQ2
PIN configuration
Consumer electronics
Telecommunications
Computing and servers
Appliances
Industrial automation
Power conversion
Environmental compliance and general
specifications
HALOGEN
Pb HF
FREE
Ordering part number
SMDJE 5-0 C A
Family name
VR voltage
(“-” indicates decimal point)
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
SMDJE
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Parameter
Symbol
Value
Unit
TSTG/ TJ
-55 to +150
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
6.5
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
3000
W
Maximum instantaneous forward voltage at
100 A for unidirectional
VF
5.0
V
Peak forward surge current, 8.3 ms single
half sine wave1
IFSM
300
A
Typical thermal resistance junction to lead
R
JL
15
°C/W
Typical thermal resistance junction to ambient
R
JA
75
°C/W
Storage operating junction temperature range
1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only,
duty cycle = 4 per minute maximum
Mechanical parameters, pad layout- mm
Part marking
Millimeters
Dimension Minimum
Inches
Maximum
Minimum
Maximum
A
5.75
6.25
0.226
0.246
B
6.90
7.40
0.272
0.291
C
2.75
3.25
0.108
0.128
D
0.95
1.52
0.037
0.060
E
7.70
8.20
0.303
0.323
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
2.15
2.62
0.085
0.103
J
2.40
K
L
Cathode band (Uni-polar only)
Part marking: xxxx = Date code
yyy- Refer to marking designator
listed in Electrical Characteristics table
0.094
4.20
3.30
Packaging information (mm)
0.165
0.130
Dimensions
Millimeters
Inches
Drawing not to scale.
A0
6.05 ± 0.3
0.238 ± 0.012
Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel
(EIA-481 compliant)
B0
8.31 ± 0.3
0.327 ± 0.012
C
330.0
13.0
D0
1.55 ± 0.1
0.061 ± 0.004
E
1.75 ± 0.2
0.069 ± 0.008
E1
13.3 ± 0.3
0.524 ± 0.012
F
7.50 ± 0.2
0.295 ± 0.008
2
www.eaton.com/electronics
P0
4.00 ± 0.2
0.157 ± 0.008
P1
8.00 ± 0.2
0.3145 ± 0.008
P2
2.00 ± 0.2
0.079 ± 0.008
W
16.0 ± 0.2
0.630 ± 0.008
W1
19.7 ± 2.0
0.776 ± 0.079
SMDJE
Electrical characteristics (+25 °C)
Part number
Uni-polar
Bi-polar
Marking
Uni
Bi
VR
(V)
IR @ VR
(μA)
VBR @ IT
min (V)
max (V)
IT
(mA)
VC @ IPP
max (V)
IPP
(A)
SMDJE5-0A
SMDJE5-0CA
HDE
IDE
5
800
6.4
7
10
9.2
326.1
SMDJE6-0A
SMDJE6-0CA
HDG
IDG
6
800
6.67
7.37
10
10.3
291.3
SMDJE6-5A
SMDJE6-5CA
HDK
IDK
6.5
500
7.22
7.98
10
11.2
267.9
SMDJE7-0A
SMDJE7-0CA
HDM
IDM
7
200
7.78
8.6
10
12
250
SMDJE7-5A
SMDJE7-5CA
HDP
IDP
7.5
100
8.33
9.21
1
12.9
232.6
SMDJE8-0A
SMDJE8-0CA
HDR
IDR
8
50
8.89
9.83
1
13.6
220.6
SMDJE8-5A
SMDJE8-5CA
HDT
IDT
8.5
10.4
1
14.4
208.3
SMDJE9-0A
SMDJE9-0CA
HDV
IDV
9
10
10
11.1
1
15.4
194.8
SMDJE10A
SMDJE10CA
HDX
IDX
10
5
11.1
12.3
1
17
176.5
SMDJE11A
SMDJE11CA
HDZ
IDZ
11
2
12.2
13.5
1
18.2
164.8
SMDJE12A
SMDJE12CA
HEE
IEE
12
2
13.3
14.7
1
19.9
150.8
SMDJE13A
SMDJE13CA
HEG
IEG
13
2
14.4
15.9
1
21.5
139.5
SMDJE14A
SMDJE14CA
HEK
IEK
14
2
15.6
17.2
1
23.2
129.3
SMDJE15A
SMDJE15CA
HEM
IEM
15
1
16.7
18.5
1
24.4
123
SMDJE16A
SMDJE16CA
HEP
IEP
16
1
17.8
19.7
1
26
115.4
SMDJE17A
SMDJE17CA
HER
IER
17
1
18.9
20.9
1
27.6
108.7
SMDJE18A
SMDJE18CA
HET
IET
18
1
1
29.2
102.7
SMDJE20A
SMDJE20CA
HEV
IEV
22.2
24.5
1
32.4
92.6
SMDJE22A
SMDJE22CA
HEX
IEX
22
1
24.4
26.9
1
35.5
84.5
SMDJE24A
SMDJE24CA
HEZ
IEZ
24
1
26.7
29.5
1
38.9
77.1
SMDJE26A
SMDJE26CA
HFE
IFE
26
1
28.9
31.9
1
42.1
71.3
SMDJE28A
SMDJE28CA
HFG
IFG
28
1
31.1
34.4
1
45.4
66.1
SMDJE30A
SMDJE30CA
HFK
IFK
30
1
33.3
36.8
1
48.4
62
SMDJE33A
SMDJE33CA
HFM
IFM
33
1
36.7
40.6
1
53.3
56.3
SMDJE36A
SMDJE36CA
HFP
IFP
36
1
40
44.2
1
58.1
51.6
SMDJE40A
SMDJE40CA
HFR
IFR
40
1
44.4
49.1
1
64.5
46.5
SMDJE43A
SMDJE43CA
HFT
IFT
43
1
47.8
52.8
1
69.4
43.2
SMDJE45A
SMDJE45CA
HFV
IFV
45
1
50
55.3
1
72.7
41.3
SMDJE48A
SMDJE48CA
HFX
IFX
48
1
53.3
58.9
1
77.4
38.8
SMDJE51A
SMDJE51CA
HFZ
IFZ
51
1
56.7
62.7
1
82.4
36.4
SMDJE54A
SMDJE54CA
HGE
IGE
54
1
60
66.3
1
87.1
34.4
SMDJE58A
SMDJE58CA
HGG
IGG
58
1
64.4
71.2
1
93.6
32.1
SMDJE60A
SMDJE60CA
HGK
IGK
60
1
66.7
73.7
1
96.8
31
SMDJE64A
SMDJE64CA
HGM
IGM
64
1
71.1
78.6
1
103
29.1
SMDJE70A
SMDJE70CA
HGP
IGP
70
1
77.8
86
1
113
26.5
SMDJE75A
SMDJE75CA
HGR
IGR
75
1
83.3
92.1
1
121
24.8
SMDJE78A
SMDJE78CA
HGT
IGT
78
1
86.7
95.8
1
126
23.8
SMDJE85A
SMDJE85CA
HGV
IGV
85
1
94.4
104
1
137
21.9
SMDJE90A
SMDJE90CA
HGX
IGX
90
1
100
111
1
146
20.5
SMDJE100A
SMDJE100CA
HGZ
IGZ
100
1
111
123
1
162
18.5
SMDJE110A
SMDJE110CA
HHE
IHE
110
1
122
135
1
177
16.9
SMDJE120A
SMDJE120CA
HHG
IHG
120
1
133
147
1
193
15.5
SMDJE130A
SMDJE130CA
HHK
IHK
130
1
144
159
1
209
14.4
SMDJE150A
SMDJE150CA
HHM
IHM
150
1
167
185
1
243
12.3
SMDJE160A
SMDJE160CA
HHP
IHP
160
1
178
197
1
259
11.6
SMDJE170A
SMDJE170CA
HHR
IHR
170
1
189
209
1
275
10.9
SMDJE180A
SMDJE180CA
HHT
IHT
180
1
201
222
1
292
10.3
SMDJE190A
SMDJE190CA
HHV
IHV
190
1
211
234
1
307
9.7
SMDJE200A
SMDJE200CA
HHX
IHX
200
1
224
247
1
324
9.3
SMDJE210A
SMDJE210CA
HHZ
IHZ
210
1
233
258
1
337
8.8
SMDJE220A
SMDJE220CA
HIE
IIE
220
1
244
270
1
356
8.4
3
SMDJE
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
IT: Test current
VF: Forward voltage drop for Uni-directional TVS diode
Pulse waveform
150
tr = rise time to peak value
td = decay time to half value
IPPM (% IRSM)
tr=10 μs
100
PPP derating in percentage (%)
Pulse derating curve
Peak value
Half value
50
td
2.0
3.0
100
Ppp (kW)
3000 W at 10/1000 μs +25 °C
10
1.0
0.1
td-Pulse width (ms)
4
60
40
50
75
100
125
150
TJ-Initial junction temperature (°C)
Peak pulse power dissipation vs. pulse width
0.01
80
t (ms)
0.1
0.001
100
1.0
10
175
SMDJE
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“SMDJE130CA”相匹配的价格&库存,您可以联系我们找货
